Settings for connecting a PC to a 2006 Sony KDS-XXA2000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 39 Old 08-23-2006, 08:56 AM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 80
Here are my settings for a perfect 1080p pixel-matched desktop with ~2 pixel underscan on all sides.
MCE 2005
Nvidia driver version 91.36
Powerstrip 3.65
Nvidia Driver Resolution Timings for 1840x1016
HFP 88
HBP 224
HSW 48
Sync +
FE Active 1840
BE Active 1920
VFP 4
VBP 100
VSW 5
Sync +
FE Active 1016
BE Active 1080
Refresh 59.939
PowerStrip timing parameters:
1920x1080=1920,88,48,144,1080,4,5,36,148500,1
Generic timing details for 1920x1080:
HFP=88 HSW=48 HBP=144 kHz=68 VFP=4 VSW=5 VBP=36 Hz=60
VESA detailed timing:
PClk=148500.00 H.Active=1920 H.Blank=280 H.Offset=72 HSW=48 V.Active=1080 V.Blank=45 V.Offset=4 VSW=5
Linux modeline parameters:
"1920x1080" 148.500 1920 2008 2056 2200 1080 1084 1089 1125 +hsync +vsync
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
post #2 of 39 Old 08-23-2006, 09:53 AM
mpgxsvcd's Avatar
Quoted: 2763 Post(s)
Liked: 2460
Could you post some digital camera pictures of your Tv displaying the desktop or this web page? Just turn out all of the lights and use a longer shutter duration. I would love to see what 1080p 60 FPS really looks like.
mpgxsvcd is offline
post #3 of 39 Old 08-24-2006, 05:26 AM
btomasie's Avatar
I second that!!! If we could see some desktop pictures, that'd be excellent!! Thanks!
Could you also let us know what video card (which nVidia series) you're running? Seeing what kind of "horsepower" I'll need if I build a HTPC.
Brian
btomasie is offline
post #4 of 39 Old 08-24-2006, 08:40 AM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 80
Below are my HTPC's specs, I'll try and take some photos tonight.
Intel Pentium D 2.8GHz (Dell Dimension 9150)
4x512MB DDR2 @533
Intel 945 motherboard
Nvidia 7800GT 256mb PCIe
SB Audigy 2 output thru S/PDIF
1x160GB Seagate SATA
1x250GB Seagate SATA
Samsung 16X DVD-ROM
Pioneer 109 DL DVD-RW
Software:
OS: MCE 2005 (with roll-up 2)
Driver version: 91.36
Output resolution: 1840x1016
Add. enh:
Frontend: MCE 2005
DVD Player: TheaterTek 2.4.0
TV/PVR: MCE 2005
Video Codec: Nvidia 1.02.223
Video Renderer: VMR9 Renderless exclusive
Ffdshow version: 20060821 Yamagata
Fdshow filters used for DVDs [NTSC & PAL] (in order)
1. Resize (2.5x, Lanczos, 4-tap)
2. Avisynth
SetMTmode(2)
MT("mergeluma( removegrain(2,-1), 0.5 )",3)
MT("LimitedSharpenFaster(ss_x=1.0,ss_y=1.0,Smode=4,strength=100, overshoot=1)",3)
3. Output YV12
N3W813 is offline
post #5 of 39 Old 08-25-2006, 05:58 AM
btomasie's Avatar
any pics yet?
btomasie is offline
post #6 of 39 Old 08-25-2006, 06:01 AM
ctalbot's Avatar
1. Resize (4x, Lanczos, 4-tap)
2. Avisynth
SetMTmode(2)
3. Output YV12
N3W813,
Where did you get this version of Ffdshow? Thanks.
ctalbot is offline
post #7 of 39 Old 08-25-2006, 06:05 AM
jocktheglide's Avatar
do you think your HTPC is better than a regular stand alone player dvd player etc...?
jocktheglide is offline
post #8 of 39 Old 08-25-2006, 09:38 AM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 80
Originally Posted by ctalbot View Post
N3W813,
http://www.ffdshow.info
Most definitely, especially through the use of ffdshow to post-process the DVD image. With well mastered DVDs, the image is almost comparable to some 1080i sources.
Originally Posted by btomasie View Post
any pics yet?
I was going to take some last night, but found out my camera was out of battery. I will take some this weekend when I can pull myself away from my tv.
N3W813 is offline
post #9 of 39 Old 08-25-2006, 10:09 AM
what is ffdshow? I got a toshiba laptop with HD dvd drive in it just curious anything to make things better than they are LOL...
post #10 of 39 Old 08-29-2006, 06:58 PM
silwenae's Avatar
Thank you for the modelines, I really appreciate it!
