Cliff Watson EPG add-on for MyHD, FusionHDTV, and HD Homerun - Page 140 - AVS | Home Theater Discussions And Reviews
 6Likes
Old 04-05-2015, 07:45 PM
ebo
ebo's Avatar
Quoted: 27 Post(s)
Originally Posted by TPeterson View Post
PS to Dartman: You could use your Prime with CW_EPG also, which is what tranle and at least one other user currently do. It's a bit of a kluge and costs $25/year for the S.D. EPG data, but it gets you transport-stream recordings (.tp files) without further futzing.
Unless you cable company flags nearly everything as Copy Once, as I understand Time Warner does. Then I don't think CW_EPG will work except maybe for locals.
ebo is offline
Old 04-05-2015, 09:30 PM - Thread Starter
TPeterson's Avatar
Quoted: 94 Post(s)
ebo, I dropped cable instantly when they encrypted my local channels and I don't have a Prime HDHR box so my information is all third hand, but IIUC, the CW_EPG users who have jumped the hoops to get their Prime tuners to play ball with us are as successful as folks using WMC. Perhaps Minh and/or Steve will chime in here....
TPeterson is online now
Old 04-11-2015, 01:08 PM
Dartman's Avatar
Thanks guys, everything works because I also upgraded to the latest version of VideoRedo that supports WTV format as it comes from WMC so no problems with that. Once I edit things down it will convert to just about any format I desire. I usually use MKV as it seems to be a slightly smaller container and all my media players play it nicely, plus VideoRedo doesn't have to do any transcoding so it converts very fast.
I haven't re upped my sub to he EPG seeing how media center handles it for free but it worked well enough when I had my other HDTV card back when basic cable wasn't encrypted here, and the price was right and support was great
Dartman is online now
Old 04-13-2015, 05:15 PM
SFischer1's Avatar
Quoted: 203 Post(s)
Liked: 35
Nani, Java does not equal Javascript. I'd be amazed if AVS Forum used Java and I've seen no notices that Java should be allowed to run in Browsers. Javascript on the otherhand is very common (and does not require that you even have Java installed on your PC).
Does this count? https://nakedsecurity.sophos.com/201...land-security/
That's two years ago. I want to look at the planes landing at SFO and having this off appears to stop the software running.
http://www.flysfo.com/community-envi...light-tracking
It's trying to start with a bigger download than Google Earth.
SHF
Name:	Java in Browsers.JPG
SFischer1 is online now
Old 04-13-2015, 05:42 PM - Thread Starter
TPeterson's Avatar
Quoted: 94 Post(s)
Looks as though you'll have to bite the Java bullet, Nani, if you're going to watch the aeroplanes.
I would do so only with the latest Java and even then I'd try running Volans in a Virtual Machine sandbox.
Old 04-13-2015, 06:06 PM
SFischer1's Avatar
Quoted: 203 Post(s)
Liked: 35
It runs so slow with my Eight (8) CPU W7 system that the one CPU Virtual Machine may just not hack it.
After my understanding is shot down that the problems with KNTV are due to airplanes I will turn it off.
The viewer is just South of SFO and the path to KNTV matches exact ally the low flying airplanes. I sure would like it to be something else.
The SFO Java application sure looks like it is secure. A better case than my being scared to delete an application built with a W2K installer. Dum Dum Dum Me.
SHF
Old 04-15-2015, 10:13 AM
ebo
ebo's Avatar
Quoted: 27 Post(s)
SFischer1:
If your goal is to see where the airplanes are when you're having reception problems, rather than getting a view from the cockpit, you might want to investigate ADSB# and ADSBScope, two programs that work with a cheap DVB-T receiver. It's demonstrated on Hak5 episode 1525, "Track Aircraft with a $20 Software Defined Radio." The segment starts about 10:25 in but skip to ~18:30 for the final result to see if it looks useful. The map is pretty crude but they might have better ones by now. I haven't tried it but I do use the receiver with other software as a cheap spectrum analyzer. Real time for signals <2 MHz wide. 6 MHz TV channels take longer, like a Polaroid snapshot. So you can't see the multipath ripple through the waveform when planes fly by as you could with a real spectrum analyzer.
ebo is offline
Old 04-15-2015, 10:47 AM
SFischer1's Avatar
Quoted: 203 Post(s)
Liked: 35
Originally Posted by ebo View Post
SFischer1:
No, it is not me but a person North West of me.
