Audio Processing in Vista Explained - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 972 Old 06-14-2007, 02:31 PM
iolaus's Avatar
Post withdrawn. I apologize for any personal insult. I hope this thread can get back on topic.
iolaus is offline
post #722 of 972 Old 06-14-2007, 02:46 PM
Nixie's Avatar
Originally Posted by iolaus View Post
Go buy $100K+ components that will give you all the pseudoscience B.S. you so obviously desire.
OK now I'm getting pissed off. I challenge you to bring up one example of pseudoscience I've mentioned here.
I don't buy anything. I design and build all my own audio equipment. I believe in the scientifically valid way to measure audibility of distortion known as double-blind triple-stimulus with hidden reference testing that the ITU prescribes. I am a skepting and a member of the Brights movement. Where do you see pseudoscience? I demand you back up your claims or else post an apology.
If you can't, then you're only helping those really promoting pseudoscience by making a hype over something that is not, and thus taking attention off them.
Your post was a massive failure. The issue of bit depth is very relevant, and though I'm not the one that brought it up, I defend my position simply because it is right, your ad hominem attacks notwithstanding. Those "trying to inform" you I will challenge if I see information presented as fact that is not. But apparently a cretinous imbecile like you fails to see this is actually to the benefit of those that need to be informed.
Nixie is offline
post #723 of 972 Old 06-14-2007, 03:06 PM
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
Ok guys, this thread is getting out of control, so please keep the topic extremely focused and more importantly keep the personal insults out of it. If you can't play nicely then I will be forced to shut down the thread.
Nothing is what I want - a true Zen saying.
Marantz AV7005 pre/pro cheap
Bob Sorel is offline
post #724 of 972 Old 06-14-2007, 09:03 PM
jimwhite's Avatar
you might as well close it.... it's become nothing but a pissing match between the technogeeks...
Jim White
St. Petersburg, FL
jimwhite is offline
post #725 of 972 Old 06-14-2007, 09:58 PM
Oppo Beta Group
RichB's Avatar
Quoted: 1273 Post(s)
Liked: 873
I have been skimming this thread and perhaps I missed it but I have an X-FI X-Treme music card with the latest drivers from Microsoft.
I do not see any options for Room correction. What am I missing?
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is offline
post #726 of 972 Old 06-14-2007, 10:52 PM
jj_0001's Avatar
Quoted: 152 Post(s)
Liked: 66
- Rich
Look in the audio control panel under the enhancements tab. You will not see room correction if you are using, for instance, headphones as your destination. You will have to have "loudspeakers" set in order to see room correction. If you do not see it then, it is possible that the manufacturer has either not supported room correction yet, or has chosen not to.
If you are using Microsoft class drivers, you should see the room correction box in the enhancements section.
James D. (jj) Johnston
jj_0001 is offline
post #727 of 972 Old 06-18-2007, 01:43 PM
jj_0001's Avatar
Quoted: 152 Post(s)
Liked: 66
I've just been told that in some cases a previous room correction profile may "stick" with you until you do "net stop audiosrv" and then "net start audiosrv".
If you see your room correction profile swapping between two values, (or more) try this.
jj_0001 is offline
post #728 of 972 Old 06-24-2007, 08:22 AM
videolover's Avatar
I have Vista home premium. Does only Vista ultimate do the room correction? If yes, how expensive is it to upgrade.
videolover is offline
post #729 of 972 Old 06-25-2007, 04:46 AM
rajdude's Avatar
I have two HTPCs running Vista Ultimate here.
One does and the other does not have the room correction thing.
From what I hear, it is the drivers which enable / disable this feature....not the version of Vista.
But I could be wrong.
-Rajiv
rajdude is offline
post #730 of 972 Old 06-26-2007, 01:01 PM
jj_0001's Avatar
Quoted: 152 Post(s)
Liked: 66
If you have a sound card that uses the class driver, or one where the manufacturer has activated our DSP's, you should be able to get it.
Look in the "enhancements" tab, but only when you have "speakers" set as output devices.
jj_0001 is offline
post #731 of 972 Old 06-26-2007, 01:02 PM
jj_0001's Avatar
Quoted: 152 Post(s)
Liked: 66
Out of curiousity, what are the sound devices on those two PC's?
jj_0001 is offline
post #732 of 972 Old 06-26-2007, 01:40 PM
rajdude's Avatar
Ok, but how does a mere mortal find out BEFORE he buys the soundcard whether it uses the "class driver" ???
Same for "where the manufacturer has activated our DSP's" ....how do we find that out ?
Or is there a list out there somewhere?
Lastly.....with s/pdif as the output....cant you still have room correction??
-Rajiv
rajdude is offline
post #733 of 972 Old 06-26-2007, 01:44 PM
df12's Avatar
No.
df12 is offline
post #734 of 972 Old 06-26-2007, 01:46 PM
rajdude's Avatar
The HTPC which does NOT have the room correction feature is the one with SB Audigy 2 ZS running latest drivers from creative's website
The HTPC which really has the feature has on board audio. The motherboard is Intel® Desktop Board DG965WHMKR
http://www.newegg.com/product/produc...82E16813121052
It has 8-channel (7.1) audio subsystem using the SigmaTel* STAC9271D audio codec and Dolby* Home Theater certification
more here
http://www.intel.com/products/mother...65WH/index.htm
-Rajiv
rajdude is offline
post #735 of 972 Old 06-26-2007, 02:21 PM
ronaldor9's Avatar
hello i am wondering with what method would i hook up my 5.1 speaker system which includes a receiver (using it as an amp) to my pc in order to get this feutre work since spdif will not owrk ??
ronaldor9 is offline
post #736 of 972 Old 06-26-2007, 02:24 PM
df12's Avatar
5.1 analog outputs from your soundcard to the 5.1 analog inputs on your receiver.
df12 is offline
post #737 of 972 Old 06-26-2007, 04:38 PM
jj_0001's Avatar
Quoted: 152 Post(s)
Liked: 66
Thank you. Unfortunately, I can't do anything about that. It's up to the driver manufacturer.
jj_0001 is offline
post #738 of 972 Old 06-26-2007, 04:40 PM
jj_0001's Avatar
Quoted: 152 Post(s)
Liked: 66
1) I don't know. It's very hard to find out. I don't have any better way to find out than you do.
