DVICO Fusion 5 HDTV tuner - Page 37 - AVS Forum | Home Theater Discussions And Reviews
post #1081 of 2932 Old 08-30-2006, 09:26 PM
KAXKID's Avatar
Originally Posted by MikeSM View Post
I was hoping not to have to take it out and take down my wife's system again. :-) Everything else in the house is a laptop or server.
mike
from your earlier symptom list of the non-working system, you need to fix it before the RT will install properly anyhow. do you have another spare HD to do a new windows install in the non-working system so you can rule out a messed up os installation? if that doesn't work, it looks like the mb is broken.
KAXKID is offline
post #1082 of 2932 Old 08-30-2006, 10:26 PM
MikeSM's Avatar
I have full nightly backups going back two months of all the systems in the house (I backup to disk), so I just reformatted the system and reinstalled XP and loaded the nforce chipset drivers, knowing I can bring it back to original state later. Even with the fusion card removed, the yukon ethernet and the 1394 controller hung off the PCI bus fail to install and operate correctly.
This makes me think it's the motherboard, which is hard to believe as it's very fast and works just fine except for this issue. On the off chance it's something windows related, I am now downloading the Suse 10.1 Linux Live DVD. This distribution has drivers for the yukon and the 1394 interface builtin, and so I will attempt to boot this DVD and see if Linux can init and configure the hardware. If it doesn't either, it's a mobo fault. If it works, then I am going to open up a nice bottle of red wine, drink it all down and then send hate mail to MSFT. :-)
If you have any other ideas, please send them along. I have wasted so much time debugging this it's not funny, but I get focused on these things and I will not give up until I understand what is going on.
Mike
MikeSM is online now
post #1083 of 2932 Old 08-31-2006, 05:05 AM
MrZZZZ's Avatar
Originally Posted by tikyle View Post
What Comcast market are you in?
Also if you're splitting your signal w/ your HSI it may hurt the performance of both.
I'm in central NJ. I tried connecting the cable coming into the house directly to the Fusion5. I get exactly the same poor signal strengths as I do when going thru the splitter. I am using a Monster 2ghz splitter.
MrZZZZ is offline
post #1084 of 2932 Old 08-31-2006, 07:49 AM
tikyle's Avatar
Try getting Comcast to boost your signal. When I only had HSI with them they were sending me too strong a signal and the HSI went out of wack. So maybe you're using more bandwidth than they've got you setup for. They actually have to come out and turn it up at the box going into your house.
tikyle is offline
post #1085 of 2932 Old 08-31-2006, 03:53 PM
maxpan's Avatar
Below is my solution to DVICO Fusion 5 Lite (RT) stuttering issues. From
what I've read so far, it will not help everyone, but hopefully will be useful.
System: MB Gigabyte GA-7N400 Pro2 (rev. 2.0), Athlon XP 3200+, X850Pro AGP,
WinXP
I had a card for about a month, and it worked fine before I re-installed XP on a
new SATA drive connected to MB built-in Silicon Image 3512 controller. Since then
everytime there was a disk access I had a ~1sec freeze while viewing QAM
channels. And since my page file was on the same disk, it was unbearable.
I was sure my signal was strong and CPU was never out of %50 load boundaries.
I rebooted to my old IDE drive system and stuttering disappeared, though was
reproducible if I accessed SATA drive. Recording to this drive was out of the
question (and I bought it specifically for this purpose).
After the problem was discovered, I've searched the net and tried every option
possible: disabled most devices in BIOS, plugged Fusion 5 to every possible
PCI slot (btw irq conflict was never an issue), reconfigured WinXP for standard
PC, used all the latest software, drivers, and BIOSes (I went as far as updating
my MB BIOS with a custom version to include SI 3512 4.3.79 BIOS module).
No matter what I did the Fusion tuner was stuttering whenever SATA drive was
accessed.
I don't want to think about how much time I spent trying to resolve this.... Finally
I did something that worked - I switched the access mode for my drive from
UDMA-6 to PIO-4 (using Sililcon Image software) and now all the stuttering is
gone. Completely. It can play live, time-shift, record, you name it... Flawless.
The problem? 20MB/s limitation (or is it 16MB/s?) of PIO-4. Can't go any faster.
