MyHD MDP-130 - Page 420 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #12571 of 12590 Old 03-22-2015, 06:34 AM
SFischer1's Avatar
Quoted: 380 Post(s)
Liked: 56
Originally Posted by Muse View Post
If I get multicore CPU, what are the features I will sacrifice if I don't run single core? Link? TIA...
MyHD MDP-130 Meta FAQ
SHF
SFischer1 is offline
post #12572 of 12590 Old 03-22-2015, 03:53 PM
ccrider2's Avatar
Quoted: 25 Post(s)
Originally Posted by TPeterson View Post
Anybody--
Why am I not getting notified of new posts to AVS Forum anymore???
I assume you've checked your junk folder; For some reason, I'm getting a lot of my AVS notifications sent to mine. Started a week or 2 ago. If it keeps up, I'll have to set up a rule...I guess.
Thanks uncle Bill...
Chris C
ccrider2 is offline
post #12573 of 12590 Old 03-22-2015, 05:00 PM
TPeterson's Avatar
Quoted: 176 Post(s)
Liked: 26
Chris--
Mine are coming in again now, not to junk. It was the system-wide issue that Nanni pointed out. (Add AVS Forum to your trusted senders and you won't need a rule)
TPeterson is offline
post #12574 of 12590 Old 03-22-2015, 05:39 PM
ccrider2's Avatar
Quoted: 25 Post(s)
Chris--
Tried that, also added to contact list, and flagged as not junk, but they still end up in Junk; some of the time.
Chris C
ccrider2 is offline
post #12575 of 12590 Old 03-23-2015, 04:46 PM
Muse's Avatar
Quoted: 20 Post(s)
Originally Posted by SFischer1 View Post
Thanks, I don't think I've ever used those features that don't necessarily work with multi-core processors. I use standalone Blu-ray player for DVD playback, I do have a network but basically not much if any need to play recordings over my network, not unless I could use my ethernet connected Blu-ray player to play them instead of using MyHD app running on my HTPC. Seems not worth the trouble, especially in light of the presumed fact that the MyHD remote wouldn't be usable for that. I use a universal remote for everything, pretty much (or can).
I have firewire but haven't used it in several years.
I do have two MyHD cards in two different desktops, my little used one is running Windows 2000 Professional!
browncoat likes this.
Muse is offline
post #12576 of 12590 Old 05-21-2015, 10:19 AM
AllenDB's Avatar
MYHD Cable
In my last move I lost the cable that plugs into the MYHD card. I remember having to buy a bit different/special cable when I bought the card. While I don't use MYHD to record anymore I do use the PLM to keep track and order of programs to view. Can someone maybe post a url on where to buy another cable???
AllenDB is offline
post #12577 of 12590 Old 05-21-2015, 11:42 PM
browncoat's Avatar
Quoted: 18 Post(s)
While I went over to Kei's to see if the spare remotes were still there, they weren't on the web pages,
but I would call to see if one can still get the spare remotes and dongles from D.C. they were listed on a back page
up until the new year.
browncoat is online now
post #12578 of 12590 Old 08-03-2015, 03:48 AM
browncoat's Avatar
Quoted: 18 Post(s)
Dumb question...
Gotta new monitor
Will MyHD control panel dual monitors option work if I want to
output the blue dongle to the VGA input, then my video cards'
HDMI, DVI output to that on the monitor or will it squeal that it
is only detecting a single monitor. Monitor is supposed to auto switch.
Or does it have to be VGA/VGA DVI/DVI only? Got no daughter card
and never tried it before and exhausted from job..brain not functioning right.
post #12579 of 12590 Old 08-03-2015, 06:18 AM
TPeterson's Avatar
Quoted: 176 Post(s)
Liked: 26
Bruce, if I'm reading your question right you want to connect your monitor's two inputs to separate outputs from the computer: VGA from the MDP130 and DVI from the video card. In effect you'd just be replacing the blue dongle's switch with the monitor's switch and it should work fine.
post #12580 of 12590 Old 08-03-2015, 06:37 AM
SFischer1's Avatar
Quoted: 380 Post(s)
Liked: 56
Originally Posted by browncoat View Post
Dumb question...
Gotta new monitor
My 37" monitor (With a dead ATSC Tuner and two NTSC tuners) has numerous inputs.
VGA from MyHD with the desktop if selected, DVI desktop from the Graphics card and HDMI from my laptops (Does not sync well at times with one or two) all are selected using the HDTV remote (Bought with a rotten ATSC tuner value = $0.0 now, not much better at the beginning).
My monitor has no auto switch function, check your manual to see how to switch manually, I need to use the remote to switch.
Winbook 37M1 - 37 LCD HDTV & PC-HD Monitor Official Thread
Winbook 37M1 - 37" LCD HDTV & PC/HD Monitor Official Thread
The ATI Catalyst Control Center is used to place the same desktop image on both the VGA and DVI graphics card output.
Do not set the extend option to use VGA and DVI side by side.
