Backing up DVD’s with improved image quality for free! Here is how! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 03-02-2005, 09:27 AM
usg
usg's Avatar
Thanks Socio! Looking forward to your updated script and Zip.
USG
usg is offline
Old 03-02-2005, 02:54 PM
Li On's Avatar
Finally trying to make a encode with this method. But every time when I select a "Source Path" by pointing to a VIDEO_TS folder (either a virtual mounted drive or a hdd folder ripped in IFO format), DVD-Rebuilder just gives me a error:
Run-time error '6': Overflow
And quit!
I haven't even started to setup any Avisynth script! And I do have the 2 msxxx.dll under windows\\system32!
I'm using the DVD-Rebuilder v0.74 installer from their web. Tried the latest 0.74a exe with same result.
Thanks in advance.
regards,
Li On
PS: I want to do MC video deinterlace with MVBob(). The script runs ok in FFDShow Avisynth with a correct picture. Though the frame rate is only around 2fps I think!
Li On is offline
Old 03-02-2005, 03:23 PM - Thread Starter
Socio's Avatar
Quoted: 18 Post(s)
Li On,
With regards to that error check this out:
http://forum.doom9.org/showthread.ph...682#post488682
Socio is online now
Old 03-02-2005, 10:37 PM
Li On's Avatar
Thanks! Change Windows to English language works, though it's annoying!
I just started an encode and the CPU usage is now at 100% so I guess it's working.
Is there any way to see the encoding frame rate and total/remaining encoding time?
regards,
Li On
Li On is offline
Old 03-02-2005, 10:51 PM
Li On's Avatar
I found the fps reading. It's in the QuEnc 0.59 box. It say 1.35fps, 02:07:25 Time Left, 1/2 Pass.
Use VBR, High Quality, Use Trellis Quant, 2 Pass Encoding all checked. Should I be using these setting?
Btw, is there a way to leave the Audio protion untouch? Or it must be transcoded too?
regards,
Li On
Li On is offline
Old 03-03-2005, 07:13 PM
warlordbb's Avatar
Socio, you have PM!
We need to get you some free filespace and I'm offering to do just that!
warlordbb is offline
Old 03-05-2005, 08:00 AM - Thread Starter
Socio's Avatar
Quoted: 18 Post(s)
Thanks to warlordbb for hosting my files a new scripts.zip is available on the first page with most of the scripts seen in this thread and a new one that USG requested.
Also there is a new version of the ColorMatrix Avsynth plugin available you can get it
here
Socio is online now
Old 03-05-2005, 08:17 AM - Thread Starter
Socio's Avatar
Quoted: 18 Post(s)
regards,
Li On
Those are the settings I used for the best quality and yes it is slow but if you want the best from it you have to be patient. CCE basic is a bit faster which is what I have now but it will cost you $58.
Side note: I know that Didee is working on a new version of IIP that is supposed to be much faster so when it is released it should speed things up doing these DVD backups.
As far as excluding the audio side I am not sure.
Socio is online now
Old 03-05-2005, 08:41 AM
Li On's Avatar
I did a 4 mins clips and it took around 30 hours to finish on my P4 3G 512M!
My test is on MVBOB in this thread http://forum.doom9.org/showthread.php?threadid=84725
I use the all-in-one mvbob.rar in page 4.
I want to do deinterlace on a pure 60i DVD clip. The avisynth script claim some kind of motion compensation video deinterlace.
The problem is my clip is pure NTSC 480i 59.94 (or 29.97fps). But the re-encoded clip becomes a 25fps format so everything is in SLOW motion!
I've no idea what went wrong. I registered on the Doom9 forum but need to wait 5 days before I can post a question!
regards,
Li On
Li On is offline
Old 03-05-2005, 08:52 AM - Thread Starter
Socio's Avatar
Quoted: 18 Post(s)
I played with that script a while back works nice but I realy did not have a need to use it.
I believe you have to add either mvfps(59.94) or convertfps(59.94) to your call script for it to output correctly not 100% sure though.
Or could be mvfps(29.97) or convertfps(29.97)
Socio is online now
Old 03-05-2005, 09:18 AM
Li On's Avatar
I know there is a mvfps function but I thought it's for NTSC/PAL conversion. My clip is already the correct NTSC 59.94 and I just want to do the video deinterlace as is.
I hope I can get some hint when I can post on Doom9.
regards,
Li On
Li On is offline
Old 06-16-2005, 06:38 AM
ulisse's Avatar
Hi Guys
i am an Italian Boy,
i have founded this thread "Backing up DVD’s with improved image quality for free! Here is how! - AVS Forum".........
absolutely amazing!
Congratulations!!
I have started to read the thread to understand the procedure ecc......but i have notated that there are a lot of changes in the procedure/softwere/settings ecc.....and my English is not too much good.......
this is the point of question:
I want to apply that procedure to "Citizen Kane" ntsc Warner R1(one of the best movie of the Istory in my opinion),
as you know that movie is in black and whyte ,4/3 format ecc....
so i want to ask you:
1)have you just/never"filtered Citizen Kane before?
