PlayList_Manager & Record_This - Page 93 - AVS Forum
post #2761 of 2788 Old 03-30-2010, 05:04 PM
DPlettner's Avatar
If you give it a try, 802.11n on the 5GHz band works better than 802.11n on the 2.4GHz band, since the 5GHz band is reserved for WiFi, and other devices can use 2.4GHz.
I have also read that many people have good luck with powerline networking.
-Dave
DPlettner is offline
post #2762 of 2788 Old 03-31-2010, 08:19 AM - Thread Starter
AllenDB's Avatar
I'll post my results. Might be in a month or two tho.
Gonna be in Santa Barbara and Orange Country for a few days in April and then were off on another cruise.
AllenDB is offline
post #2763 of 2788 Old 07-30-2010, 01:26 PM - Thread Starter
AllenDB's Avatar
Kinda reactivate the thread in case there are questions.
Post #1 updated with the latest RT.
AllenDB is offline
post #2764 of 2788 Old 07-30-2010, 01:44 PM
DPlettner's Avatar
Allen has updated RT to be compatible with CW_EPG.
For existing RT users
All reservations can go through the CWHelper portion of CW_EPG. This eliminates the need for RT_Helper on remote PCs. Also, CWHelper handles HDHR recordings, so you no longer need HDHRCorder. Finally, CWHelper provides persistence, so HDHR and Fusion recordings interrupted by a power interruption or BSOD/reboot will resume. Also, if you boot up your PC after a reservation was scheduled to start, the recording will be started by CWHelper. Note that the MyHD application already had this functionality.
For new RT users
CW_EPG has a nice installer, so it simplifies the initial RT configuration since you do not need to manually configure HDHRCorder and RT_Helper.
For existing CW_EPG users
RT provides an easy way to insert manual reservations into CW_EPG. RT also has a few more specialized scheduling options, such as joining back-to-back programs on the same channel into a single reservation, or the ability to add additional padding to a program if a different trigger program aired earlier in the day (which works well for certain live events that delays schedules).
-Dave
post #2765 of 2788 Old 07-30-2010, 10:25 PM
KAXKID's Avatar
-Dave
ok, i was able to get the new rt+cwepg to work using hdhr and ota but something is not quite there for qam... what am i missing???
see rt log below:
07/31/10 00:11:31 Record_This: ************************************************************
07/31/10 00:11:31 Record_This: Compile date/time Jul 28 2010 11:14:29
07/31/10 00:11:31 Record_This: Ini filename Record_This.ini
07/31/10 00:11:31 Get_Next_Record: >> ChannelTable HDHRota0
07/31/10 00:11:31 Get_Next_Record: >> Channel wjctdt 70 0 1 qam256
07/31/10 00:11:31 Get_Next_Record: test_Movie [at 00:15-00:17 on wjctdt date 07/31/2010]
07/31/10 00:11:31 Get_Next_Record: >> local HDHR [DeviceId 10161ADA tuner 0 Folder "c:\\hdtv" Identifier HDHRota0 CWHDHR 8181]
07/31/10 00:11:31 Record_This: Run date/time 2010/07/31 0:11:31 DST 1
07/31/10 00:11:31 Record_This: Recording date 2010/07/31
07/31/10 00:11:31 HDHR_Parse_Message: HTTP/1.0 200 OK
07/31/10 00:11:31 Store_Dont_Care: >>>>>>>>>>>>>>>>>>>> Inserting manual reservation for test_Movie on 7/31/2010 at 0:15-0:17 channel wjctdt
07/31/10 00:11:31 List_Scheduled: Program 0 wjctdt 0:15- 0:17 7/31 0 test_Movie
07/31/10 00:11:31 Insert_Here: Program 0 on local HDHR tuner 0(0)
07/31/10 00:11:31 Schedule_Using_CWHDHR: CWHelper call capture?channelname=70.1&datetime=7/31/2010 0:15&datetimeend=7/31/2010 0:17&tuner=10161ADA-0&filename=c:\\hdtv\ est_Movie.tp&protocol=qam&title=test_Movie
CW_EPG Helper Interface
Not able to schedule capture for 70.1 Slot: start [07/31/10 00:15:00] stop [07/31/10 00:16:59]
Sat Jul 31 00:11:31 EDT 2010 ERROR - capture was not defined.
channel 70.1 qam not found on 10142327-0 lineup.
channel 70.1 qam not found on 10142327-1 lineup.
channel 70.1 qam not found on 10161ADA-0 lineup.
channel 70.1 qam not found on 10161ADA-1 lineup.
channel 70.1 qam not found on HDTV3Silver+/3Gold.3 lineup.
channel 70.1 qam not found on MYHD lineup.
