PlayList_Manager & Record_This - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 2804 Old 03-12-2006, 05:08 PM
Cris Moore's Avatar
Originally Posted by jldet5 View Post
I'm able to schedule with Titan. That should mean the file is fine?
True. If you can schedule with Titan but RT gives you a conflict for the same reservation then it must have something to do with RT's schedule conflict code, unless a schedule from Titan automatically overwrite entries for the Fusion?
Cris Moore is offline
post #452 of 2804 Old 03-12-2006, 05:12 PM
Cris Moore's Avatar
If anybody is interested I'll post it but if not, no problem.
I'm always willing to look at your latest build. Post away.
post #453 of 2804 Old 03-12-2006, 05:17 PM
jldet5's Avatar
Looks like I need a new version!
jldet5 is offline
post #454 of 2804 Old 03-12-2006, 05:29 PM - Thread Starter
AllenDB's Avatar
As soon as you said Grey's Anatomy I tried it. Didn't schedule. Hmmmmm there were some conflicts with Seinfeld but it should have worked.
AllenDB is offline
post #455 of 2804 Old 03-12-2006, 05:34 PM
Cris Moore's Avatar
I can't schedule it either! Is the show name causing problems because it has an apostrophe in it?
Edit: It could still be the name (Allens' routine for adding it to the DB) but I was able to manually add it directly to the DB.
post #456 of 2804 Old 03-12-2006, 05:43 PM - Thread Starter
AllenDB's Avatar
I'm thinking that I need to find and fix this problem before I move on. My bad on the error message. When it says conflcit on a Fusion card it really means a DB access error. I said conflict because during testing thats what usually happened. It now will say DB access error.
I did schedule it on MYHD. Hmmmmm
AllenDB is offline
post #457 of 2804 Old 03-12-2006, 05:53 PM
jldet5's Avatar
Same problem with America's Next Top Model. Perhaps it is the ' as Cris suggested?
jldet5 is offline
post #458 of 2804 Old 03-12-2006, 05:59 PM - Thread Starter
AllenDB's Avatar
This is a monumental go figure. Took out the apostrophe and it worked. Do I just take it out or replace it with a semicolon?
AllenDB is offline
post #459 of 2804 Old 03-12-2006, 06:01 PM
Cris Moore's Avatar
I vote for just taking it out.
post #460 of 2804 Old 03-12-2006, 06:02 PM
jldet5's Avatar
Ditto.
jldet5 is offline
post #461 of 2804 Old 03-12-2006, 06:07 PM - Thread Starter
AllenDB's Avatar
Ditto.
History and I'll post the 'new' beta. It doesn't have any Dont Care logic just the revamped tables in preparation. And conflict and priority stuff.
AllenDB is offline
post #462 of 2804 Old 03-12-2006, 06:26 PM - Thread Starter
AllenDB's Avatar
Beta, beta.
Log file name changed to Record_This_Log.txt
Record_This.txt 74.611328125k . file
AllenDB is offline
post #463 of 2804 Old 03-12-2006, 06:53 PM
jldet5's Avatar
Beta, beta.
Thanks Allen! Running great!
jldet5 is offline
post #464 of 2804 Old 03-14-2006, 07:45 AM
kdtjlamb's Avatar
I couldnt tell if PLM would auto update it's ini file with new folders that were created with the MYHD scheduled recording app... so I banged out a script that does what I need it to do... feel free to use if you want
This script is something that I created to compliment the PLM application.
It will parse through your top level recording directories append any
subdirectories to the bottom of the PLM.ini file. If you record your shows
into folders (folders named as the title of the show), then you might like this.
You will no longer need to go and manually update your MYHD_Params.ini to
scan the sub folders.... Each time the script is ran, it generates a new
MYHD_Params.ini file and populates the bottom of the ini file with the latest
folder information. It then calls the PLM.exe application to execute.
