MyHD MDP-130 - Page 421 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #12601 of 12611 Old 09-08-2016, 05:10 AM
Liked: 0
John walker
everything sounds good to me
suethecollectors is offline
post #12602 of 12611 Old 09-15-2016, 10:56 AM
browncoat's Avatar
Quoted: 21 Post(s)
Question
Are the blue dongles known to go belly up? {did a search, couldn't find any old posting}
As an experiment, I left the PVR on, just the desktop, MyHD off and physically turned the monitor off.
Upon returning from errands, switched monitor on, desktop appeared, then screen went black [no screensaver active]
with the blue monitor switch light on & not going to amber. Activating the MyHD it took about eight on/offs, pressing the
remote's HD button over and over again, before both TV picture and desktop were stable.
Maybe re-seat the card? The whole bloody case needs a good dusting any how.
The only way around this so far is what I did the previous day, just leave monitor on, no screen saver or other power settings,
MyHD activation/use then went as normal. Probably going into dual monitor mode in the CP would also get around this glitch.
browncoat is online now
post #12603 of 12611 Old 09-15-2016, 11:07 AM
TPeterson's Avatar
Quoted: 209 Post(s)
Liked: 26
Bruce, I'm betting that the problem will go away after your housecleaning. But if it doesn't PM me an address and I'll send you one of the spare dongles from my closet.
TPeterson is offline
post #12604 of 12611 Old 09-22-2016, 09:50 PM
browncoat's Avatar
Quoted: 21 Post(s)
It was the monitor.
Swapped dongles with the one that was boxed, but Thursday went to watch the noon news, blue light, not amber , sound but no picture.
Wasn't using the MyHD, swapped a neighbours spare [with damaged pixels] but had both the desktop and TV with just a bit of aspect ratio crunch, so guessing it is the LCD backlight that was acting up. For when I reconnected, the monitor {Acer 24"} would go dim in a corner, then go black with the blue light on, like it was receiving a signal but pooping out on illumination.
That means this identical model will go in the future, the main difference, when I walk away I just hit the power button off, no screensaver or
other power settings.
post #12605 of 12611 Old 09-25-2016, 02:05 PM
browncoat's Avatar
Quoted: 21 Post(s)
Got the monitor 1920x1080, now trying to figure out what gives the best aspect ratios, 1280x1024p from the VGA menu tab doesn't cut it like it did on the 1680x1050
monitor. No black bars top and bottom on wide screen HD shows any more.
For now, leaving it on 1920x1080i but like an earlier poster, wish there was a setting 1920x1080p because at this setting the OSD menus look
kinda rough and flickery eventhough the picture isn't. In the other settings the OSD menus have a smoother look. Plus people and things look a tad
too 'thin' , imperceptible to most, I'm just finicky that way.
post #12606 of 12611 Old 09-25-2016, 03:41 PM
SFischer1's Avatar
Quoted: 435 Post(s)
Liked: 58
My new monitor has HDMI inputs only.
OSD menus look kinda rough and flickery
Same here with my new Sony.
With the VGA to HDMI adapter 1080P produced no picture, 720 a great one. BUT!!! The pass through audio requires speaker setting for audio output (Cord plugs in the normal speaker out jack).
So if I want to use the MyHD VGA output I have to switch the audio. (Note, a different Graphics Adapter may not require this.) I expect to use MyHD only when Fusion is down waiting for another reinstall. EDIT: Another failed switch to KNTV VC 11 RF 12, computer restart needed, . Then Fusion repair, restart, Fusion uninstall, restart, Fusion install, restart, scan for channels, change settings. My HD prepared if needed.
http://www.newegg.com/Product/Produc...82E16812186169
SHF
SFischer1 is offline
post #12607 of 12611 Old 09-25-2016, 10:16 PM
browncoat's Avatar
Quoted: 21 Post(s)
Originally Posted by SFischer1 View Post
My new monitor has HDMI inputs only. Same here with my new Sony.
SHF
I was able to find a variant of a Acer G6 model:
http://www.acer.ca/ac/en/CA/content/model/UM.HG6AA.G04
That has one of each, D-sub 15 pin VGA, standard DVI and one HDMI.
