Need help for a new HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-28-2006, 06:49 PM - Thread Starter
frederic's Avatar
I want to build a new HTPC - mine is 3 years old now and it is more than time to build a new one (and I finally have some money to put into it).
Unfortunately a lot is confusing to me now - and I am thinking you guys can help me (if you can not then probably nobody can ;) ).
My HTPC is used for storing music - watching and recording TV - watching movie and playing video game. It is connected to a SONY HS20 PJ.
Here is what I am looking for:
- case - probably a sylverstone lascala one. This is an easy decision - no issue there.
- CPU - dual 2 core (e6600) - I have a D2C laptop (Del M90) and it is almost impossible to max out the cpu - so I am thinking this will be great.
- Motherboard - that is the very hard part - it seems no good MB are available yet - I am not impressed with the intel chipset (not enough connectivity) and it is exepnsive. I want 10 USB2 - at least 8 SATA (6 for HD) and 2 for DVD drives - I want at least one eSATA port as well - I want a 7.1 sound output (I would like to avoid buying a soundcard - not required for Vista MCE) and digital audio output.
I though NVidia will come out with some good chipset for D2C but it does not seem to be the case yet - should I wait more?
- HD - at least 4 (500GB Minimum) HD - noise has not be an issue before but if I can get some silent one at a decent price I would consider them.
- Video card - a top of the line directX9 card - this is why I thought now would be a good time to build the new HTPC. Since DirectX 10 will be out very soon - the current top of the line should be more affordable. I am OK to pay 300$ for it. I want an ATI one as well (better image quality) with an HDMI output - a Dual DVI as well. Of course it needs to be HDCP compliant.
So as you can see - I have a feel for what I want - but I dont know what specific hardware to buy - in particular a good motherboard has been impossible to find so far. Should I wait more to get the new Nvidia based mobo?
Please help me figure out what are the best HW options for me today.
Thank you,
Frederic
Always looking for a better home theater system...
frederic is offline
post #2 of 10 Old 10-29-2006, 12:05 PM - Thread Starter
frederic's Avatar
Any help with the motherboard question in particular?
Once I got that one figured out the rest will follow.
Please advise,
F
frederic is offline
post #3 of 10 Old 10-29-2006, 08:58 PM
hdmi4ever's Avatar
Quoted: 18 Post(s)
Why do you need 10 USB on the motherboard? Just get a hub or hubs that will add the number of USB ports that you need. Or a PCI card that provides additional ports.
hdmi4ever is offline
post #4 of 10 Old 10-30-2006, 11:04 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
10 USB2.0 implies either Intel P965/G965 with southbridge ICH8/ICH8R or NVIDIA nForce 590 SLI (C19SLIX16 + MCP55). Among the motherboards with these chipsets, only one board meets the criteria: 8 x SATA and 1 x eSATA:
ABIT AB9 Pro
that comes with 10 x USB2.0, 9 x SATA, 1 x eSATA, 7.1 HD audio and optical S/PDIF in/out. The board got positive reviews at various hardware review sites. Please look at the sticky thread "Core 2 Duo (Conroe & Merom) Motherboard List - With a Short Guide to Chipsets" and in particular the attached spreadsheet for details.
The new NVIDIA chipsets are nForce 650I/680I SLI (will be released in December). The northbridge is the new C55. This is basically for gamers and I don't think it's particularily better than Intel chipset for HTPC.
If you use an SATA PCI (or PCI-E) controller for additional storage (around $20), you can choose several other boards, for example, ASUS P5B-E, P5B Deluxe. You should also consider AMD Athlon 64 boards. You won't see any difference between C2D and Athlon 64 for normal HTPC usage.
renethx is offline
post #5 of 10 Old 10-30-2006, 11:40 AM
umdivx's Avatar
Here's a good running list of mobo's supported by the new intel chips:
http://www.avsforum.com/avs-vb/showthread.php?t=710828
Segate or samsung seem to be the best choice.
What makes you think ATI has better image quality? Also you won't find a video card that has HDMI and dual DVI. It'll either be HDMI and DVI, or HDMI and VGA, or Dual dVI.
Here's a running list of HDCP supported video cards:
http://www.hardforum.com/showthread.php?t=1071342
I think what your looking for in a mobo is a ways away still but I could be wrong, but specifically on the intel side, things like that tend to go extremely slow.
- Josh
umdivx is offline
post #6 of 10 Old 10-30-2006, 11:56 PM - Thread Starter
frederic's Avatar
Thank you so much for your responses.
I will look into the ABIT AB9 Pro and into the different HDCP video cards.
Does anyone knows when I could expect motherboards with the new NVidia chipset? I am just looking for a rough estimate.
PS: the USB2 ports are for all sorts of gadgets - in particular for gaming - I usually have 5 or 6 pluged in at any time - so I thought 10 would be great - but 8 would be fine too. I so much wish the wireless USB standard would be ready by now ;) - that would really clean up my room... But I think it will only be ready by the end of 2007 or early 2008 - so I am not going to wait for it.
frederic is offline
post #7 of 10 Old 10-31-2006, 01:17 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
More NVIDIA nForce 600 Series Details Revealed (Daily Tech):
NVIDIA is set to release its upcoming nForce 600 series of chipsets in the first half of November.
DFI's Q3, Q4 Desktop Products:
DFI LANPARTY UT NF680I SLI-T2R/G, December 2006. This borad has 8 SATA ports (6 from nForce 680I and 2 from SiI3132) but no eSATA.
renethx is offline
post #8 of 10 Old 10-31-2006, 03:43 AM
hdmi4ever's Avatar
Quoted: 18 Post(s)
You can connect over a hundred USB devices if you get a hub. So you'll be unnecessarily restricting your choice of motherboards if you require 10 USB2.0 on the motherboard itself.
post #9 of 10 Old 10-31-2006, 05:57 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Even if the condition 10 x USB2.0 is removed, ABIT AB9 Pro is the only C2D board that comes with (at least) 8 SATA and 1 eSATA.
renethx is offline
post #10 of 10 Old 10-31-2006, 09:04 PM - Thread Starter
frederic's Avatar
I have looked at the ABIT AB9 Pro - it is very much what I was looking for.
Thank you very much for pointing it out to me.
Since the new NVidia are coming out in the next few days with their new chipset - I will wait a little bit to see how they turn out. But otherwise I think I just found my next mobo.
Thank you,
F
frederic is offline
Closed Thread Home Theater Computers