It's still fine as a media drive to record and play but noticebly slower as the
system drive (read: forget about 15-sec XP boot times).
I don't know what's the real issue beyond this (DMA conflict?). Hopefully it can
be fixed in DVICO drivers, but in a meanwhile I recommend folks with Silicon
Image based SATA controllers to try this. You can get the software from
Silicon Image website (will not allow me to post a link).
maxpan is offline
post #1086 of 2932 Old 08-31-2006, 04:02 PM
TPeterson's Avatar
Quoted: 236 Post(s)
Liked: 30
Thanks, maxpan, for confirming the SI SATA stuttering problem with the PIO tack. Others have posted on the Forum about stuttering with SATA drives specifically with the SI controller, but yours is the most conclusive that I've seen.
BTW, there are utilities from the HDD vendors to limit the drive to a specific UDMA speed. Did you try using that to see if a slower UDMA access would avoid the stutters/pauses?
TPeterson is offline
post #1087 of 2932 Old 08-31-2006, 04:03 PM
KAXKID's Avatar
WinXP
accessed.
this info should help a lot of users. i'm glad to see that someone else has also found that irq conflict is not an issue.
thanks for the post, i'll bookmark it for future reference.
KAXKID is offline
post #1088 of 2932 Old 08-31-2006, 05:02 PM
maxpan's Avatar
Originally Posted by TPeterson View Post
Thanks, maxpan, for confirming the SI SATA stuttering problem with the PIO tack. (I believe PIO4 is 16 Mbit/s (Mbps) though, about 2 MBps rather than 16) Others have posted on the Forum about stuttering with SATA drives specifically with the SI controller, but yours is the most conclusive that I've seen.
In wikiality PIO-4 is 16.7MB/s, so it's not that bad. Maybe <30% slower in real world
applications for my 300GB Seagate (st3300831as) compared to UDMA6 (access times
stay the same). Certainly enough for all existent media streams used by mortals :-)
My problem is that I wanted to get a silent system with just one HD and now it's
a choice between an extra noise generator and a slower system.
Using SI tool I did try other DMA modes but in terms of stuttering they were no
different from UDMA6, unfortunately. I think SI tool changes modes in HD itself,
so it wouldn't be different from seagate util, and the setting is persistent across
system reboots and shutdowns.
maxpan is offline
post #1089 of 2932 Old 08-31-2006, 05:15 PM
TPeterson's Avatar
Quoted: 236 Post(s)
Liked: 30
Sorry...brain freeze. Of course PIO is, well, parallel I/O, so it would not be spec'd in bps.
However, I don't think I've ever seen it run at nearly 10 MBps...are you sure you're seeing such rates? I wouldn't expect such a rate to slow WinXP loads inordinately. ATSC TS bit rates are never over 2 MBps, so you're right that PIO is able to keep up. It's really just that the CPU overhead is usually unacceptable.
post #1090 of 2932 Old 08-31-2006, 09:28 PM
beowulf7's Avatar
Good post, although it's not relevant for me (yet) since I don't have a TV tuner in my computer, let alone DVICO's HDTV tuner.
FYI, I don't think you're allowed to post links until you have 10 or 20 posts (something like that). However, you can bypass that by putting a space before or after the "." in the URL. For example: http :// www . avsforum . com. Most people will know to remove the spaces within the URL.
Procrastination is the thief of time.
-- Edward Young
They that give up essential liberty to obtain a little
temporary safety deserve neither liberty or safety.
-- Benjamin Franklin
You shouldn't mix meditation with management.
The mind gets too empty.
-- Scott Adams, "Dilbert"
beowulf7 is offline
post #1091 of 2932 Old 09-01-2006, 05:57 AM
FranksPlace2's Avatar
tikyle,
Thanks for the suggestion. My PQ (Analog & Dogital) seems random and have been trying to dcide what to do. I didn't know it was controlled locally.
Frank
FranksPlace2 is offline
post #1092 of 2932 Old 09-02-2006, 08:53 AM
obeewaan's Avatar
WinXP
channels.
Maxpan, Thank you verymuch for your great research !!!