@ the local Staples for 199.99 CDN, 30 bucks cheaper than the W233's were in
2008. , so I added a service package for 29.99, all because out of hundreds of
glowing reviews, there were six bad ones I encountered. So, hedging my bets
for inconsistencies on the factory floor. When I can afford it, like to replace this final
W233 with another, great computer monitor, plenty of real estate, but having found
the optimum setting, so people, foregrounds and backgrounds look proper, it was
actually the 1024x768p setting that produced the best results, so now on 16:9 material
I have black all around the outside. Having UN-checked the option in the 130's OSD
tab to display the output, it reverted to reading "AUTO" in capitals, and furthermore
SD material actually fills in more of the screen.
On the other hand, if I went the other way, and bought a 'real' TV, I'd have to be sure I get one
that has controls to reduce the overscan when used as computer monitor, or else the icons will be in the wrong place,
and the wall paper skewed and even some of the taskbars may be hidden by the overscan.
Still a larger picture by all accounts, and the MyHD's OSD menus are much smoother looking.
Still getting used to it. The manuals are pitiful, why even bother putting out a CD if the thing is do devoid
of the kind of info techheads require, and it didn't even fully relate to my particular model!
Now I understand the noobs, those that want the incoming picture to fill all of the real
estate, yet put up with a maladjusted set that doesn't display the true aspect ratios.
They'll sit there, watching their sports and wondering why all the people are 'skinny'
on TV. I got one on the far north corner that screams and yells 'why do all the people look funny?'
I scream and yell too, but my frustrations are in other areas {like being poor and hating it} .
BTW, when I was learning the controls that are there, I discovered that it keeps more than one
memory of the settings, even if the same input is used, and in the previous 1920x1080i, when using
the 130, It reads that the output, at the dongle, is actually 1920x540, meaning that the monitor works
best with progressive, rather than interlaced peripherals. NONE of it in the manuals, and the box material calls it an LED
yet on-line descriptions call it LCD, no wonder people get confused.
post #12608 of 12611 Old Yesterday, 08:00 AM
Muse's Avatar
Quoted: 20 Post(s)
Don't know why aspect ratios using MyHD are problematic. I don't normally use OSD anymore, just go full HD at 1920x1080i and my aspect ratios look perfect on my PJ system, also on my 23" computer monitor. I'm a guy who notices distorted images (too skinny, etc.), and I'm virtually positive I'm not getting any of that. I don't think I'm losing any of the picture (could be wrong), and I get no black bars at top/bottom or sides. It appears I get a perfect fit.
What does happen occasionally (maybe every 15 hours of MyHD use), is that the screen will go suddenly blank. A workaround for that (besides resetting the PC!), is to go out of HD mode, go into MyHD settings, set the res to other than 1920x1080i, poke the Apply button and then set it back to 1920x1080i, poke apply again, close settings, go HD again and the picture is back. I discovered the other day that it's possible to do all this with the remote, but I haven't done that yet, not sure it will work but I'll try it next time the screen goes black.
There are plenty of little or big gotchas/caveats with the MyHD cards (it doesn't surprise me that my first one was given up unused by an Ebay seller who decided to go Tivo HD instead!!!), but I've always managed to get it to work one way or another. Plenty of aggravation, but no clear reason to toss it in a dumpster and find another solution for HDTV/DVR.
Muse is offline
post #12609 of 12611 Old Yesterday, 05:58 PM
SFischer1's Avatar
Quoted: 435 Post(s)
Liked: 58
My Graphics card (On W7) just asked the TV what it was and what resolution it wanted to use and all has been great from the start. (1080p)
MyHD with the desktop passed on produced no picture. I finally disconnected the graphics card and selected 720p and a great picture appeared.
I have discovered that I can switch between the two HDMI inputs with just a button press on the Sony remote so no need to pass the desktop through. The sound is available only on one of the HDMI inputs at a time which is a bummer.
SHF
post #12610 of 12611 Old Today, 08:08 AM
Muse's Avatar
Quoted: 20 Post(s)
I'm going to have to come back later, this !@#$%^%$#@! board didn't process my response to Muse, and didn't save a draft, now I'm missing the news.