2)what kind of procdure you can suggest to me to apply to that movie (as i have wrote i have not understood all the various procedure and relatives reasons of changing ecc....,
so if you can say to me directly what kind of procedure and setting you will be use for this movie it will be grat for me!
Thank you.
best regards
ulisse is offline
Old 11-15-2005, 08:02 PM
Mr.Bitey's Avatar
Hi Socio,
Very interesting (just finished reading this thread, and your other thread on pre-processing using limited sharpen (in real-time)).
Ive been using ffdshow for a couple of years now and am generally happy with the results, however i'd like to see how some DxVA capable decoders display a processed mpeg stream - ie. not use ffdshow when viewing at all and do all of the processing beforehand (including resizing to, in my case to 1776x1000).
I also watch a lot of recorded HDTV (1920x1080) and for these I strongly prefer the more fluid DxVA capable decoders to the likes of dscaler5006 with ffdshow.
Is it possible to use these methods to create a mpeg stream that is both resized and 'enhanced' ? (which can then be viewed with a DxVA capable mpeg decoder) ?
EDIT: Just finished reading Didee's thread over on doom9 which sounds like it will do what I want, hopefully I can work out how to make it work with DVD-RB / CCE which is what im planning... I think there are many late nights ahead!! (if you have any tips let me know! :-)
Cheers,
Bitey
Mr.Bitey is offline
Old 11-16-2005, 05:19 AM
tetsuo55's Avatar
would it help to use lanczos 2 at 4x enlargment, then back to regular dvd resolution?
it would take a lot longer, but i wonder if it further enhances image quality
tetsuo55 is offline
Old 11-16-2005, 10:08 AM
jammarjim's Avatar
Why not just buy the BlueRay version next year ;)
jammarjim is offline
Old 11-16-2005, 10:27 AM
tetsuo55's Avatar
That says absolutely nothing about quality
tetsuo55 is offline
Old 11-16-2005, 10:41 AM
jammarjim's Avatar
The HD version will surely give you much more detail than you'll ever get from all this work.
However I was just kidding, I know that it will be awhile before many titles are available in HD. This just seems like an awful lot to go thru for such a small gain.
Old 11-18-2005, 11:25 AM
tetsuo55's Avatar
Serveral movies aired in HD are worse quality than the dvd releases
tetsuo55 is offline
Old 11-18-2005, 01:21 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
OTA HD != next gen DVD
OTA HD is mpeg2 with around 75:1 compression vs DVD also using mpeg compression but closer to a 20:1 compression ratio. This means current HD often has many more artifacts from it's compression than DVD does, these artifacts often far out weigh the increase in resolution.
next gen DVD will be H.264 encoded an will have much better pq as a result.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 11-19-2005, 03:29 AM
tetsuo55's Avatar
However true that may be, an upconvert will always be nothing more than an upconvert. In Being only that, these upconverted DVD's come pretty close to what youll get on nextgen dvd. Even upconverting masters will still cause grain because a lot of them are old.
Only movies filmed in HD will really show how beautifull HD is
tetsuo55 is offline
Old 12-19-2005, 05:34 PM
Mr.Bitey's Avatar
Hi Guys,
Any developments in this area?
I believe that using MT for dualcore/hyperthreading/dual CPU's can result in quite an increase in performance... check out socio's other thread on using limtiedsharpen in realtime for more info.. and socio's site (which brings it all together very nicely!) note: the site doesnt have this method but the new work can be applied to this process I believe..
Socio,
Is there a way to tell DVD RB to not 'shrink' the video down? - ie not further compress the source material ?
Ive been toying around with virtualdubmod scipts and outputting to an uncompressed avi then feeding into cce (but havent done so yet as Ive been busy playing with ffdshow/limitedsharpen (thankyou!)..
Cheers,
Bitey
Mr.Bitey is offline
Old 12-19-2005, 07:11 PM
Quoted: 21 Post(s)
Originally Posted by Mr.Bitey
...Is there a way to tell DVD RB to not 'shrink' the video down? - ie not further compress the source material ?...
Yes, by placing a TargetSectors=xxxx into the Rebuilder.ini file under Options, you can control the "shrinkage". I forget the default sectors, but they are something less (maybe 50-100Mb) than full DVD-R size. You can change this to fit a DL disc; I have done it.
There are Rebuilder support forums at Doom9 and digital-digest where you can ask further about this.
Laserfan is offline
Old 12-19-2005, 08:48 PM
Mr.Bitey's Avatar
Cool - thanks Laserfan
Cheers,
Bitey
Mr.Bitey is offline
Old 12-20-2005, 12:31 AM
sxr71's Avatar
So what you're saying is that OTA HD is basically a sham? When I first got HDTV on my computer monitor I noticed how heavy the artifacting was and I thought it to be a substandard broadcast. While OTA HD is better than analog TV I've noticed that it is a trade off of sorts, almost like picking your poison. Analog aritifacts or digital artifacts?
sxr71 is offline
Old 01-04-2006, 12:02 AM
shadowfax3000's Avatar
So uhhhh...where's IIPX.zip? Can someone post it please?
shadowfax3000 is offline
Old 04-14-2006, 07:24 PM
adrianmak's Avatar
i'm also waiting the IIPX.zip reupload too.