I have Asus K8VSE with Athlon 64XP3200, 1 GB RAM and Geforce FX 5900 (128MB).
I am about to add 2 SATA 150 MB/s drives to my PC for storage.
I looked in Asus manual and VIA website (K8T800 chipset) but no avail about the info of my SATA 150 controller.(whether its a Silicon Image controller )
How can I findout this info ?
Also, how do I switch access mode of SATA? in BIOS?
thanks
_________________________
Athlon 64 3200, ASUS K8VSE, 1 GB RAM, 400 GB SATA, GeForce 5900 FX , Turtlebeach Montego , Fusion 5 GOLD RT, XP Pro SP2 ,Sil_stone LC17S, GV 42L
obeewaan is offline
post #1093 of 2932 Old 09-02-2006, 09:36 PM
maxpan's Avatar
Quickly checked: you have one built in your south bridge, and maybe another one
on a Promise chipset, so no need to worry. Info should be in your MB manual.
thanks
If you wish to switch, most HDD manufactures provide utilities (normally put
on a bootable floppy disk). I, however, used the utility made by my controller
manafacture (not sure if others provide the same though).
maxpan is offline
post #1094 of 2932 Old 09-03-2006, 07:19 AM
poster's Avatar
Quoted: 21 Post(s)
Liked: 27
Does the FusionHDTV5 USB Gold work with satellite(Dish Network) or is it just for digital cable. I just want to be able to save some TV programs(sports, other shows) to my hard drive in HDTV. Is this tuner a good option for me. I haven't seen too many that capture HDTV. Thanks for any help anyone can provide this noob!
poster is offline
post #1095 of 2932 Old 09-03-2006, 11:01 AM
TPeterson's Avatar
Quoted: 236 Post(s)
Liked: 30
poster--
No. All of the standard PC tuner widgets are for OTA and a few, such as the FusionHDTV ones, also handle cable clear QAM. For satellite, you need to use the providers' hardware (or some sort of bootleg device that can't be talked about in this forum and about which I know nothing specific).
post #1096 of 2932 Old 09-03-2006, 11:43 AM
poster's Avatar
Quoted: 21 Post(s)
Liked: 27
poster--
Thanks for the reply. Is satellite not considered OTA? I guess I dont get the difference between digital cable and satellite in that respect. I don't want to do anything shady to get this to work, is there any other options for satellite users that are looking to do what I am trying to do?
poster is offline
post #1097 of 2932 Old 09-03-2006, 12:14 PM
TPeterson's Avatar
Quoted: 236 Post(s)
Liked: 30
"OTA" (Over the Air) is synonymous with "broadcast TV", aka "FTA" (Free to Air) which is not satellite or cable.
post #1098 of 2932 Old 09-03-2006, 04:15 PM
poster's Avatar
Quoted: 21 Post(s)
Liked: 27
Thanks TPeterson for the help. I have been reading up and it makes sense to me now. I guess I just have to buy one of these TV tuners knowing that they will not work in capturing HD from satellite. Take care!
poster is offline
post #1099 of 2932 Old 09-04-2006, 06:59 PM
arcticool's Avatar
Kaxkid-
Thanks for the setup tips, working fine now.
Maxpan-
Good job troubleshooting, hopefully that will help some folks with the stutter issue. I still think the drivers have some issues with IRQs though, since randomly swapping cards around several times eventually fixed it for me.
BTW, has anyone gotten a Remote Wonder working with this card? Maybe I should start a seperate thread and bump it every few weeks...
AC
arcticool is offline
post #1100 of 2932 Old 09-04-2006, 07:21 PM
replay_boy's Avatar
This may be a dumb question but if I am using Windows Media Center and recording cable shows, can I add the Fusion 5 to the media center and record OTA High-Def? Basically, does Windows Media Center allow me to have a cable channel line-up and a OTA channel line-up as well?
My Replay could handle this. (but not high-def)
Replay_Boy
replay_boy is offline
post #1101 of 2932 Old 09-04-2006, 09:19 PM
Bruce Embry's Avatar
Quoted: 13 Post(s)
Replay_Boy
YES!!!!
Bruce.in.Triangle NC
Firewire is alive and kicking!
