Cliff Watson PVR app for HD Homerun, MyHD, and FusionHDTV - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #4321 of 4336 Old 06-27-2017, 10:05 AM
sengsational's Avatar
Hey guys,
This might not be the "perfect" place to start for this question, but given we're all on Windows and have transport stream files laid down by (typically) HDHR devices (or maybe MyHD), I thought I'd start here.
Here's the problem I'm having: A station (my local PBS, to be more specific), often sends out what I consider to be a defective transport stream, and I'd like to know it's defective before I attempt to watch it.
You might think that if it's OTA (over the air), how do I know it's a defective transport stream and not just bad reception. Well, if I'm correct in my thinking, the stats gathered by the HDHR for the recording would be "bad" for bad reception. But that's not the case. Checking http://127.0.0.1:8181/recent, I can see "tste", "tsmiss" are zero, and "tunss" is >95 and "tunsnq" is 100. On other channels, when the recording is pixelated or has dropouts, those numbers are "bad".
The symptom I have is "good" reception stats, but the recording doesn't play well in VLC. For example, we got a recording, watched 35 minutes of it...perfect, then there was a 5 minute segment that caused VLC to hang. After that it played fine again.
Since these recordings come on PBS, they're repeated at different times. What happens is that I get a recording, then CW_EPG skips the repeats, as designed. So the repeats come and go, and I'm sitting on a defective capture file, but don't know it! So one solution would be to configure CW_EPG to record all instances of the problem shows. But what I was wondering was, is there a batch file program/process that can assess the quality of a capture file? If so, I could be alerted right away and make sure I don't miss when the show gets replayed.
sengsational is offline
post #4322 of 4336 Old 06-27-2017, 12:03 PM - Thread Starter
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Dale, does TSReader Lite indicate problems with these defective recordings? That doesn't fit your request for a batch file, but if TSReader doesn't see issues, I'm not sure that any other filter would find them either.
TPeterson is offline
post #4323 of 4336 Old 06-28-2017, 07:33 PM
Terry, Thanks for the reply. I had run it through my crusty copy of TSReaderLite (circa 2003!), and it added an asterisk and said that meant the PID had continuity errors. The "Continuity errors:" field jumped from 0 to 23189 (and the associated asterisk showed up) in the middle of chugging through the file, so that did align with my watching experience.
The same TV station aired that same program again and I ran THAT one through TSReaderLite... no asterisk, zero continuity errors! I haven't watched it yet to see if it plays well, but I bet it will be fine.
Might need to write me a transport stream parser. Whoa! That's above my pay grade!
post #4324 of 4336 Old 06-28-2017, 08:45 PM - Thread Starter
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Hmm...I had thought that the tsmiss HDHR stat was equivalent to continuity errors in TSReader...but I guess that's not right. But in any case I'm sure that the needed utility has been written already.
See, e.g., here
post #4325 of 4336 Old 06-29-2017, 10:47 AM
ebo
ebo's Avatar
Quoted: 68 Post(s)
There are a number of programs that claim to fix ATSC transport stream errors. Some are free. Some will log the errors they find. Years ago I used MPEG2Repair which is free and does save a log. It's also handy for joining segmented .TS files into one file. The final version is 1.0.1.5 from 2007.
Back then I used HDTVtoMPEG2 (I might have that name wrong) to edit out commercials. It was very crude, butting the remaining segments together without fixing the timestamp discontinuities. MyHD played the result just fine but other programs and hardware players like WDTV would stop when they hit an edit.
I dropped both programs when I switched to VideoReDo, which does proper frame-accurate edits. Its QuickStream Fix tool can repair .TS errors. But it's not free.
Any version of TSReaderLite can work with saved .TS files but only recent ones work directly with 4th-gen HDHRs such as the HDHR4-2US. The current version is 2.8.48b.
ebo is offline
post #4326 of 4336 Old 07-04-2017, 11:29 AM
I was under the impression that HDHR's stats would do it too, but, like I said, I got a perfect recording according to the HDHR stats, but had an horrific chunk in it from a watchability standpoint, and it had thousands of continuity errors on TSReaderLite.
I found DVB Inspector, written in Java, and the author is still active. Using that as a library and two lines of code, default logging, it spits out continuity errors!
Code:
       TransportStream transportStream = new TransportStream("c:\\my\\tmp\\11.3-170702-2200-Prime Suspect; Tennison on Masterpiece-.tp");
       transportStream.parseStream();
ebo, I even recall a few of those tools. But I'm less about attempting to fix the files... I just want to know (in an automated way, such as a command line) they're bad so I can delete the entry from the cw_epg history and so allow them to record on the next airing.
post #4327 of 4336 Old 07-04-2017, 06:52 PM - Thread Starter
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Dale, it may not be in the "debug" stats recorded in /recent, but I think that if you look at CWHelper's log of the "...." progress you'll see some "...s...sss.." occurences in the problem recordings. You could use that string as your rejection criterion.
post #4328 of 4336 Old 07-10-2017, 09:19 AM
I had my doubts, but looked back at the recording that spawned this thing and the dang dots DID show a problem, when the debug was "clean"! Again, sir, you come through with "the right answer".
post #4329 of 4336 Old 07-10-2017, 09:38 AM - Thread Starter
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Aha! But I was guessing wrong about the source of the problem. According to the "dots", you had LAN issues for that recording, not sequence errors in the TS. That still leaves us with no explanation for the lack of errors in the debug report..."err = 0"?
post #4330 of 4336 Old 09-15-2017, 07:17 PM
theduke514's Avatar
unable to record - ant 0
I notice that my CW EPG was not recording.