2) Ditto.
3) We ought to start a list.
jj_0001 is offline
post #739 of 972 Old 06-26-2007, 04:41 PM
jj_0001's Avatar
Quoted: 152 Post(s)
Liked: 66
Originally Posted by df12 View Post
No.
Multichannel with SPDIF can not support room correction, as it's going to be very difficult to get the training sequence out to the room.
In theory, 2-channel using SPDIF would be possible, but then a variety of special cases are going to arise that are going to provide massive heartburn.
jj_0001 is offline
post #740 of 972 Old 06-26-2007, 10:31 PM
ronaldor9's Avatar
analog ive never used that to hook up an htcp to a reciever would you just use mini stereo to RCA analog cables but how does the receiver recoginze (or how would you know where to plug them into the receiver) from the sound card which is left channel or right and center and bass ?
post #741 of 972 Old 06-27-2007, 08:44 AM
df12's Avatar
If your sound card supports 5.1 then there should be a Green plug that is Front L and R. an Orange plug that is Rear L and R, and finally a Black plug that is Center and LFE. Those are usually 1/8" stereo jacks...
df12 is offline
post #742 of 972 Old 06-27-2007, 09:14 AM
jj_0001's Avatar
Quoted: 152 Post(s)
Liked: 66
With modern equipment that has jack sense, you'll also see a popup asking you what you just connected, and you can pick the proper outputs from the list. Each stereo miniphone will have two channels, usually LR, C/sub and LS/RS (and in 7.1 LR/RR). You can get cables (you can get fancy cables, or go to the likes of Home Depot and get quite functional cables for much less money, I don't want to get into cable wars here) that have the male stereo miniphone at one end, and two male RCA's on the other. Plug those into your 5.1 or 7.1 inputs as you assign and connect them.
You also will have to go to the control panel and tell it you want rendering in your choice of 5.1 or 7.1 using speakers.
jj_0001 is offline
post #743 of 972 Old 06-27-2007, 09:32 AM
ronaldor9's Avatar
thanks alot i might try out this feautre after building my htcp these forums are great im learning alot
thanks again
post #744 of 972 Old 06-27-2007, 09:57 AM
ronaldor9's Avatar
one last question then the male rca connectors would be hocked up to the dvd 5.1 analog option at the back of your receiver correct
btw why would this use analog if digital is much better and you would probably need a good osundcard if usisng this feature since its also doing decoding correct
thanks
post #745 of 972 Old 06-27-2007, 10:46 AM
df12's Avatar
I have a conspiracy theory about that. It has to do with the lack of a standard for PAP (Protected Audio Path).
There are "real" reasons too. Mainly S/PDIF doesn't have support for uncompressed Multi-Channel (5.1 +) PCM audio. So once you've manipulated the channel data to provide room correction and etc, you'd need to compress/encode it using DTS or DD. Most sound cards don't have the hardware necessary to do that on-the-fly.
df12 is offline
post #746 of 972 Old 06-27-2007, 10:56 AM
rajdude's Avatar
......while we are talking about jacks and cables, I just wanted to point out that some cards may have 4-pole jacks instead of stereo jacks. Mine does ! (Audigy 2 ZS)
That way it can do 7.1 from 3 jacks.
Of course one has to use special cables with 2-pole minijack to 3 RCA cables with them. A camcorder cable is ideal. See them here:
http://www.pccables.com/cgi-bin/orde...les.com&rcode=
How did I find this info?? Ok see it here:
http://www.avsforum.com/avs-vb/showthread.php?t=377573
-Rajiv
rajdude is offline
post #747 of 972 Old 06-27-2007, 11:53 AM
mrchung's Avatar
HD Audio, and USB audio class devices have class drivers built into the OS. To make sure you are using the class driver I believe you can "roll back" the driver to the class driver in the devices control panel (devmgmt.msc). It is really up to the device manufacturer if they want to enable the Vista sound effects so there is currently not a list I know of.
-Rian
mrchung is offline
post #748 of 972 Old 06-27-2007, 07:13 PM
jj_0001's Avatar
Quoted: 152 Post(s)
Liked: 66
Room correction does not work with SPDIF because all signals out of SPDIF that are multichannel must be encoded.
The encoding mucks greatly with the room correction probe system.
jj_0001 is offline
post #749 of 972 Old 06-28-2007, 04:04 AM
rajdude's Avatar
Ok so are you saying that:
The "class drivers" are the ones included with Vista.
-Rian
-Rajiv
rajdude is offline
post #750 of 972 Old 06-29-2007, 08:44 AM
hessel holland's Avatar
Howdy folks...what is a "class" driver and any widely available PC's that support this room correction capability?
hessel holland is offline
Reply Home Theater Computers