To use the script:
DISCLAIMER:
MAKE A BACKUP COPY OF THE 'MYHD_Params.ini' file. THIS SCRIPT WILL
MANIPULATE THE 'MYHD_Params.ini' FILE EACH TIME IT IS RUN. PLEASE KEEP
A COPY OF YOUR ORIGINAL IN CASE YOU WANT TO RESTORE TO YOUR
ORIGINAL FILE.
1. Place this script in the same directory as your PLM application:
2. Edit your MYHD_Params.ini and remove your record folders
at the bottom of the file. Save and close the MYHD_Params.ini.
3. Rename MYHD_Params.ini to MYHD_Params.default
4. In the 'CONFIG DVR FOLDERS HERE' section (above), enter your DVR top level
recording directories. Multiple directories can be listed. Example of Syntax:
Set DVRDirectories="D:" "C:\\DVR Recordings" "\\\\Server\\Share\\"
5. Save the script and set it to run at a scheduled time.
Download the script and remove the '.txt. extention, the script is called PLM_GO.cmd
PLM_GO.cmd.txt 2.7060546875k . file
kdtjlamb is offline
post #465 of 2804 Old 03-14-2006, 03:10 PM
jldet5's Avatar
OH OH,
Not sure what happend yet but all of my recordings are recording the wrong channel.
jldet5 is offline
post #466 of 2804 Old 03-14-2006, 04:47 PM - Thread Starter
AllenDB's Avatar
OH OH,
Is that since you started using the beta or the beta has been working but something went south today?
Allen
AllenDB is offline
post #467 of 2804 Old 03-14-2006, 04:58 PM
jldet5's Avatar
Allen
Been doing some testing. The Beta is broken.
jldet5 is offline
post #468 of 2804 Old 03-14-2006, 05:02 PM - Thread Starter
AllenDB's Avatar
Concerning the apostrophe problem, want a previous version with the fix in?
Mind sending or posting a log from the beta?
Thanks, Allen
AllenDB is offline
post #469 of 2804 Old 03-14-2006, 05:06 PM
jldet5's Avatar
Thanks, Allen
Thanks but I can work around the apostrophe problem.
The log looks fine. Its what is being written to the database. I can send you the database and log?
jldet5 is offline
post #470 of 2804 Old 03-14-2006, 07:50 PM
Cris Moore's Avatar
jldet5 is correct. The log file indicates the correct program number but RT is back to putting 0001 in for the program number again.
jldet5,
Is it just the Fusion recordings that are messed up or are the MyHD ones messed up too?
post #471 of 2804 Old 03-14-2006, 07:59 PM - Thread Starter
AllenDB's Avatar
Yeah, that darn Fusion Program Number again. This should/better fix it.
AllenDB is offline
post #472 of 2804 Old 03-14-2006, 08:11 PM
jldet5's Avatar
jldet5,
It was just the Fusion but I only ran one test on the MYHD.
jldet5 is offline
post #473 of 2804 Old 03-14-2006, 08:11 PM
Cris Moore's Avatar
Getting the correct program number now. Lots of new "info" in the LOG file. Is this basically debug info until the next official release?
post #474 of 2804 Old 03-14-2006, 08:16 PM - Thread Starter
AllenDB's Avatar
No, I'll get it out now thats it OK. Wasn't 100% sure.
Hit the wrong key, here it is.
AllenDB is offline
post #475 of 2804 Old 03-16-2006, 10:27 PM - Thread Starter
AllenDB's Avatar
First DontCare beta. No documentation yet. But to use the feature just define the programs you don't care about before any card definition. RT will put as many programs possible on the first defined card and any conflicts spill over to the second defined card and so on. Did some testing and it looks like I still have a bit of work to do with ER.
ER starts a minute or two BEFORE the hour. I try and handle programs that run over like ABC but not ones that start early. I borrowed Tim's feature where programs can be trimmed. But this would only be needed if space for the oddball reservation cannot be found on any card. Then two new options come into play TrimBegin and TrimEnd. TrimBegin delays the beginning of a program by the minutes of overrun. TrimEnd clips the overrun minutes of the offending program to the hour. Options can be specified globally or in the program entry.
