MyHD MDP-130 - Page 90 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
Old 06-23-2005, 08:00 PM
Nrmf's Avatar
Cliff..TPeterson
need your help please.. i have to put an HTPC together for a customer and i want bad to install an Myhd for them..but they want a small foot print Case which means most of the time low profile, can you suggest a small case that an myhd will jam into or will i be better off looking at the new fushion 5.
thanks guys
Nrmf is offline
Old 06-23-2005, 08:10 PM
Cliff Watson's Avatar
Originally Posted by Nrmf View Post
Cliff..TPeterson
thanks guys
Here is a low cost/low profile case that I've used with MyHD.
http://www.digitalconnection.com/Pro...ses/ci6004.asp
Cliff Watson is offline
Old 06-23-2005, 08:30 PM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 30
Yep, I used that case for my first HTPC. I later decided that a tower form factor works better for me and switched to the Antec Sonata. The DC case isn't very "small footprint," but it does fit in with other HT-type boxes in a stack. The "proprietary" PSU is a negative, IMO, also.
TPeterson is offline
Old 06-23-2005, 09:10 PM
Les Auber's Avatar
Quoted: 66 Post(s)
Pardon me for butting in but I've found the Sonata to work quite well with MyHD also. And it's relatively quiet if you use the Antec fan bus. This even with a couple extra fans. The only thing I did that made it a little noisy was add a second HD, a SATA 7200 rpm Maxtor. The original 7200 rpm IDE Seagate was inaudible. Oh, and the optical drive is fairly noticeable too when it spins up.
Les
Les Auber is offline
Old 06-23-2005, 10:27 PM
DPlettner's Avatar
I have a Sonata, and it is a very nice case. However, the PC connected to my TV is in an Antec Overture case. It is low profile, and there is plenty of room for the MyHD and DVI cards. However, it runs much hotter than the Sonata.
I think Antec has addressed the heat issue, since the picture of the Overture now has a big vent on the side, and the picture of the Overture II appears to have a vent on the top. My case has neither.
-Dave
DPlettner is offline
Old 06-25-2005, 11:54 AM
navarros's Avatar
I've just installed the MyHD 130 with the DVI daughter card. I used the latest drivers posted at www.digitalconnection.com (from which I purchased the card).
Everything went fine except for two things:
1) The image I get from all channels is horrible (looks like the negative of a picture). I tried changing the resolutions, but that didn't solve the problem.
2) MyIRC is not always responsive. Sometimes it works, sometimes it doesn't. I tried unplugging my wireless keyboard (logitech Gyration) to see if there was a compatibility problem, but that didn't help either.
I am using an Athlon system with an MSI motherboard (with the latest updates) and a GeForce 6800 card.
I used the MyHD 120 for a while in the past and everything worked fine.
Any suggestion?
navarros is offline
Old 06-25-2005, 12:03 PM
Any suggestion?
Sounds like you have a bad DVI card. Call teck support for a RMA.
Old 06-25-2005, 12:38 PM
Sbmocp's Avatar
This looks like the card I want to add to my MythTV setup. Does anyone know if Linux drivers are being developed for it?
Sbmocp is offline
Old 06-25-2005, 12:45 PM
navarros's Avatar
Soulds like you have a bad DVI card. Call teck support for a RMA.
Cliff,
Before I call for a RMA, I want to make sure the dvi card is correctly installed. I noticed that the pins didn't go all the way through the MyHD 130. I was extra careful because I know those pins are delicate and I could damage the card if they were bent or broken, but maybe I was too careful and the DVI card is not correctly mounted. On the other hand, should the dvi card not be properly mounted I wouldn't get a perfect pass through signal (as I do now).
Another thing: I don't get any image at all when using the channels preview (small screen). I do get the image (although with heavy color distortion) when I click on HD (Full screen).
What do you think?
Thanks, Cliff. I love MyHD cards because of the excellent support they get through this forum.
navarros is offline
Old 06-25-2005, 12:52 PM
I've not heard of Linux drivers being developed.
Old 06-25-2005, 12:58 PM
Cliff,
What do you think?
Actually you could get an image with pass thru, because the pins are the connection for the MyHD decoder and some control bits.
The pins on the DVI card should be flush with the black plastic stops in the pin header of the DVI card.
If you are not getting any image on the overlay window it could also be a problem with the main card.
Old 06-25-2005, 01:21 PM
Nrmf's Avatar
Cliff
can you help with an answer please. am i able to hhok up my dishnet box to the inputs on the breakout cable ...like the s-video and auido ins and if so will i be able to record with the myhd . i am sorry if this has been asked 57 times
Nrmf is offline
Old 06-25-2005, 01:41 PM
Cliff
Yes you can but I would not recommend using MyHD for analog recording because Video For Windows is crap.
