MYHD trouble with AMD duel core processor. No video. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-26-2006, 09:58 PM - Thread Starter
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 57
I just loaded my MYHD card in my new HTPC. The PC has a AMD duel core processor. My servers connected to this PC are mapped and showing up and the MYHD card launches and works fine but while its playing the file I have blanks video and audio. If I transfer the file to my main PC it plays fine just not from any servers connected to the main PC. Not sure of the term but hyper something but Im told with a duel core I need to disable one of the processors.
Im not very technical with PCs but Im trying the bes I can describing this.
Anyone know how to do this or if there is anything else I can try.
Thank you.
Alan Gouger is online now
post #2 of 9 Old 03-27-2006, 06:31 AM
thepicman's Avatar
Alan,
From the MetaFAQ:
Question: HyperThreading, multi-processor, dual-core disables certain features (DVD, firewire, etc.)
From Digital Connection FAQ:
http://www.digitalconnection.com/Support/cn_myhd_1.asp
MyHD software will work with Dual and HyperThreading systems, however there are some functions that do not work properly without disabling this feature. The three functions that will not work under dual processor/hyperthreading is:
DVD-Playback
Playback of recorded files over a network
Firewire recording to D-VHS tape player using MDP-130 software
I think you are having this problem. If I mistunderstood, please let me know.
TPM
thepicman is offline
post #3 of 9 Old 03-27-2006, 08:18 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 57
TPM
Yes, I cannot playback my recorded ts. files :(
Ive now been told a few things but do not know which will work.
I was told I need to turn off one of the processors but was not told how to do this.
I was told there is a registry hack but not told how to do this.
Any help is appreciated:)
post #4 of 9 Old 03-27-2006, 08:44 AM
sfhub's Avatar
Most likely there is an option in your BIOS to turn off the second processor.
When you first turn on the PC either some BIOS identification comes on the screen or you see some image identifying the PC. At this point, depending on the BIOS, you hit "DEL" or "F10" or some special key on the keyboard to enter the BIOS config. There will be several options, setting the clock, the HD types, etc. Under processor menu or advanced menu, there should be something that sounds like disable dual core.
The instruction manual will probably have more detailed and pertinent info.
Try disabling the 2nd core and see if playback improves.
sfhub is offline
post #5 of 9 Old 03-27-2006, 09:39 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 57
Hi
Tried that last night. Nothing in the Bios to turn off the sencond processor. My PC guy who built the machine read through the manual and cant figure out how to turn it off. Im not a PC geru so Im stuck waiting :)
post #6 of 9 Old 03-27-2006, 11:39 AM
Super Moderator
Bob Sorel's Avatar
Quoted: 73 Post(s)
Liked: 126
Well, Alan, the dual core processor or hyperthreading is DEFINITELY your problem, as MyHD will not play over a LAN unless it (or they) is disabled. I don't know much of anything about AMD processors, but with Intel it is a simple matter to disable hyperthreading in the BIOS. As soon as I disabled hyperthreading, .TS playback over my LAN became possible. Having the latest and the greatest in the PC world is not always optimum unfortunately.
If you give us the exact model of motherboard you have, maybe one of us kind souls will check an online manual for you to see if we can find the setting that needs to be disabled....;)
Bob Sorel is offline
post #7 of 9 Old 03-27-2006, 11:47 AM
alk3997's Avatar
Liked: 92
As far as I know there is no way to "turn off" the second processor in an AMD dual core processor. Unlike hyperthreading, where one processor acts like it is multiple processors, the AMD dual core chips really have two cores and the second processor is integral to the way the overall chip works.
Dual cores have lower clock speeds than their single core counterparts. Less with AMD than Intel. Is it possible to exchange your dual core? If so, you might wan to look at an AMD FX-57 or one of the AMD San Diego 4000+ chips.
alk3997 is offline
post #8 of 9 Old 03-27-2006, 01:25 PM
sfhub's Avatar
Hi
EDIT: No need to try. Doesn't work with my HT system, so probably won't work with dual core.
I don't know if this will work, but it is worth a try.
Run MyHD.exe
Press ctrl-alt-del to get task manager
Click on "Process" tab
Find MyHD.exe
Right click on MyHD.exe
Select "Set Affinity"
Check CPU 0, uncheck CPU 1
Again, this may or may not work, I haven't tried it.
sfhub is offline
post #9 of 9 Old 03-27-2006, 01:45 PM
miimura's Avatar
Alan,
You don't have to do anything to your BIOS. Just have Windows start with only one CPU. Edit your Boot.ini to have something like the following:
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\\WINDOWS="Microsoft Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\\WINDOWS="Microsoft Windows XP Pro Uniprocessor" /fastdetect /onecpu
see http://www.sysinternals.com/Information/bootini.html for more startup options. This will add a selection to your boot process so you can choose whether you want to start up the normal way or force only one cpu. You can get there by going to System Properties->Advanced->Startup and Recovery->Settings. Clicking the Edit button there will take you right to the Boot.ini in Notepad. This dialog also allows you to set your default selection and how long it will put up the text-mode list of choices at boot time.
However, this kinda defeats the purpose of having a dual-core machine, but at least you can use all the MyHD features. Network playback is a must for me on the HTPC. My HTPC has HT off in the BIOS, but my server which also has a MyHD for recording, just does without those features that don't work with MP/HT.
- Mike
miimura is offline
Closed Thread Home Theater Computers