If those options don't exist a normal conflict occurs and program preference comes into play. The programs are ranked by the sequnce of definition. The latter ones being higher in conflict resolution.
I'm outta town for a few days. Hope most/some of it works.
AllenDB is offline
post #476 of 2804 Old 03-16-2006, 11:17 PM
Cris Moore's Avatar
Thanks Allen!
post #477 of 2804 Old 03-17-2006, 03:30 PM
rathwine's Avatar
I am including a small portion of the output from record this.
I am unable to get the list of channes for my fusion card. Maybe someone could help me find out why. Thanks, Troy.
03/17/06 17:28:10 Get_Next_Record: >> xmlfilename c:\\program files\\xmltv-0.5.42-win32\\oneday.xml
03/17/06 17:28:10 Get_Next_Record: <<>> showxml
03/17/06 17:28:10 Get_Next_Record: <<>> scheduleconflicts
03/17/06 17:28:10 Get_Next_Record: >> FusionVersion 3.3
03/17/06 17:28:10 Get_Next_Record: >> DBPath c:\\Program files\\Dvico\\FusionHDTV\\Epg2Lst.mdb
03/17/06 17:28:10 Get_Next_Record: >> Showsubchannels
03/17/06 17:28:10 Get_Next_Record: >> filenamestyle chnumber_date_title
03/17/06 17:28:10 Get_Next_Record: >> directorystyle none
03/17/06 17:28:10 Get_Next_Record: >> showoldschedule
03/17/06 17:28:10 Get_Next_Record: >> showaddedschedule
03/17/06 17:28:10 Get_Next_Record: >> showallprograms
03/17/06 17:28:10 Get_Next_Record: <<>> today
03/17/06 17:28:10 Get_Next_Record: >> tomorrow
03/17/06 17:28:10 Get_Next_Record: >> showallchannels
03/17/06 17:28:10 Get_Next_Record: <<>> reruns
03/17/06 17:28:10 Get_Next_Record: <<>> notseen
03/17/06 17:28:10 Get_Next_Record: <<>> timeoffset -8
03/17/06 17:28:10 Get_Next_Record: >> channel xyz 207 5 1
03/17/06 17:28:10 Get_Next_Record: >> channel lala 198 11 1
03/17/06 17:28:10 Get_Next_Record: >> local MYHD ant1
03/17/06 17:28:10 Get_Next_Record: >> reruns
03/17/06 17:28:10 Get_Next_Record: csi: miami [20:00-24:00]
03/17/06 17:28:10 Get_Next_Record: >> Reruns off
03/17/06 17:28:10 Get_Next_Record: csi: crime scene investigation [20:00-24:00]
03/17/06 17:28:10 Get_Next_Record: charmed
03/17/06 17:28:10 Get_Next_Record: smallville [20:00-24:00]
03/17/06 17:28:10 Get_Next_Record: house [20:00-24:00]
03/17/06 17:28:10 Get_Next_Record: threshold [20:00-24:00]
03/17/06 17:28:10 Get_Next_Record: lost [20:00-24:00]
03/17/06 17:28:10 Get_Next_Record: numb3rs
03/17/06 17:28:10 Get_Next_Record: in justice [20:00-24:00]
03/17/06 17:28:10 Get_Next_Record: supernatural
03/17/06 17:28:10 Get_Next_Record: some programs off this cable
03/17/06 17:28:10 Get_Next_Record: <<>> local fusion
03/17/06 17:28:10 Get_Next_Record: <<>> remote formyhd myhd
03/17/06 17:28:10 Record_This: Run date/time 2006/03/17 17:28:10
03/17/06 17:28:10 Record_This: Recording date 2006/03/18
03/17/06 17:28:10 Dump_All_Sub_Channels: QueryValue failed 0 Length 15000 Key AirRF207SubChannels
03/17/06 17:28:10 Dump_All_Sub_Channels: QueryValue failed 2 Length 15000 Key AirRF198SubChannels
03/17/06 17:28:10 Store_channel: Channels 0 Int I21655.labs.zap2it.com Ext WJXTDT Virtual 4 Physical 42
03/17/06 17:28:10 Store_channel: Channels 1 Int I25029.labs.zap2it.com Ext WTLVDT Virtual 12 Physical 13
03/17/06 17:28:10 Store_channel: Channels 2 Int I25030.labs.zap2it.com Ext WTLVDT2 Virtual 12 Physical 13
03/17/06 17:28:10 Store_channel: Channels 3 Int I31070.labs.zap2it.com Ext WJWBDT Virtual 17 Physical 34
rathwine is offline
post #478 of 2804 Old 03-17-2006, 03:35 PM
Cris Moore's Avatar
This line is incorrect. It should be:
DBPath c:\\Program files\\Dvico\\FusionHDTV\\Epg2List.mdb
Allen, get that INI file updated with the correct path!