You would be better off using a cheap analog card that has MPEG2 encoder onboard. Plus if you record in MPEG2 format it will play back on MyHD.
Old 06-25-2005, 02:09 PM
Nrmf's Avatar
well may not have much of choice seeing how i had to go with small footprint case, just hope i can shove myhd130 and daughter card in here.
http://www.newegg.com/Product/Produc...82E16856110024
Nrmf is offline
Old 06-25-2005, 02:14 PM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
I'm not sure, but there might be a USB device that would work.
Karyk is offline
Old 06-25-2005, 02:21 PM
Nrmf's Avatar
really like which one
Nrmf is offline
Old 06-25-2005, 03:59 PM
mdv
mdv's Avatar
That page is a little misleading. It says ATX power supply and then later says the power supply is proprietary.
Mark
mdv is offline
Old 06-25-2005, 05:52 PM
Mark
ATX power supply means that it provide the proper voltage and connectors for ATX motherboards. It can be both ATX and proprietary.
Old 06-26-2005, 07:21 AM
handlogten's Avatar
I just installed MyHD 130 and I get the following error when I try to play any DVD:
"Key exchange for DVD copy protection failed. Can't playback this DVD-Video disc."
This happens on all my DVDs (they are just regular store-bought DVDs)
I can play the DVDs using PowerDVD but with MyHD installed I cannot drag the DVD window to the "big screen" (I am set up for Dual Monitor) so I would really like to use MyHD for DVDs
My Hardware is:
Windows XP Pro
ASUS P4S800-MX mother board
Celeron 2.8GHz processor
ATI Radeon 9800 Pro video card
16x DVD drive
Its all fairly new hardware. I did a clean install of Windows. I really need to have this working by 6/30 or I will be in trouble with my family.
Thanks for the help
handlogten is offline
Old 06-26-2005, 07:31 AM
CharlesC's Avatar
Originally Posted by CharlesC View Post
Now I know at least 3 reasons why people don't like this card for analog:
1. The quality isn't as good as my WinFast TV 2000 Deluxe.
2. No WDM drivers. (which means no WME)
3. Can't record on the fly with space-saving formats.
I correct myself... in some cases the quality is better than the WinFast...
CharlesC is offline
Old 06-26-2005, 08:29 AM
UHD Addict
aaronwt's Avatar
Quoted: 5246 Post(s)
Liked: 3137
My Hardware is:
Windows XP Pro
16x DVD drive
Thanks for the help
I thought it won't play copy protected DVDs. I know mine can't. I have to decrypt my DVds to play them with the MyHD card. All the store bought DVds are copy protected.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
Old 06-26-2005, 09:20 AM
handlogten's Avatar
How do I decrypt them? Can I do that on the fly (as I am playing them)?
Old 06-26-2005, 09:46 AM
Oppo Beta Group
RichB's Avatar
Quoted: 881 Post(s)
Liked: 577
Do a google search for AnyDVD. That will make DVD's playable with MyHD.
-- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
Old 06-26-2005, 09:53 AM
RAFABAMAD's Avatar
DVD43FREE works for me and it is free.
Robert
Robert
RAFABAMAD is offline
Old 06-26-2005, 12:20 PM
Nrmf's Avatar
i got small problem either its the new nvidia drivers or the new software but when i go from full screen to windows screen the picture is like white...like its been white washed...any thoughts
Nrmf is offline
Old 06-26-2005, 12:37 PM
navarros's Avatar
After properly mounting the daughter DVI card (I had to press really hard) I finally solved part of the problems: I do get HD image full screen, but now the image in the small preview screen looks horrible (same as full screen before: very distorted colors). Besides I get a 3" black bar on the left. I tried changing the resolution but can't get the image centered. I am using a 37" Sharp Aquos (LC-37G4U). The panel's native pixel resolution is Wide XGA (1,366-by-768), meaning it scales 720p or 1080i HDTV content to the native resolution. I tried selecting 1,360 by 768 in MyHD, but I still get the 3" black bar on the left.
navarros is offline
Old 06-26-2005, 01:10 PM
I assume that you have checked the "Enable DVI Output" in MyHD Config Panel. Not have this setting checked will shift the image to the right.
Still don't know why the overlay is bad. Try downloading and installing the newly posted V1.65.2E software/driver.
Old 06-26-2005, 01:11 PM
Try resetting the contrast/brightness setting in the graphics card properties.
Old 06-26-2005, 01:22 PM
Nrmf's Avatar
that did nothing i changed them...then set back to default.
Nrmf is offline
Old 06-26-2005, 01:25 PM
Did you change the desktop or Overlay Brightness setting? I can wash out the overlay by setting the ATI card overlay brightness to 100%.
