Cliff Watson EPG add-on for MyHD, FusionHDTV, and HD Homerun - Page 139 - AVS | Home Theater Discussions And Reviews
 4Likes
post #4141 of 4157 Old 11-30-2014, 07:03 PM - Thread Starter
TPeterson's Avatar
Quoted: 82 Post(s)
Thanks, ebo. I'm still mystified as to how you found this though.
TPeterson is online now
post #4142 of 4157 Old 11-30-2014, 08:29 PM
ccrider2's Avatar
Thumbs up
Thanks, ebo....
Chris C
ccrider2 is offline
post #4143 of 4157 Old 12-01-2014, 04:09 PM
ebo
ebo's Avatar
Quoted: 24 Post(s)
I noticed a long time ago that the files names were the same except for the release date and possibly beta version. Back then, there were always several earlier versions available but more recently that's dropped to 1 or 2. The dates can be found by looking at the latest software or firmware changelog.
ebo is offline
post #4144 of 4157 Old 12-01-2014, 04:48 PM - Thread Starter
TPeterson's Avatar
Quoted: 82 Post(s)
Ah. So you just edit the URL from that of the current version and jump blindly to see if the previous one(s) is(are) there?
post #4145 of 4157 Old 12-01-2014, 11:44 PM
ebo
ebo's Avatar
Quoted: 24 Post(s)
Yup. Like the Leap of Faith in Last Crusade. Or Ike jumping from the saucer in South Park 101: "It's my turn!" (foop). Of course nothing really bad happens if you guess wrong.
ebo is offline
post #4146 of 4157 Old 01-26-2015, 10:18 AM
ccrider2's Avatar
Please jog my 'bean'
I can't recall the name of the file that stores my 'Programs To Match'. I seem to have lost all the data there, but I can't seem to find it in my backups.
Can someone through me a hint?
Thanks Much,
OK....I keep forgetting about the C:/program data folder
Chris C
ccrider2 is offline
post #4147 of 4157 Old 01-26-2015, 01:12 PM - Thread Starter
TPeterson's Avatar
Quoted: 82 Post(s)
Chris, I take it that you found all the 'missing' data in the ProgramData CW_EPG subfolder...right?
EDIT: Oops, just noticed "found it" in the fine print....
ccrider2 likes this.
post #4148 of 4157 Old 01-26-2015, 01:33 PM
SFischer1's Avatar
Quoted: 151 Post(s)
Liked: 31
Search for "watchlist.csv" recommended.
If you are running Vista or above, UAC on does it's magic, ONE PER USER!
"C:\Users\Nani\AppData\Local\VirtualStore\ProgramD ata\CW_EPG\watchlist.csv"
"C:\Users\Nani-Trinity\AppData\Local\VirtualStore\ProgramData\CW_ EPG\watchlist.csv"
On your admin account select Windows Explorer to show hidden and system files.
Windows XP
"C:\Documents and Settings\All Users\Application Data\CW_EPG\watchlist.csv"
SHF
SFischer1 is online now
post #4149 of 4157 Old 01-26-2015, 07:06 PM
ccrider2's Avatar
Nani,
Running win7 with UAC at default; mine is found at C:\ProgramData\CW_EPG + several other places ....thanks to my original install eons ago, in a folder far, far, away.
I keep forgetting that at around version 2, the install ends up in a different spot. When something goes 'ca-thump', I'm looking in the wrong folder for a solution. I never deleted the old install folder as I didn't know that I should; also, it never seemed to affect the operation.
Perhaps these odd things, I'm infrequently experiencing, are the result of that orphan folder.
Chris C
ccrider2 is offline
post #4150 of 4157 Old 01-26-2015, 07:55 PM
SFischer1's Avatar
Quoted: 151 Post(s)
Liked: 31
Originally Posted by ccrider2 View Post
Nani,
Note: This is on my W7 64 Bit Laptop, not on my XP HTPC.
I was bothered that there was not a copy in "C:\ProgramData\CW_EPG" but finding "watchlist.csv" in the VirtualStore for each user made me happy.
It may have happened that I just copied the "watchlist.csv" file from a copy of what is on my HTPC to "C:\ProgramData\CW_EPG" as a normal user and as that is illegal it went to the Virtual Store. I remember just checking CW_EPG and if the watchlist is there job done.
The files are different sizes and the last modified dates are different. So I did it twice, once for each user.
I tried starting CW_EPG on a user account that had never used CW_EPG before. I started it first and there was no watchlist entries or file. Then again this time adding TEST to the watchlist.
Boy was I surprised when it went to "C:\ProgramData\CW_EPG" and not to the VirtualStore.
Just when you think you understand "Developer Best Practices and Guidelines for Applications in a Least Privileged Environment" something new happens.