Without your HDTV's manual (link) and your graphics card model (link) much more cannot be said.
SHF
post #12581 of 12590 Old 08-03-2015, 07:03 AM
browncoat's Avatar
Quoted: 18 Post(s)
Thank You guys, got some sleep, feel better now, will make the above a .txt to place in my reminders and tips folder, in case I forget.
Yep, what Terry said.
post #12582 of 12590 Old 08-21-2015, 03:08 AM
gilpv's Avatar
MYIRC isn't recognized
My old DVR PC died so I configured a newer (still old) PC to be my DVR. Based on what I read, I could use Win 7 so long as it was 32 bit and I used XP compatibility. I initially used XP SP3 compatibility but it didn't work but once I used SP2 all seemed fine.
The only problem I'm running into is that MYIRC is not recognized. I looked for newer drivers but I couldn't find any. I then used the inf file from the disc that came with the card but I got an error message when I tried to install it.
Any thoughts?
gilpv is offline
post #12583 of 12590 Old 08-21-2015, 10:45 AM
TPeterson's Avatar
Quoted: 176 Post(s)
Liked: 26
Gil--
You can install MyHD in W7 using XP-SP3, but I don't know of any downside from choosing SP2 either. Which versions of MyHD installer and Driver updates did you use? The latest ones are MyHD_App_Drv_v1.66.1E.exe and MyHD_App_Drv_Update_v1.66.1.1.exe.
With the latter file, for some reason, you can't just select the correct compatibility on the Properties tab, but instead you have to select Troubleshoot Compatibility from the right-click menu. IIRC, I may have had to run (using XP compatibility) the installation exe that's inside the Driver folder in the MyHD Program Files folder after the main installation to get the USB receiver to function correctly. And even then it sometimes failed to get recognized on resuming from sleep on one of my systems.
gilpv likes this.
post #12584 of 12590 Old 08-22-2015, 03:39 AM
gilpv's Avatar
Gil--
TPeterson,
Thank you!!!! That did it. Even though I got an error when I ran the installation within the Program Files Folder, once I rebooted all was well. It nice to have my DVR back.
Much appreciated.
gilpv is offline
post #12585 of 12590 Old 09-23-2015, 01:10 PM
browncoat's Avatar
Quoted: 18 Post(s)
Small Personal update:
On the workstation, since it doesn't look like I'll install the second MyHD any time soon, not at least until I can build a unit that can handle Blender and other CGI fun stuff. I used the ASUS core unlocker and turned it into a Athlon II x2 4450e. Can always reverse it later, the dedicated PVR is still a Sempron 145, since I download everything else, the PVR primarily records the CBC, since I can seldom count on finding files for them, not much demand beyond Suzuki's "Nature of Things" docu's.
Broke my foot, first time I ever broke a bone, out of commission for at least six weeks, so getting a new fridge will have to wait until spring, car insurance has to be paid!
So in that case, bought a 4TB drive to replace the failing ('cording to CrystalDiskInfo utility) Television drive, a 2TB Seagate green [unhappy since Seagate got me through all my Atari years] with less than 30,000 (currently 28654) hours on it. They should last 100,000! WD were the ones going tits up on me during the Win'98 period.
A local brick and mortar has WD greens on sale, so will give it a try, less hassle than mail order if I have to return, will keep old one as backup but unplug power/data to it.
Does anyone know if Kei is still selling spare MyHD remotes?
That's pretty much it for now.
TTFN
post #12586 of 12590 Old 09-23-2015, 03:32 PM
TPeterson's Avatar
Quoted: 176 Post(s)
Liked: 26
Bruce, you can email her (sales(at)digitalconnection(dot)com) to find out. If she's out of them, PM me your address and I'll send you the one that (I think) I have sitting here.
post #12587 of 12590 Old 09-24-2015, 03:00 AM
browncoat's Avatar
Quoted: 18 Post(s)
No Immediate need, its' just that they seem to have disappeared from the web pages at DC.
Thanks Terry.
post #12588 of 12590 Old 10-27-2015, 09:17 PM
SFischer1's Avatar
Quoted: 380 Post(s)
Liked: 56
Revolutionaries: Worm: The First Digital World War
Welcome to the MyHD on Windows Vista & W7 / W8 / W10 Main thread
That forum is where the discussion should occur IMHO.
SHF
post #12589 of 12590 Old 04-18-2016, 06:37 PM
SFischer1's Avatar
Quoted: 380 Post(s)
Liked: 56
XP user with Java and Schedules Direct?
Is anyone who is running XP SP3, have Java installed and has signed up for Schedules Direct still here?
I am looking for someone who can download and install another approved application, "FreeGuide".
Two people are having problems and I appear to not have a XP SP3 install anymore.
TIA
SHF
post #12590 of 12590 Old Today, 11:03 AM
browncoat's Avatar
Quoted: 18 Post(s)
OK, bloody password changed and recorded in the handler!
Reply Home Theater Computers
