PlayList_Manager & Record_This - Page 94 - AVS Forum | Home Theater Discussions And Reviews
post #2791 of 2804 Old 04-17-2015, 12:28 PM - Thread Starter
AllenDB's Avatar
Originally Posted by DPlettner View Post
Hi Allen,
Good to hear from you. Glad to see you are still around.
Sadly, I am not using RT much these days. I don't record much anymore, and when I do I use Media Center.
Sorry I can't help with your problem. I just wanted to say hi.
-Dave
Yeah, its cool to hear from past users and the like. Don't have my 40' tower anymore as we moved downtown. Driving back and forth into the hills got to be a but tiresome.
Hope all is well,
Allen
AllenDB is offline
post #2792 of 2804 Old 11-13-2015, 11:29 AM
rgharrin's Avatar
Plm
This works for me except
"skip NCISLA" is ignored....NCISLA is on J: drive
Any ideas?
>> clear
>> extensions tp
>> sortd
>> skip NCISLA
>> CheckSubFolders
>> skip MyHD_sections
J:/MyHD
\\xe2\myhd
\\xe\myhd
\\dc5000\myhd
rgharrin is offline
post #2793 of 2804 Old 11-13-2015, 12:46 PM - Thread Starter
AllenDB's Avatar
Any ideas?
>> clear
>> extensions tp
>> sortd
>> skip NCISLA
>> CheckSubFolders
>> skip MyHD_sections
J:/MyHD
\\xe2\myhd
\\xe\myhd
\\dc5000\myhd
Holy Smoke!!!! It has rearisen :.
The program name has to be exact. In this case I believe it is "NCIS: Los Angeles"
AllenDB is offline
post #2794 of 2804 Old 11-13-2015, 01:10 PM
rgharrin's Avatar
I use MyHD to capture NCISLA. That is the name of the folder.
"NCIS: Los Angeles" does not work either.
rgharrin is offline
post #2795 of 2804 Old 11-13-2015, 01:53 PM - Thread Starter
AllenDB's Avatar
Could you type the exact and full file name that you want MYHD to skip? I'm a bit confused.
AllenDB is offline
post #2796 of 2804 Old 11-13-2015, 02:09 PM
SFischer1's Avatar
Quoted: 479 Post(s)
Liked: 60
FreeGuide lists the upcoming program as:
21:59 - NCIS: Los Angeles: Defectors
5-1 KPIXDT, ends 23:00 Crime drama (starts in 3 days)
The members of the team search for a teenage girl who may have been recruited by a terrorist organization.
actor Chris O'Donnell; LL Cool J; Linda Hunt; Daniela Ruah; Eric Christian Olsen; Barrett Foa; Renée Felice Smith; Miguel Ferrer date 20151116 director Dennis Smith episode-num EP01158361.0155; 706 system: dd_progid; onscreen aspect 16:9 stereo dolby digital guest Nicole Steinwedell; Arthur Darbinyan; Anjali Bhimani; Marlane Barnes; Laura Niemi; James Wong; Rishi Arya; Anne Griffin; Adam Lieberman; César García; Jenna Seede; Jonathan Roumie writer Jordana Lewis Jaffe value TV-14 quality HDTV
SHF
SFischer1 is online now
post #2797 of 2804 Old 11-13-2015, 02:17 PM
rgharrin's Avatar
NCISLA
MyHD captures the episode.
My_Playlist_Manager puts NCISLA on my playlist.
I have many others, such as scorpion, bones, gotham, player, etc
on the playlist. I want NCISLA excluded
skip does not leave it off the list
rgharrin is offline
post #2798 of 2804 Old 11-13-2015, 02:29 PM
rgharrin's Avatar
NCISLA
rgharrin is offline
post #2799 of 2804 Old 11-13-2015, 02:39 PM - Thread Starter
AllenDB's Avatar
NCISLA
Could you post the log file? Thats MYHD_Log.txt.
AllenDB is offline
post #2800 of 2804 Old 11-13-2015, 06:03 PM
rgharrin's Avatar
thanks for your interset,
log file
rgharrin is offline
post #2801 of 2804 Old 11-14-2015, 02:41 PM - Thread Starter
AllenDB's Avatar
log file
This is going to get a bit complicated so bear with.
The PLM treats the first string of characters to the left of the last period as the file name.
For the actual file "E:\myhd\NCISLA\D05-1(39)-1005.tp" the PLM treats "D05-1(39)-1005" as the file name.
This is a bug in the case of MYHD section naming architecture. When the PLM was first written there was a small effort to deal with this MYHD feature but it obviously does not work correctly in all cases.
If your want to put out a little more effort try another angle. Try ">>skip D05-1(39)-1005". I am not sure but it might work. If it does you would have to put in a skip entry for each NCISLA.
A couple of years ago the disk drive on my development machine went south. In a manner I did recover the files that were on the disk but I have not been able to successfully reinstall the C++ development environment. Good Luck.
AllenDB is offline
post #2802 of 2804 Old 11-15-2015, 08:54 AM
rgharrin's Avatar
>>skip D05-1(39)-1005 does not work
nor does >>skip NCISLA\D05-1(39)-1005
Thanks so much for your time to answer my question.
This little program does so much for me. I am very grateful for what it does.
rgharrin is offline
post #2803 of 2804 Old 11-15-2015, 09:40 AM - Thread Starter
AllenDB's Avatar
I gotta poke around some more. I'll name one of my files like yours and see if I can duplicate the problem. But even if I can I can't fix it because I can't get C++ compiler correctly installed. If you wanted to rename the files and take off the MYHD section names it should/probably/maybe work.
AllenDB is offline
post #2804 of 2804 Old 11-15-2015, 11:46 AM - Thread Starter
AllenDB's Avatar
I renamed a file G:\WinTV7\NCISLA\D05-1(39)-1005.ts. I put in:
>>Skip D05-1(39)-1005
and one of the lines in the debug file was:
11/15/15 12:27:48 Skip_This_File: <<skipped>> D05-1(39)-1005(01-20-15)
So it kinda appears to work here.
I accidentally ran across another option I use. I saw an entry in my ini file
>> Skip AFolderName\
I put in
>> Skip NCISLA\
Notice the training backslash. That worked too and I would guess all files under any folder named NCISLA would be skipped.
Good Luck
AllenDB is offline
Reply Home Theater Computers
