Cliff Watson EPG add-on for MyHD, FusionHDTV, and HD Homerun - Page 141 - AVS | Home Theater Discussions And Reviews
 9Likes
post #4201 of 4215 Old 06-01-2015, 09:29 AM
ccrider2's Avatar
Quoted: 22 Post(s)
Originally Posted by SFischer1 View Post
I just got this in my notifications Icon area.
My reading that Windows 10 would be free to W7 and higher Windows versions was correct.
As Windows 10 is said to be the last Windows version, what is next? "DOORS"?
SHF
But what's the charge per month to use it? Does it say? I get a page not found error when trying to research.
Chris C
ccrider2 is offline
post #4202 of 4215 Old 06-01-2015, 09:46 AM - Thread Starter
TPeterson's Avatar
Quoted: 129 Post(s)
Liked: 24
Wink Why worry, be happy....
Nani, yes there is a 32-bit W10, which you can get via the "Insiders' Preview" site.
I've been testing W10-64 and working with our team to update CW_EPG for it (and W10-32 automatically, since CW_EPG is a 32-bit program). Thanks to the team's work (primarily, Dale's yeoman's efforts) we're nearly there now.
ccrider2 likes this.
TPeterson is offline
post #4203 of 4215 Old 06-01-2015, 09:50 AM
SFischer1's Avatar
Quoted: 246 Post(s)
Liked: 39
Originally Posted by ccrider2 View Post
404???? Makes me wonder if 'Uncle Bill' has it together yet.
Perhaps not as Windows 10 will be the last Windows. He is actually off giving his money away (And Warren Buffett 's money also.)
I did determine that W10 does have a 32 Bit edition.
Windows Update would not give me the W10 upgrade Icon like it did on my W7 64 Bit Laptop.
So now off to the MyHD thread to see if anyone has tried MyHD on W10.
SHF
SFischer1 is online now
post #4204 of 4215 Old 06-01-2015, 08:49 PM
Dartman's Avatar
Got my notification today too. Using Win7 64 Ultimate and saw a weird box in the running APS notification area. Agreed to the eventual download but probably won't install it till I get something that will work in place WMC for my Prime.
Silicon Dust is working on a DVR solution that should work with cable card and regular HomeRun boxes so maybe once I have a working beta it'll be worth the upgrade.
For many here where the EPG is working fine probably not a issue as no need for WMC, and should be working with 10 too.
You can install a WMC add-on to 10 but then it will refuse to run windows updates supposedly.
Dartman is offline
post #4205 of 4215 Old 06-01-2015, 09:04 PM
SFischer1's Avatar
Quoted: 246 Post(s)
Liked: 39
And I keep setting the W10 Icon to not be displayed and it keeps coming back on each restart.
I need to pay the $$$ to MS for the W7 Home Premium to W7 Pro upgrade for some features I thought were not needed.
Maybe then the W10 Icon will appear with Windows Update on the 32 Bit Edition.
Be sure and burn the DVD's when you install W10, that's the only way to do a clean install like I need to do.
SHF
post #4206 of 4215 Old 06-01-2015, 09:54 PM - Thread Starter
TPeterson's Avatar
Quoted: 129 Post(s)
Liked: 24
Nani, just go to the ISO download site and get your W10-32 now: http://windows.microsoft.com/en-us/windows/preview-iso
Chances seem good that once you're in the "insiders" program you'll be grandfathered into W10 RTM ownership too.
P.S.: If you're not ready to install it as a dual-boot option, you can also install it in an Oracle VBox VM to get used to it. (But you can't install MyHD in a VM)
post #4207 of 4215 Old 06-01-2015, 10:05 PM - Thread Starter
TPeterson's Avatar
Quoted: 129 Post(s)
Liked: 24
Originally Posted by Dartman View Post
...won't install {W10} till I get something that will work in place WMC for my Prime....
As I've mentioned and Steve (KAXKID) and Minh (Tranle) have confirmed, CW_EPG is that something already.
post #4208 of 4215 Old 06-01-2015, 10:20 PM
SFischer1's Avatar
Quoted: 246 Post(s)
Liked: 39
http://www.theregister.co.uk/2015/06/01/windows_10_upgrade_app_arrives_on_windows_7_and_8_ tempted/
Suggests waiting is better, but Home Premium upgrade to Pro needs to be done first. Before or after wiping the hard disk clean to fix the Fusion abort on rewind problem.
Wait, could I get W 10 Pro without upgrading from Home Pro. That does not sound right.