But wait, copying "Watchlist.csv" may be different for Windows Explorer and CW_EPG program.
More testing to be done.
SHF
post #4151 of 4157 Old 01-26-2015, 10:21 PM
SFischer1's Avatar
Quoted: 151 Post(s)
Liked: 31
Strange, I cannot get "watchlist.csv" into the VirtualStore for a new user that never ran CW_EPG before.
I must have done something strange when I was trying to get CW_EPG working before.
Once a file in "ProgramData" is forced into the VirtualStore it stays there for that user.
SHF
post #4152 of 4157 Old 01-27-2015, 10:22 AM
ccrider2's Avatar
SHF
Until you mentioned VirtualStore, I had no idea it existed. I've never put anything in there, that I recall; although there's bits and pieces of 6 different apps there.
Everyday day I become more convinced I know nothing, (Sgt. Schulz Syndrome) and have become accustomed to accepting that.
Chris C
ccrider2 is offline
post #4153 of 4157 Old 01-27-2015, 11:09 AM
SFischer1's Avatar
Quoted: 151 Post(s)
Liked: 31
The Virtual Store (and Virtual Registry) were created to allow old (read BAD) programs to continue to work while protecting the system / users.
I first learned about it before ~ 01-30-2007 with a Vista prerelease.
The "Developer Best Practices and Guidelines for Applications in a Least Privileged Environment" document is now at: https://msdn.microsoft.com/en-us/library/aa905330.aspx The Virtual Store description appears to now be in a downloadable help file. Link on that page.
At some point Microsoft will shut down these old (read BAD) programs for good. Just like it did for 16 bit programs. W8 I believe, W10 for sure. I am running XPMODE on W7 which is almost built in.
The number of people I run into that insist that UAC MUST BE TURNED OFF is astounding. W10 may be the last OS that allows it to be turned off and many programs will simply not be allowed to run. Yes, not be allowed to run.
SHF
post #4154 of 4157 Old 02-01-2015, 06:01 PM
Vlad Theimpaler's Avatar
Liked: 33
A big "Thank you" to the CW_EPG Development Team
Two years ago, Superbowl Sunday 2013, the game went into overtime, and as a result, a new episode of the drama "Elementary", which followed the game, was truncated by my HTPC/DVR. I had given that particular scheduled item the maximum "end padding" possible, which was 60 minutes... but the overtime was just too great for that provision to be effective.
After that event, I whined my displeasure in this thread with these words:
I configured the capture settings for "Elementary" to add as much padding as CW_EPG would allow, 15 minutes prior to and 60 minutes following the show. Unfortunately, due to a significant time overrun of the Super Bowl telecast, 60 minutes was not enough, and my resulting capture of "Elementary" is incomplete.
This is my first ever feature request. If possible, I hope a future version of CW_EPG will be configurable enough to allow >60 minutes of post-program padding to a scheduled capture item.
Well, today, I noted that a new episode of "The Black List" follows the Superbowl telecast on NBC tonight. So I manually set that program to have the maximum end padding -- and to my surprise, the latest version of CW_EPG (which I installed a few months back) now allows up to 120 minutes of end padding! (The maximum start padding is still 15 minutes, as before.)
I did not want this feature update -- or my appreciation -- to go unnoticed. Thank you so much for listening to the users of your excellent software. From the bottom of my heart: thank you, thank you, thank you to the awesome CW_EPG Development Team!
Vlad Theimpaler is offline
post #4155 of 4157 Old 02-01-2015, 07:15 PM
ccrider2's Avatar
+1 here also...
Chris C
ccrider2 is offline
post #4156 of 4157 Old 02-03-2015, 11:19 PM - Thread Starter
TPeterson's Avatar
Quoted: 82 Post(s)
Vlad and Chris--
On behalf of Tim, you're welcome. Finally, we all know of a slipstreamed improvement of Tim's that Nani didn't notice first.
Edit: BTW, I was caught flat-footed myself by that Blacklist timing, so I'm capturing the repeat broadcast of that episode in the hour before the regular-timeslot broadcast of the conclusion later this week.
netman likes this.
post #4157 of 4157 Unread Today, 06:50 PM - Thread Starter
TPeterson's Avatar
Quoted: 82 Post(s)
Cool Calling all bit-chomping Windows 10 fans
Good news. I just set up a test PC (a cute little Zotac ZBox fanless job with a Haswell I5 inside) and installed the latest Win10 Tech Preview OS, followed by Chrome, VLC, Java 8-40, HDHomeRun sw, and CW_EPG. It's all working just fine and I didn't have to d**k around with installing stuff in a compatibility mode or "as administrator" either.
Reply Home Theater Computers