getAvailableCapturesForChannelNameAndSlot returned no captures for 70.1 10161ADA-0 Slot: start [07/31/10 00:15:00] stop [07/31/10 00:16:59]
Done
looks like rt does not like my channel definition for some reason.
here's a partial dump of my channels :
steve
KAXKID is offline
post #2766 of 2788 Old 07-30-2010, 10:55 PM
TPeterson's Avatar
Quoted: 78 Post(s)
Steve, your protocol needs to be "QAM256" in the captures for HDHR and Fusion. It is "QAM" only for MyHD captures. (Thanks to Dave P. for reminding me of that)
TPeterson is offline
post #2767 of 2788 Old 07-30-2010, 10:56 PM
DPlettner's Avatar
Steve,
You found the last issue that I know about.
If you look at the request, RT is sending "protocol=qam" to CWHelper. Originally, RT was sending "protocol=qam256".
During testing I asked Allen to make the change because MyHD reservations were broken. It turns out that this varies by tuner, and Fusion and HDHR want "protocol=qam256", and MyHD wants "protocol=qam". My request fixed MyHD, but broke Fusion and HDHR.
I expect that Allen will probably fix this pretty quickly.
-Dave
Edit: Terry beat me by a minute.
post #2768 of 2788 Old 07-30-2010, 10:59 PM
KAXKID's Avatar
-Dave
i wonder what an rt scheduled event for the hdpvr would look like in cwepg...
steve
KAXKID is offline
post #2769 of 2788 Old 07-30-2010, 11:02 PM
DPlettner's Avatar
I doubt you would see anything, since those reservations do not go through CWHelper, and CW_EPG and CWHelper know nothing about HD PVRs.
By the way, do you really get all those HBO channels in clear QAM?
-Dave
post #2770 of 2788 Old 07-30-2010, 11:08 PM
KAXKID's Avatar
Steve,
-Dave
ok, i tried qam and qam256 and even qam64 (upper and lower case too) before posting. i thought that was already fixed from reading earlier messages...
steve
KAXKID is offline
post #2771 of 2788 Old 07-30-2010, 11:18 PM
KAXKID's Avatar
-Dave
eh... no those are "fake" channels i added to one of my hdhr tuners so i could see what's on hbo. i also added a few of the "fake" hd channels after comcast encrypted some of my analogs, i watch. the hdhr does capture zero byte files when it matches shows i want.
i really use the info from the auto email to see what i have to watch live or set the hdpvr to capture.
steve
KAXKID is offline
post #2772 of 2788 Old 07-31-2010, 12:46 PM - Thread Starter
AllenDB's Avatar
My bad, I thought that tweak was in MYHD code only. Try this one.
Record_This.zip 241.2890625k . file
AllenDB is offline
post #2773 of 2788 Old 07-31-2010, 02:47 PM
KAXKID's Avatar
ok, this works for hdhr qam and 8svb. i didn't check fusion or myhd.
i do seem to have a problem when defining more than one hdhr tuner at the same time.
for example, one hdhr tuner on qam has its own channel table and another hdhr tuner is connected ota has a different channel map. if scheduling two captures, one on each tuner, i get an error, but if i comment out the capture and program statement individually, i can capture both.
see attached rt log and ini:
Record_This_Log.txt 9.5146484375k . file
Record_This ini.txt 0.4169921875k . file
File Type: txt Record_This ini.txt (427 Bytes, 11 views)
KAXKID is offline
post #2774 of 2788 Old 07-31-2010, 03:12 PM
DPlettner's Avatar
I am not sure if this is the issue, and I don't think it explains your success. However, I think the correct usage of the channel tables and manual scheduling is to define the station call letters and the network. For example:
>> Channel KTVUDT/FOX 79 2 2 1 CABD
then refer to the network in the manual reservation:
Test_Recording [at 18:30-18:35 on FOX every A]
IIRC, it was done this way because some users lived between large cities and could get the same network from multiple sources, and this configuration provided additional scheduling flexibility.
I don't think the text you pick matters, so try defining a channel for something like KXYZDT/ABC, and then schedule to ABC.
-Dave
post #2775 of 2788 Old 07-31-2010, 03:46 PM
KAXKID's Avatar
-Dave
still the same error.
i think i found the problem. it is the way i have my ini constructed. i guess i should have read all the documentation.
here's the info:
<< The general format
<< of an ini file is to define the options, list the programs to be recorded and
<< then the card(s). Programs listed after a card will be recorded on that card.