I have that computer dual booting now but using Linux GPARTD to create partitions is the problem.
And I need to fix the "F" grade for Internet download speed soon, webpages are getting very slow to load.
Too much to do, too little time left.
I will look at downloading W10 32 Bit very soon. Thanks for that and the dual boot idea if I can do it.
MS outlawing Partition Magic keeps coming back for me to be horrible.
SHF
post #4209 of 4215 Old 06-02-2015, 07:14 AM
SFischer1's Avatar
Quoted: 246 Post(s)
Liked: 39
I got the W10 Insider 32 Bit ISO burned to a DVD.
Now to figure out how to save the existing W7 32 Bit installation and partition the 500 GB disk after "Nuking" it.
If I can get better partition sizes then I will be able to dual boot.
Terry, are you suggesting that I may not need to upgrade W7 Home Premium to W7 PRO? I need to read the details but where are they. The link from the Paradox forum does not match up with the Insider program.
Next post will be to:
MyHD on Vista & W7 - W8 Main Thread
http://www.avsforum.com/forum/26-hom...in-thread.html
SHF
post #4210 of 4215 Old 06-02-2015, 07:43 AM - Thread Starter
TPeterson's Avatar
Quoted: 129 Post(s)
Liked: 24
Nani, I'm not at all clear on how MSFT plans to align W10 versions (if any) with the prior version ownership. However, if they grandfather us "insiders" I expect they'll let us keep the version we've been testing (i.e., the full monty).
post #4211 of 4215 Old 06-02-2015, 08:21 AM
SFischer1's Avatar
Quoted: 246 Post(s)
Liked: 39
I have replied to:
Welcome to the MyHD on Windows Vista & W7 / W8 / W10 Main thread
SHF
post #4212 of 4215 Old 06-15-2015, 10:27 PM
SFischer1's Avatar
Quoted: 246 Post(s)
Liked: 39
Episode Numbers
I have long wondered how TMS / Gracenote assigns Episode Numbers.
After discovering KQED Inc. latest upcoming blunder with "Prime Suspect" numbers 5, 23 last Friday and upcoming Friday to be 7, 24 I Googled "how does gracenote assign episode numbers" and got this web site:
http://www.gracenote.com/video/unique_id/
It gets interesting here:
http://developer.tmsapi.com/page/Quickstart_Guide
And this that I will send to a friend:
EyeTV EPG switches to My EyeTV Gracenote
http://blog.macplaza.co.uk/2013/02/e...etv-gracenote/
And this to post to my local OTA list:
http://www.sec.gov/Archives/edgar/da...9310d1012b.htm
Not an answer to my question, what will actually be shown Friday I will need to wait.
I found a website long ago that also assigned unique ID's, but TMS / Gracenote may be the same or that one just never caught on.
SHF
post #4213 of 4215 Old Today, 08:23 PM
ebo
ebo's Avatar
Quoted: 31 Post(s)
I have CW_EPG set up to email me whenever it schedules anything. It stopped doing so a few months back. I use Verizon for email and they've made some changes which I incorporated into my email client but forgot to do in CW_EPG. I figure their grace period ended and I'm sure that's part of the problem. But when I made the changes to CW_EPG's email page it still didn't work.
The changes are:
SMTP Mail Host: outgoing.verizon.net => smtp.verizon.net
Port: 587 (originally 25) => 465
Secure Connection Required (SSL): unchecked => checked
I'm using an old email client (Agent 2.0) that doesn't understand SSL, so back when Verizon said they were going to require it I installed Stunnel, which lets me point Agent to localhost using the non-SSL ports. Stunnel adds SSL and converts to the proper ports. So I set up CW_EPG to use Stunnel by sending to localhost unencrypted on port 587. That worked. So why didn't it work to let CW_EPG do SSL directly? What am I doing wrong?
ebo is online now
post #4214 of 4215 Old Today, 08:34 PM - Thread Starter
TPeterson's Avatar
Quoted: 129 Post(s)
Liked: 24
ebo, I think that your problem is that CW_EPG's emailer can use SSL, but doesn't (yet) do TLS, which many mail hosts now require instead of SSL. The only workaround for the present is to use no encryption and port 25, which only works if your mail host can be persuaded to trust your CW_EPG sender or, as you did, if you use an indirect route.
post #4215 of 4215 Old Today, 08:50 PM
ebo
ebo's Avatar
Quoted: 31 Post(s)
Thank you; that's probably it. I'll leave it set up to use Stunnel for now.
ebo is online now
Reply Home Theater Computers