Here is my Record_This.ini file using the new "Don't Care" feature:
<< - debug info
<<>> showallchannels
<<>> showsubchannels
<<>> showallprograms
<<>> shownotseen
<<>> showwatchprograms
<<>> showcardinfo
>> xmlfilename c:\\HDTV_Tools\\XMLTV\\xmltv-0.5.42-win32\\epg.xml
>> DBPath C:\\Program Files\\DVICO\\FusionHDTV\\Epg2List.mdb
>> directorystyle title
>> filenamestyle chname_date_title
>> showaddedschedule
>> showsubtitle
>> showdescription
>> today
>> clear
>> excludechannels
<< - OTA main channels
>> channel KOPBDT 27 10 1 OTA
>> channel KPTVDT 30 12 1 OTA
>> channel KWBPDT 33 32 1 OTA
>> channel KOINDT 40 6 1 OTA
>> channel KATUDT 43 2 1 OTA
>> channel KGWDT 46 8 1 OTA
>> channel KPDXDT 48 49 1 OTA
<< - OTA sub channels
<<>> channel KOPBDT2 27 10 2 OTA
<<>> channel KOINDT2 40 6 2 OTA
<<>> channel KOINDT3 40 6 3 OTA
<<>> channel KGWDT2 46 8 2 OTA
Surface
Medium
CSI: Miami
Bones
Veronica Mars
CSI: NY
Smallville
Supernatural
CSI: Crime Scene Investigation
Ghost Whisperer
Charmed
Tim Janis: Coastal America
>> local MYHD ant1
>> local Fusion
>> FusionVersion 3.3
Nova [notseen]
Innovation [notseen]
Nature [notseen]
post #479 of 2804 Old 03-18-2006, 06:13 AM
jldet5's Avatar
The INI file was fixed in the 3/3 version. There is still a bad reference in the ini but the first DBPATH looks to be correct.
jldet5 is offline
post #480 of 2804 Old 03-18-2006, 11:21 AM
Cris Moore's Avatar
I have >> showaddedschedule, >> showsubtitle, and >> showdescription enabled.
It seems that if a show is skipped (time passed) then subsequent showings will not show title, subtitle, or description either, although they will be scheduled properly.