Paul
silwenae is offline
post #11 of 39 Old 10-09-2006, 02:02 PM
btomasie's Avatar
N3W813,
woul dyou be able to post with the steps that you took to actually get this to display on your A2000? For example, did you set up PowerStrip with all this ahead of time on a regular monitor, and then rebooted and then connected your A2000 up to your PC?
Basically looking for the detailed steps that you took to go from a traditional display to the A2000?
Thanks much!!!
Brian
btomasie is offline
post #12 of 39 Old 10-11-2006, 05:35 AM
anthonybay's Avatar
I have a Sony computer which has a Nvidia video card inside. The card has dual output capability via a Vga and a Dvi-a jack. I can't seem to locate anyplace that makes a Dvi-a (the plug that has 4 pins around the ground lug) to a vga to make this connection.Sony e-mailed me to say that no such wire exists! I tried using a Dvi-a to hdmi cable on a different input and the picture was a double image sitting slightly on top of each other vertically as well as being to large for the screen. Help!
anthonybay is offline
post #13 of 39 Old 10-11-2006, 08:38 AM
bdub12's Avatar
I don't know if this is the right forum, but when Microsoft upgrades the XBOX 360 to 1080p, will a VGA connection finally fill the a2000 screen? Currently, the VGA out on the 360 does not fill the screen on the a2000.
I know that some people with OSX can fill the screen through the VGA input.
Thanks for any info.
Fredericton, NB Canada
bdub12 is offline
post #14 of 39 Old 10-11-2006, 05:11 PM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 80
N3W813,
Thanks much!!!
Brian
Didn't do anything special....
1. Connect PC to TV with DVI-HDMI cable
2. Boot PC, change resolution to 1920x1080
3. Used Nvidia's overscan tool to adjust for overscan
4. Created 1840x1016 custom resolution
5. Installed PS
6. Reboot
7. Adjust refresh rate in PS to 59.94
I never had to connect a monitor first before connecting to my TV.
N3W813 is offline
post #15 of 39 Old 10-25-2006, 07:29 PM
mrpoune's Avatar
Hello,
I have a A2000 50 inches.... I am trying to setup my TV so that i can play NHL 07 on it.... the thing is (even with your timings), I miss the score bar on top when playing.
what can I do? What causes this?
Fred
mrpoune is offline
post #16 of 39 Old 11-27-2006, 07:36 AM
jmv
jmv's Avatar
I am not sure if I am doing anything wrong, but I used these settings on my ATI 9800 and I still get the normal 1920x1080 with 30~50 Pixels of overscan in each direction/each corner...I think N3W813 is correcting in the Nvidia driver rather than the Powerstrip parameters...does anyone have a 2~3 Pixel overscan settings for Powerstrip that doesn't use the ATI/Nvidia driver to correct? I have a tempermental card that took 3 hours to convince to display at 1920x1080, so I am afraid to try tweaking on my on
mv
jmv is offline
post #17 of 39 Old 11-28-2006, 08:01 AM
jmv
jmv's Avatar
bump--anyone?
jmv is offline
post #18 of 39 Old 11-28-2006, 11:14 AM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 80
Yes, I did use Nvidia's custom resolution applet to correct overscan. I tried using powerstrip but could not get my desktop centered correctly.
Sorry.
N3W813 is offline
post #19 of 39 Old 12-02-2006, 09:54 AM
jmv
jmv's Avatar
Well tossed the aged (2 year old ?) HTPC setup that took 3 hours to convince to playback on the A2000 (finally got 1080P with 30~50 pixel overscan on all corners). This was ATI 9800 based with DVI to HDMI, latest released drivers. Would only display once it got to the desktop (ie no dos boot screens etc.)...one other quirk with this machine is that if it sat idle it would hibernate even if I told windows to Never hibernate...that is working correctly with the new HTPC too...
Shiny new HTPC with E6700 Conroe and Nvidia 7600GT vid card...boots up first time plugged in through DVI to HDMI and I see the DOS boot screens, window logo and finally the desktop. Desktop came up as 720P...set Nvidia to 1080P and bang...worked. Used the Nvidia TV settings to reduce overscan to 2~5 pixels in all directions...final desktop resolution is 1840 x 1028 pixel perfect.
Did an A/B vs. the old HTPC and the picture looks slightly better with the 7600 (colors cleaner). But the real important part is this vid card knows this is a HDTV and keeps the resolutions friendly to the TV.
jmv is offline
post #20 of 39 Old 12-04-2006, 03:29 PM
The Canuck's Avatar
Lol you could've gotten away with just a $30 6200, but upgrading to the latest stuff is always fun! After shelling out $2k for the TV I don't think the wife will be letting me buy anymore high end stuff for a while....