While you are composing your message, I'll add this:
My PJ is an Epson 8700UB, which I bought reburb at Visual Apex. Great image, great blacks, a lot of bang for the buck. Still on my first bulb since I got it over 4 years ago, probably around 3000 hours on it now. I run it in Eco mode and low brightness to boot (projecting from a meager 10 feet in a very dark room, I don't need much brightness). I believe this makes it run relatively cool and extends my bulb life greatly.
I also run it in an altitude setting (although I'm at 80 feet above sea level), which makes the fan work harder. This creates more noise, but since I use earbuds, I don't hear that noise and bulb life is further extended, undoubtedly. I feel this is a good idea because I often run this in a hot room where the temperature reaches nearly 90 degrees F.
Its native res is 1080p = 1920x1080. Same native res on my 23" desktop monitor, so AFAIK I get a perfect image using 1920x1080 in MyHD. I got a cheap switch from Monoprice to switch between the 23" and the PJ. Works flawlessly, but you have to walk up to it, it can't be switched with a remote control. However, it's never failed me.
Muse is offline
post #12611 of 12611 Old Today, 01:49 PM
browncoat's Avatar
Quoted: 21 Post(s)
Oh! You're talking projectors, I was going to accuse you of running the 130 in 'Zoom' mode all the time..that's the only way not to see any bars around the picture on a true monitor, you should see the crazy numbers I had to use when setting up KMPlayer, in order to get the proportions correct, but that doesn't affect the source material, 1080p always looks better than 720p .mkv but are larger files and .mp4, especially in 720 always looks inferior. Aspect ratios too, since I have it set in another menu "Keep Source Aspect Ratio" but doesn't affect quality, wide screen movies vary and you can see it.
Well, in the control panel, the AV tab, what says Resolutions, should probably have been marked some thing else, because over to the right of that, the upper box is greyed out on mine and I leave it in Auto Letterboxed, on the right side where it says Aspect Ratio, and you can see it change according to the input of the broadcasting station. Like some sub-channels only transmit 720x480i, however they're not all the same because, if you use the On Screen Data, in curved brackets it will tell you if the material source is 16:9 or 4:3, but you say you don't use the OSD {or do you have that confused with the annoying overlay, which I disabled since day one}. Most people I know, even those that use Hauppage, or however its spelled, use at least the two settings so they can see what channel/station their on and the time of day from a distance, and when I change channels, I have it set for a 5 second display, though I've forgotten by now what the default was.
How do you tell what station you're on? Don't you even want to use the on-screen clock that's built in?
Yet, on the main channels you can see that the 1920x1080i stations are crisper than the ones, like the local CBC that went down from that to 1280x720p are softer focus and sometimes displays artefacts. Terry said {IIRC} a long time ago that , if it transmits 1080, that's what you see, ditto for 720p and the rest. That's what I like about the On Screen Data {as I like to call it, rather than that other word} I can tell what the broadcasting station is sending me but I wish the local CBC would send out PSIP, to make programming easier. So I have all the boxes on the left of that tab checked, but leave the one marked resolution [erroneously] on the right of the tab unchecked.
I don't know, maybe you do have it on 'Zoom' all the time, are logos and other data cut off at the sides sometimes?
Aren't you the one that has all the trouble with time-shifting?
As for "The Glitch" , well it locks the computer during scheduled recording but doesn't harm the final result, so you have to wait until it is done, then do that action, or reboot. So when I was in the Hospital I had a friend not only feed my cat, but if they came in prior to the start of prime-time TV, give the PVR computer a hard reboot at the PSU switch, to reload all drivers and avoid that occasional hammering sound effect that locks up the machine as well, especially if they hear it, but that only occurs every four to six months, if ever, without the practice of hard rebooting. Peculiar thing, after not getting it for three years, it came back with a vengeance, once in December, then again in May but has behaved since, with dusting and a schedule of hard reboots.
This monitor, unlike the W233s, actually have an input switch on the bottom, I played with it, watching it cycle until it stopped at the VGA selection, so I may experiment this weekend with the VGA tab's Dual Monitor option and hook the video card to the DVI and the 130 to the VGA and see how it behaves. Still angry at the lack of quality in the manuals, the CD at least should have been more comprehensive, so I left a star off for that.
Reply Home Theater Computers