Bruce Embry is offline
post #1102 of 2932 Old 09-05-2006, 12:53 AM
videojanitor's Avatar
Hi folks! This is my first post in this particular thread. I picked up a FusionHDTV5 USB Gold a few weeks ago -- the thing works, but I find that it becomes very unstable with 1080i material.
As an example, if I engage the "time-shifting" mode while watching a 1080i station, the window goes to black and that's all she wrote. If I try to change the channel, all I get is an "Overlay Not Available" message. The only way to clear it is to exit the program and re-launch it. I can RECORD a 1080i program then play the file later with no problems, though the program seems very touchy -- if I so much as press a key on the keyboard, it will hang and has to be dumped from the Task Manager.
Just wondering if this might be a sign that my video card is not quite up to the task? I have an nVidia GeForce FX5200, which as near as I can tell, is on the list of cards that should work. The PC is a Dell P4, 2.8GHz, 1GB RAM and two Seagate 160GB SATA drives.
No issues at all with 720p stations. Anything to point me in the right direction would be appreciated!
videojanitor is offline
post #1103 of 2932 Old 09-05-2006, 01:27 AM
TPeterson's Avatar
Quoted: 236 Post(s)
Liked: 30
The issue seems to be video-driver related. Are you using DxVA mode or sw mode? Your machine actually should do OK with sw mode, so I'd give that a try.
Otherwise, you could try reinstalling either the same nVidia driver or a newer/older one to see if that might play better with FusionHDTV.
Also, if you have dual monitors, try disabling that in the driver to see if the problems are related to the multimonitor configuration.
post #1104 of 2932 Old 09-05-2006, 01:55 AM
Thanks for the quick reply. I'll admit to being a bit dumb about this -- how do I know which mode I am using? Are you referring to the "Decoder Option" in the "video configuration" screen? If so, I have that set to "Zulu HDTV Decoder." If I select the "Zulu HDTV (DvXA) Decoder" mode, then I can't see 1080i content at ALL. Just black.
I only have one monitor, connected via DVI, so that eliminates the possible dual-monitor problem. I'll give your driver re-install/update/downgrade suggestion a try.
post #1105 of 2932 Old 09-05-2006, 08:06 AM
TPeterson's Avatar
Quoted: 236 Post(s)
Liked: 30
Yes, that's the setting I meant. Another thing to check is the AGP aperture in your PC's BIOS. That should be set to at least as big as the DRAM size of your FX5200.
post #1106 of 2932 Old 09-05-2006, 01:56 PM
I checked it, and it's set to 128MB, which matches what is on the card. Is there any advantage to setting it to 256MB?
Also, I installed the latest nVidia driver -- it seems to be somewhat more stable, but still just goes to black if I click the "time-shifting" icon while viewing 1080i. It doesn't seem to crash though. I can now stop it and change the channel to get video back.
post #1107 of 2932 Old 09-05-2006, 02:18 PM
TPeterson's Avatar
Quoted: 236 Post(s)
Liked: 30
I doubt that there's any but, hey, it wouldn't hurt to try it to see what happens.
Glad to hear that you've eliminated the crashing problem anyway. Does DxVA mode still not work either?
post #1108 of 2932 Old 09-05-2006, 02:21 PM
Gotta run off to work right now, but I'll try changing that later tonight. As for the DxVA mode -- correct, I still get nothing at all at 1080i.
post #1109 of 2932 Old 09-05-2006, 05:43 PM
SpokaneDoug's Avatar
Originally Posted by videojanitor View Post
... all I get is an "Overlay Not Available" message. The only way to clear it is to exit the program and re-launch it.
I had a bunch of "Overlay Not Available" problems when I first got the FusionHDTV RT Gold -- they went away when I switched to a bigger video card. (Then I had insufficient power problems, but that's another story!)
Doug
SpokaneDoug is offline
post #1110 of 2932 Old 09-05-2006, 09:14 PM
TPeterson's Avatar
Quoted: 236 Post(s)
Liked: 30
Doug, I had a similar thought, which was why I suggested disabling dual monitor mode. But 128 MB for a single monitor should be enough to handle 1080i overlays. (In fact, I have no such problem with a 64-MB MX-440, IIRC)
Reply Home Theater Computers