The Canuck is offline
post #21 of 39 Old 12-05-2006, 02:53 PM
ESPNSTI's Avatar
Quoted: 24 Post(s)
Has anyone had any luck with NVidia 97.02 drivers for a 8800 GTS/GTX on XP Pro?
I get overscan, and I can't seem to get to any of the customization options in PS.
Creating an NVidia custom resolution didn't seem to have any effect either.
ESPNSTI is offline
post #22 of 39 Old 12-07-2006, 01:51 PM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 80
Same problem here.
Just upgrade my video card last night to 8800GTS. Now I cannot add any custom resolutions, the drivers always say failed when testing the new rez. Tried PS, cannot even access the advanced timings option. The developer of PS said in their forums that the 8800 is not supported.
Now I got overscan that I cannot get rid of unless I change service menu settings on my TV. But that's something I don't want to do because it'll lose 1:1 pixel mapping.
N3W813 is offline
post #23 of 39 Old 12-12-2006, 06:45 PM
ESPNSTI's Avatar
Quoted: 24 Post(s)
Same problem here.
The new 97.44 drivers have fixed most of the problems for me.
The "Resize or pan HDTV desktop" option under "Video & Television" in the new control panel worked for me now.
The full screen video (only available in the classic control panel) seems to have a 4:3 aspect ratio now though.
There are two not so ideal workarounds for it that I found:
- Shut off full screen video, set your primary display to 1920x1080 and use clone mode. Downside: your primary display might not handle 1920x1080. (Mine is 1680x1050 max.)
- Use ffdshow and force the overlay aspect ratio to 1.78. Downside: 4:3 video will stretch.
ESPNSTI is offline
post #24 of 39 Old 12-13-2006, 09:48 AM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 80
I reinstalled my OS, and then installed 97.44.
All is well now. Overscan compensation and custom resolutions are working again.
N3W813 is offline
post #25 of 39 Old 12-15-2006, 12:55 PM
ESPNSTI's Avatar
Quoted: 24 Post(s)
Ugh... Well that didn't last long.
I think it only worked that one time after I just installed 97.44.
I think it lost its mind after the reboot and went back to "pick any resolution and I'll overscan it for you" mode.
After a whole bunch of work (driver cleaner pro, manual registry clean, etc..) I got it to work once more, but sure enough, it went right back to old behavior right after the reboot.
Going back to a saved restore point didn't work either.
ESPNSTI is offline
post #26 of 39 Old 01-01-2007, 04:12 PM
Rook_1's Avatar
any update on this? I'm considering an A2000 as my next set and I want to make sure that I can setup a PC on it properly. This thread tells me that its very possible, but it seems people are having problems, I'm curious to see if its still doable.
Rook
Yarr!!
Rook_1 is offline
post #27 of 39 Old 01-06-2007, 09:42 AM
Geronimo.USMC's Avatar
Quoted: 153 Post(s)
Liked: 96
I want this tv for htpc. Any updates?
SOUND: 7.2 via Marantz AV8802A | Wyred4Sound monoblocks + Halo A51 | Paradigm 100'sV5, ADP590'sV5, 690v5, 20v5's | Dual SVS SB16-ULTRA Subs
VIDEO:
SONY OLED 65A1E | OPPO UDP-203 and SONY UBP X800 UHD Blu Ray Players
- 40TB of Blu ray .iso's in a Synology DS1815+ controlled by a Dune Solo 4K
- HTPC/Gaming Rig:
Silverstone CW02B, Core i7-5820K, ASUS X99-A, 16GB, EVGA GeForce GTX 1080 SC GAMING ACX 3.0, Auzen HDMI XFi
Geronimo.USMC is offline
post #28 of 39 Old 01-12-2007, 04:49 PM
Kompleat's Avatar
After upgrading to a 8800 GTX I was not able to get my custom resolutions to work either. I am using the 97.44 drivers. I had previously installed the 97.02 (I think) drivers and they were not able to set any custom resolutions either.
I have a different TV that still gets 1:1 pixel mapping but of course there is overscan without the custom resolution.
Kompleat is offline
post #29 of 39 Old 01-13-2007, 12:20 AM
crisscross's Avatar
I can confirm that though the new 97.92 drivers are supposed to fix some other bugs the resize bug is still there on 8800-series. I would love a solution for this....
crisscross is offline
post #30 of 39 Old 01-14-2007, 09:40 AM
crisscross's Avatar
Good news! I found one driver for nvidia 8800-series where the overscan correction works and it is Forceware 96.89. I dont know if other functions of the driver is crippled, not teted yet, but this was most important to me.
http://downloads.guru3d.com/download.php?det=1505
Reply Home Theater Computers