<< Programs listed before all cards will be recorded and the first available card in
<< the card list based on an available time slot. A simple ini looks like:
<< >> Option entry
<< >> Option entry
<< Program1
<< Program2
<< >> Card entry
<< >> Card entry
so, reconstructing my ini seems to have fixed the problem.
my new ini and the resulting rt log:
steve
Record_This ini2.txt 0.4208984375k . file
File Type: txt Record_This ini2.txt (431 Bytes, 6 views)
KAXKID is offline
post #2776 of 2788 Old 07-31-2010, 04:17 PM
DPlettner's Avatar
(Edit: Looks like you figured it out while I was composing this, but I figured I would post it anyway after spending time writing it.)
One more thing to try. Put all your channel table statements at the top. It is possible that RT needs to read in all the channel table statements before scheduling. Then list all your shows, and then all tuners.
According to the documentation:
Programs listed after a card will be recorded on that card. Programs listed before all cards will be recorded on the first available card in the card list based on an available time slot"
That means there are two possible formats. For example:
>> tuner 1
program 1
>> tuner 2
program 2
or
program 1
program 2
>> tuner 1
>> tuner 2
I think you are doing this:
program 1
>> tuner 1
program 2
>> tuner 2
So your arrangement is not what RT is expecting.
-Dave
post #2777 of 2788 Old 07-31-2010, 04:46 PM - Thread Starter
AllenDB's Avatar
Looking at his last ini file it looks like he got it sorted out and working. Glad to hear it before.....................................
before RT blew his HTPC to smoking shreds
If one gets the drift.
AllenDB is offline
post #2778 of 2788 Old 07-31-2010, 04:58 PM
TPeterson's Avatar
Quoted: 78 Post(s)
Nothing ventured, nothing gained.
post #2779 of 2788 Old 07-31-2010, 05:26 PM
KAXKID's Avatar
yes, i read the documentation and figured it out before the smoke got too thick...
steve
KAXKID is offline
post #2780 of 2788 Old 08-02-2010, 10:07 AM - Thread Starter
AllenDB's Avatar
Put the latest RT in post #1.
AllenDB is offline
post #2781 of 2788 Old 12-30-2011, 09:32 AM
jldet5's Avatar
Hi Allen,
Came to download the latest PLM. Haven't been on for a year. PLM is still a vital link for me to run between GB-PVR Hauppauge for recording and MYHD for playback. Thanks for continuing to support these much appreciated apps!
jldet5 is offline
post #2782 of 2788 Old 12-30-2011, 08:57 PM - Thread Starter
AllenDB's Avatar
Originally Posted by jldet5 View Post
Hi Allen,
As do I. If my MYHD cards ever fail I won't know how to watch TV
And since you pressed the 'resurrection' button I'll point out that I added two more options to PLM but did not post a new one. "StartList' and 'StopList'. Controls programs dated before and/or after specified dates to be skipped. I was watching programs but did not remove them. Since I usually watch in date order I put in the commands to skip 'old' programs.
Allen
AllenDB is offline
post #2783 of 2788 Old 01-18-2012, 01:27 PM - Thread Starter
AllenDB's Avatar
Since the thread got resurrected, in a manner, I posted the latest PLM. Added StartList and StopList to control what files get put into the playlist by date. Added AtEnd to put specified files at the end of the playlist no matter what sort option is used or not used. I use it to put movies at the end of the list.
AllenDB is offline
post #2784 of 2788 Old 01-20-2012, 07:24 PM
DPlettner's Avatar
Hi Allen,
Thanks for the update. My hybrid RT/CW_EPG setup is still working great!
-Dave
post #2785 of 2788 Old 01-20-2012, 08:14 PM - Thread Starter
AllenDB's Avatar
Sure been awhile. Haven't touched RT lately but still tinker with the PLM,,,,,,,,, in between cruises.
Allen
AllenDB is offline
post #2786 of 2788 Old 04-13-2014, 06:43 PM - Thread Starter
AllenDB's Avatar
Anybody still here??
Unthinkable happened. MYHD software comes up, shows the current channel but no buttons on the control screen work and neither does the remote.
I did clean out the Temporary Internet Files folder today but nothing else. I reinstalled but can't get any control mechanisms to functionj. Its how I watch 98% of all recorded material.
I posted this in the MYHD thread too
AllenDB is offline
post #2787 of 2788 Old 04-13-2014, 06:46 PM - Thread Starter
AllenDB's Avatar
And just in case is there a replacement box? One that connect component to the TV and connects to the home network? The HDX box I use is really limited in that it can keep trace of only 6 or so networked folders. But the MYHD playlist is impossible to replace or is it????
AllenDB is offline
post #2788 of 2788 Old 04-13-2014, 06:48 PM - Thread Starter
AllenDB's Avatar
False alarm, fixed!!! Malwarebytes, which I just installed, somehow screws it up.
AllenDB is offline
Reply Home Theater Computers