I reinstalled it, without success.
I have 2 tuners through HD Homerun box. Ant 1 and Ant 2.
When I select a program, is shows which tuner will record it. However, when I push the "schedule matches", these are sent to the "scheduled item" tab. But they show up with Ant 0 next to them. The result is that none get recorded.
Any idea, what setting I need to change so that the proper tuner is selected?
theduke514 is offline
post #4331 of 4336 Old 09-15-2017, 08:19 PM
SFischer1's Avatar
Quoted: 619 Post(s)
Liked: 71
Is this something new or are you just getting started? Do you have a two tuner model or a three tuner HDHomeRun model?
Tuner0 and Tuner1 are all that I have seen on any of my HDHR tuners, (Two tuner models both) CW-EPG, HDHR GUI setup and HomeRun Config all show Tuner0 and Tuner1.
Where does the Ant 1 and Ant 2 show up?
What does the HDHR Config GUI show, again Tuner0 and Tuner1 show for me.
SHF
SFischer1 is online now
post #4332 of 4336 Old 09-15-2017, 09:38 PM - Thread Starter
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Pierre, you're confusing two unrelated numbers. The "1" and "2" on the Main tab are the priorities of your two tuners as you have defined them on the Options window. The "Ant0" and "Ant1" on the Scheduled tab refer to the tuners in each HDHR unit. E.g., if you have set up tuner0 in one of your two HDHR units (totaling 4 tuners if you have the standard item) it will show up as "1" in the Matches pane on the Main tab and "Ant0" on the Scheduled tab.
Now...we need more information to figure out why "none get recorded". Do you see no file in the designated capture folder or is it there but 0 bytes? Please send me the stdout.txt and stderr.txt files from your CW_EPG\logs folder that include a time range where one of these non-recordings was scheduled and then not recorded. From that I can probably deduce the issue.
post #4333 of 4336 Old 09-15-2017, 09:40 PM
SFischer1's Avatar
Quoted: 619 Post(s)
Liked: 71
Are you perhaps confusing the MyHD tuners and the HDHR tuners?
MyHD does use Ant 1 and Ant 2 but the HDHR tuners use Tuner0 and Tuner1.
CW_EPG addresses the tuners in their native method thus MyHD and HDHR are different.
SHF
post #4334 of 4336 Old 09-16-2017, 02:22 PM - Thread Starter
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Nani, he doesn't have a MyHD unit, only HDHR ones. See my post above for an explanation of what he's seeing. The only question is exactly what's transpiring with the scheduled captures, since it's clear from his first post that they're set up correctly.
Pierre, the "Ant" column on the Scheduled Items tab is a misnomer (left over from tuners that had more than one actual antenna). If you look at the Tuner column there you'll see that the "0" and "1" in the Ant column merely replicate the final number of the HDHR tuner in the Tuner column; i.e., it designates which of the tuners in the HDHR will be used. You're seeing a "0" there because one of your HDHR tuners "HRxxxxxx-0" was made top priority for the scheduled program (i.e., it is Tuner "1" on the Main tab's Matches pane) so it was the selected tuner for the capture.
post #4335 of 4336 Old 09-16-2017, 03:20 PM
SFischer1's Avatar
Quoted: 619 Post(s)
Liked: 71
I cannot read PDF's, install Java, get Both of IE and Chrome to load so I had to go to FireFox. So I sorta can get my e-mail and surf the Internet.
With my main laptop failed and Sony out the business, Best Buy Geek Squad Sony's new repair option could not open a repair ticket for Kentucky.
So I had to take it to Central Computers who do board level part replacement in San Jose. Fingers crossed.
Thus I could not look at CW_EPG's doc and other places and looking at all the HDHR programs I could not see ANT 2 at all, even in the place you added to the list.
The possibility of MyHD and HDHR confusion in the doc was a possibility for ANT 2.
As usual your idea of CW_EPG tuner Icon numbers appears to be correct. I do not use the second antenna on MyHD even though an antenna is connected.
SHF
post #4336 of 4336 Old 09-19-2017, 03:40 AM
theduke514's Avatar
SHF
Thank you for the explanation. It sure got me confused.
I can now confirmed that the recording seems to work now. The re-installation seems to have fixed my issue.
Thank you again for your support. You are a dedicated individual.
Reply Home Theater Computers