Record_This: **********************************************************
Get_Next_Record: << - debug info
Get_Next_Record: <<>> showallchannels
Get_Next_Record: <<>> showsubchannels
Get_Next_Record: <<>> showallprograms
Get_Next_Record: <<>> shownotseen
Get_Next_Record: <<>> showwatchprograms
Get_Next_Record: <<>> showcardinfo
Get_Next_Record: <<
Get_Next_Record: >> xmlfilename c:\\HDTV_Tools\\XMLTV\\xmltv-0.5.42-win32\\epg.xml
Get_Next_Record: >> DBPath C:\\Program Files\\DVICO\\FusionHDTV\\Epg2List.mdb
Get_Next_Record: >> directorystyle title
Get_Next_Record: >> filenamestyle chname_date_title
Get_Next_Record: >> showsubtitle
Get_Next_Record: >> showdescription
Get_Next_Record: >> today
Get_Next_Record: >> clear
Get_Next_Record: <<
Get_Next_Record: >> excludechannels
Get_Next_Record: <<
Get_Next_Record: << - OTA main channels
Get_Next_Record: >> channel KOPBDT 27 10 1 OTA
Get_Next_Record: >> channel KPTVDT 30 12 1 OTA
Get_Next_Record: >> channel KWBPDT 33 32 1 OTA
Get_Next_Record: >> channel KOINDT 40 6 1 OTA
Get_Next_Record: >> channel KATUDT 43 2 1 OTA
Get_Next_Record: >> channel KGWDT 46 8 1 OTA
Get_Next_Record: >> channel KPDXDT 48 49 1 OTA
Get_Next_Record: <<
Get_Next_Record: << - OTA sub channels
Get_Next_Record: <<>> channel KOPBDT2 27 10 2 OTA
Get_Next_Record: <<>> channel KOINDT2 40 6 2 OTA
Get_Next_Record: <<>> channel KOINDT3 40 6 3 OTA
Get_Next_Record: <<>> channel KGWDT2 46 8 2 OTA
Get_Next_Record: <<
Get_Next_Record: Surface
Get_Next_Record: Medium
Get_Next_Record: CSI: Miami
Get_Next_Record: Bones
Get_Next_Record: Veronica Mars
Get_Next_Record: CSI: NY
Get_Next_Record: Smallville [reruns]
Get_Next_Record: Supernatural
Get_Next_Record: CSI: Crime Scene Investigation
Get_Next_Record: Ghost Whisperer
Get_Next_Record: Charmed
Get_Next_Record: >> local Fusion
Get_Next_Record: Nova [notseen]
Get_Next_Record: Innovation [notseen]
Get_Next_Record: Nature [notseen]
Get_Next_Record:
Get_Next_Record:
Get_Next_Record:
Get_Next_Record:
Record_This: Run date/time 2006/03/18 10:13:49
Check_Program: >>>>>>>>>>>>>>>>>>>> Skipping because start time passed Nature on PBS/KOPBDT 3/18 7:00 till 8:00
Check_Program: >>>>>>>>>>>>>>>>>>>> Skipping rerun Veronica Mars on UPN/KPDXDT 3/18 16:00 till 17:00
Check_Program: >>>>>>>>>>>>>>>>>>>> Skipping rerun CSI: Crime Scene Investigation on UPN/KPDXDT 3/18 20:00 till 21:00
Check_Program: >>>>>>>>>>>>>>>>>>>> Scheduling a rerun Smallville on WB/KWBPDT 3/18 17:00 till 18:00
Check_Program: Magnetic
Check_Program: A rebellious Lana lands in jail after she becomes attracted to a fellow student (Kevin Zegers); Clark discovers that Lana's new friend has magnetic powers that can move objects and alter emotions.
Assign_Reservations: Program 0 17:00 18:00 Smallville
Insert_Here: Program 0 on local MYHD
MYHD_Reservation: Input 0 PhyCh 33 VirCh 32 SubCh 1 DateMode 0
MYHD_Reservation: 2006/03/18 start 17:00 stop 18:00 Week 40 FileType 2 TunerInputMode 1
MYHD_Reservation: DefaultfileName 1 FileName D:\\Recordings\\MyHD\\Smallville\\KWBPDT-0318-Smallville.tp FileNameStyle 9
MYHD_Reservation: DirStyle 6 ChNum ChName KWBPDT title Smallville
Fusion_Reservation: PhyCh 27 VirCh 10 SubCh 1 ProgNum 3 2006/03/18 start 11:00 stop 12:00
Fusion_Reservation: ChName KOPBDT title Nature FileName D:\\Recordings\\Fusion\\KOPBDT-0318-Nature.tp
Fusion_Reservation: PhyCh 27 VirCh 10 SubCh 1 ProgNum 3 2006/03/18 start 12:00 stop 13:00
Record_This: Not Seen file has 2 entries
Done
Reply Home Theater Computers