I got the airplane tracker to work, well a little. It displays a little and then stops. This shows six (6) airplanes getting ready to land at SFO.
San Francisco, CA - OTA
This shows the viewers path to KNTV on Mt. San Bruno. Sutro is almost on the same path.
More words suggesting airplanes are the problem but it has been shot down. The experts are looking for the answer elsewhere.
SHF
Old 04-17-2015, 11:45 AM
AllenDB's Avatar
Quoted: 13 Post(s)
Back To The Dark Ages
Pardon the intrusion but I thought I would as least ask.......
From the dark ages of rctvcap and rcgraphbuilder. My HTPC bit the dust in a major way a month ago. Its resurrection seemed a difficult task so I opted for the DVR option from DirecTV. While impressed with its capabilities I need to get the HTPC back up and running. I use rctvcap to record off two DTV boxes. To get rctvcap to run in the past I used rcgraphbuilder.
Now when I run rcgraphbuilder I get the dreaded "can't find filter: File Dump". Having grown a bit older since the early 2000 I can't remember how to get around this problem.
Somebody out there remember????
Please and thank you.
AllenDB is offline
Old 04-17-2015, 06:13 PM
ebo
ebo's Avatar
Quoted: 27 Post(s)
Pardon me for responding to a topic I know nothing about (doesn't seem related to CW_EPG) but if you're talking about the Hauppauge 1212 HD PVR you'll probably get more help in that thread. A quick search turned up lots of old messages about rctvcap and rcgraphbuilder. Also see ARogan's blog. The PVR should have come with Arcsoft software on a disc; once installed look for C:\Program Files\Common Files\ArcSoft\Mpeg Engine\filedump.ax. Make sure it's registered by running regsvr32 filedump.ax (probably as Administrator).
ebo is offline
Old 04-19-2015, 10:04 PM - Thread Starter
TPeterson's Avatar
Quoted: 94 Post(s)
Update on Win8, 10 and Java 8 compatibility
The fly in the ointment that I just discovered lately is that Windows 8 and Win10 Tech Preview both have broken the way that CW_EPG handles waking up for scheduled recordings.
Dale and I have been looking at this problem (and the Java 8 one) and he's created a fix such that CW_EPG will work with these newer OSes. But we've run into a bug in the new driver that was needed, which prevents proper operation on Win10 (and, I think, Win8) so we are seeking a workaround before releasing an update for beta test.
Old 04-20-2015, 07:37 AM
ccrider2's Avatar
Quoted: 20 Post(s)
Is there an issue with Windows 7?
And will that also be included in the Java 8 fix for Win10 & Win8?
Chris C
ccrider2 is offline
Old 04-20-2015, 09:07 AM - Thread Starter
TPeterson's Avatar
Quoted: 94 Post(s)
Chris--
Yes, there is an issue in all Windows versions after upgrading to Java 8. The issue is that Java 8 has dropped support for the driver that CWHelper uses to access the MDB file where it maintains the "localhost:8181/recent" report. It doesn't affect scheduling or actual recordings, however, so it's a relatively minor problem. Dale's new code will fix it on all Windows versions.
ccrider2 likes this.
Old 04-20-2015, 10:28 PM
SFischer1's Avatar
Quoted: 203 Post(s)
Liked: 35
Old 04-20-2015, 11:37 PM - Thread Starter
TPeterson's Avatar
Quoted: 94 Post(s)
In the long run we're all "doomed", Nani. It's about time that HDHR produced a complete product and they should be able to make some polished software for $100k (OK, so it will end up costing more--I know some folks who could give them a big head start. ). But going head-to-head with AppleTV is a very tough game. I wish them well.
Old 04-21-2015, 09:01 AM
ccrider2's Avatar
Quoted: 20 Post(s)
Originally Posted by SFischer1 View Post
CW-epg serves it's purpose even if the maintainers of Cliff's 'baby' decide to put a cost on their work. Actually, I never knew Cliff, but if he had a family that survived him, I would gladly donate to a fund for providing this program.
Chris C
ccrider2 is offline
