Artec T14A Mini USB 2.0 HDTV tuner - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 321 Old 10-18-2007, 08:39 PM
gblinckmann's Avatar
Originally Posted by Da_G View Post
New driver+application today.
V 2.0.2.0 &
V 1.X.0.4,
1.0.4.8
Word from artec tech support is that it fixes the 55 sec skip. Have not yet tried it.
Thanks! I'll have to see if that fixes my reboot problem.
Glenn-
TW Albany, NY - SA Explorer 8300HD - SARA 1.87.16.a109
gblinckmann is offline
post #302 of 321 Old 10-20-2007, 09:13 AM
pivovy's Avatar
This is how scan window looks like in 2.0.2.0
Although these QAM options are not available for now, this is a good sign.
I no longer have 55s skip.
pivovy is offline
post #303 of 321 Old 10-20-2007, 11:28 AM
Unless I'm missing something, this still has the same driver. It's not fixing my reboot issue.
Glenn-
post #304 of 321 Old 10-23-2007, 09:49 AM
Da_G's Avatar
32 bit driver has been updated. You can extract it from the executable by appending /a to the command line, and extracting to a temporary folder.
The 55sec skip does seem to be fixed with this new driver + app. However unfortunately the 64 bit driver has not yet been updated, who wants to join me in emailing artec to bug them for it? :P
Da_G is offline
post #305 of 321 Old 10-26-2007, 07:15 AM
All that's in the setup.exe file is the "ArtecMedia ATSC Digital TV Player 2.0.2.0.msi" file and some INI files. There's no driver in there that I can find. So the file at the following link doesn't have any drivers in it that I know of:
http://207.210.85.226/~artectv/drive....2.0/setup.exe
The file at http://207.210.85.226/~artectv/drive...geVistax32.exe still has the latest Vista32 driver.
Glenn-
post #306 of 321 Old 10-29-2007, 06:19 PM
Da_G's Avatar
In addition to those files it extracts a folder structure. Look in /program files/ultima/artecmedia/driver.
Da_G is offline
post #307 of 321 Old 11-02-2007, 09:05 PM
Thanks! The driver version in there is 1.1.0.4. I'd never have thought to look in that directory. I'll report back if it does or doesn't fix my issue.
Glenn-
post #308 of 321 Old 11-03-2007, 07:23 AM
Well, I tried the new driver. It doesn't seem to work for me. With the older driver Vista Media Center can "see" the tuner, but it doesn't seem so with the newer driver. I guess I'll wait on the sidelines longer for the next driver update for Vista.
Glenn-
post #309 of 321 Old 11-20-2007, 04:11 PM
taleharate's Avatar
Hi
I am not sure whether this is the right place to ask. While browsing internet for USB TV Tuner reviews I happened to see this forum.
I am planning to buy a VisionTek's ATI TV Wonder 600 USB stick HDTV Tuner.
Any one has any experience with this tv tuner?
Please advice me.
Taleharate
taleharate is offline
post #310 of 321 Old 11-27-2007, 10:37 PM
microfeet's Avatar
My Vista MCE / Artec T14A can only record HDTV to the format of 704x480 @ 59fps. In the same PC, the ArtecMedia Digital TV Player can record to 1080i @ 29.97 fps. Does anyone know how to enable 720P/1080i recording in MCE?
FYI, I am using the most recent 1.1.2.2 firmware.
Thanks a lot!
microfeet is offline
post #311 of 321 Old 01-05-2008, 07:42 PM
TimBoston's Avatar
I was wondering if anyone has the antenna connector to attach the antenna to the USB TV Tuner. I bought this from ZipZoomFly for 59 bucks with a 59 dollar rebate (FREE!), but the box didn't contain the antenna connector. I can't seem to get any info from Artec. It must be the language barrier. I sent in the rebate before hooking it up, so I can't return/RMA it with ZipZoomFly.
Is there a part I can buy somewhere to replace this? I went to Radio Shack and they were no help. Any help would be appreciated, thanks!
TimBoston is offline
post #312 of 321 Old 01-07-2008, 09:50 AM
jimwhite's Avatar
try looking here: http://www.pasternack.com/
Jim White
St. Petersburg, FL
jimwhite is offline
post #313 of 321 Old 01-27-2008, 03:26 PM
TimBoston's Avatar
Thanks, do you know what connectors this adapter uses?
post #314 of 321 Old 01-28-2008, 09:59 AM
TimBoston's Avatar
I found the links if anyone is interested.
post #315 of 321 Old 01-28-2008, 09:59 AM
TimBoston's Avatar
post #316 of 321 Old 01-28-2008, 10:01 AM
TimBoston's Avatar
Here is the tiny url to the ebay link, ~12 bucks including shipping.
SMA-Female to SMB-Jack Coaxial Adapter
http://*******.com/2h2vr4
post #317 of 321 Old 02-04-2008, 10:26 PM
sstrunks84's Avatar
i just saw that Artec has released the T18AR. Asthetically, it looks identical to the T14A except it's white. I'm wondering if it's a T14A but just rebranded. Perhaps it does have different internals but regardless, does anybody have the drivers for the T18AR? It supports QAM and maybe the T14A can use the drivers if they are indeed identical units.
sstrunks84 is offline
post #318 of 321 Old 02-13-2008, 07:56 PM
jobedo's Avatar
new drivers http://www.artec.com.tw/Service_e/nl/home/drivers.htm
for T18A ATSC Digital TV
Joe
jobedo is offline
post #319 of 321 Old 05-04-2008, 07:50 PM
jobedo's Avatar
jobedo is offline
post #320 of 321 Old 01-17-2010, 08:25 AM
jobedo's Avatar
Drivers now say WIN 7 on them. http://www.artectv.com/Service_e/nl/home/drivers.htm
Joe
jobedo is offline
post #321 of 321 Old 09-14-2013, 03:06 PM
Muamer Arapovic's Avatar
guys please! I have problem mit artec t14 ,I can't found driver and software for usb my OS is win7! need help please! smile.gif
Muamer Arapovic is offline
Reply Home Theater Computers