Besides, I've a question, if I use any of the scripts mentioned under this post to to dvd ripping (i.e. dvd -> xvid/divx), should I put deinterlace process, cropping, and video resize , all after the pre-processing scripts/filter ?
For example
Code:
SetMemoryMax(96)
Import("C:\\Program Files\\AviSynth 2.5\\plugins\\LimitedSharpen2.avs")
#  PLUGINS
LoadPlugin("C:\\PROGRA~1\\GORDIA~1\\DGMPGDec\\DGDecode.dll")
LoadPlugin("C:\\Program Files\\AviSynth 2.5\\plugins\\Convolution3DYV12.dll")
LoadPlugin("C:\\Program Files\\AviSynth 2.5\\plugins\\undot.dll")
LoadPlugin("C:\\Program Files\\AviSynth 2.5\\plugins\\MaskTools.dll")
LoadPlugin("C:\\Program Files\\AviSynth 2.5\\plugins\\WarpSharp.dll")
LoadPlugin("C:\\Program Files\\AviSynth 2.5\\plugins\\colormatrix.dll")
LoadPlugin("C:\\Program Files\\AviSynth 2.5\\plugins\\asharp.dll")
LoadPlugin("C:\\Program Files\\AviSynth 2.5\\plugins\\aWarpSharp.dll")
#  SOURCE
mpeg2source("F:\\[DVD-VOB]movie\\movie.d2v")
Convolution3D (0, 6, 10, 6, 8, 2.8, 0)
LimitedSharpen2( ss_x=1.0, ss_y=1.0,
\\ Smode=4, strength=60, radius=2, aSharpS=0.4,
\\ Lmode=1, wide=false, overshoot=1,
\\ soft=false, edgemode=0, special=false,
\\ exborder=0 )
UnDot()
ColorMatrix()
FieldDeinterlace()
crop(2,0,716,476)
LanczosResize(640,480)
adrianmak is offline
Old 04-16-2006, 07:27 PM
Mr.Bitey's Avatar
Guys,
Check out the IIP5 thread over on doom9 - i believe all the scripts are there - there are a few versions tho so make sure you get right 'version'.
Cheers,
Bitey
Mr.Bitey is offline
Old 04-19-2006, 02:25 AM
adrianmak's Avatar
Guys,
Cheers,
Bitey
I'm sorry, I can't search any post neither by keyword "IIP5' nor by username
Old 04-19-2006, 07:18 PM
Mr.Bitey's Avatar
Adrianmak,
Here you go:
http://forum.doom9.org/showthread.php?t=70916
Seems the search function is crap :-)
Its a bugger to get working as copying scripts from sites (ie. copy/paste) seems to add spaces in unusual places which creates script errors.
I think some of the later posts here (or possibly doom9) have some 'packages' (downloadable zips and the like) which are easier to get working and have fixed scripts
You may also want to check out seesaw (doom9) - seems to be part of the Didee's new project..
IIP is really really slow BTW...
Cheers,
Bitey
Mr.Bitey is offline
Old 06-09-2006, 05:42 AM
joblack's Avatar
import("C:\\PROGRA~1\\GORDIA~1\\AviSynthPlugins\\Limitedshar pen2.avs")
LoadPlugin("C:\\PROGRA~1\\GORDIA~1\\AviSynthPlugins\\UnDot.d ll")
LoadPlugin("C:\\PROGRA~1\\GORDIA~1\\AviSynthPlugins\\MaskToo ls.dll")
LoadPlugin("C:\\PROGRA~1\\GORDIA~1\\AviSynthPlugins\\WarpSha rp.dll")
LoadPlugin("C:\\PROGRA~1\\GORDIA~1\\AviSynthPlugins\\asharp. dll")
LoadPlugin("C:\\PROGRA~1\\GORDIA~1\\AviSynthPlugins\\aWarpSh arp.dll")
LoadPlugin("C:\\PROGRA~1\\GORDIA~1\\AviSynthPlugins\\colorma trix.dll")
LoadPlugin("C:\\PROGRA~1\\GORDIA~1\\AviSynthPlugins\\LoadPlu ginEx.dll")
mpeg2source("D:\\kovboy\\kovboy.d2v")
crop(2,76,716,426)
LanczosResize(704,288)
Undot()
ColorMatrix()
\\ Smode=4, strength=40, radius=2,aSharpS=1,
\\ exborder=0 )
FieldDeinterlace()
ERROR ??????
1. Avisynth open failure:
script error:there is no function named "mpeg2source"
(D:\\ kovboy\\ kovboy.avs,line9)
OK
2.Cannot open file "kovboy_Movie.avi"
joblack is offline
