New FusionHDTV Software - Page 37 - AVS Forum | Home Theater Discussions And Reviews
post #1081 of 1809 Old 02-20-2008, 10:56 PM
KAXKID's Avatar
Originally Posted by img eL View Post
Having the ability with two Dvico tuners to veiw two main screens with the FusionHDTV software is my furture feature request #1
dvico gave up being able to run two versions of fusionHDTV way back in 2005 as i recall. when the f5usb was first introduced there was a separate version for pci tuners and the usb tuner(version 3.12?), but it was quickly changed to run everything in one version with pip.
KAXKID is offline
post #1082 of 1809 Old 02-20-2008, 11:12 PM
ClarenceR's Avatar
Originally Posted by cdcooker View Post
Two weeks after Chinese New Year now, still no new version of FusionHDTV from DVICO web site. Any updates? Thanks
DVICO's page posted 3.66.01 a few days ago (bottom of page, button labelled "Download).
ClarenceR is offline
post #1083 of 1809 Old 02-21-2008, 07:04 AM
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
That's easy--just get two computers.
TPeterson is offline
post #1084 of 1809 Old 02-23-2008, 05:47 AM
img eL's Avatar
Does BeyondTV have the ability for 2 seperate screens?
img eL is offline
post #1085 of 1809 Old 02-23-2008, 07:09 AM
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
BTW, this version has fixed the QAM channel-scanning bug that was introduced starting with version 3.64.
post #1086 of 1809 Old 02-23-2008, 07:51 AM
sengsational's Avatar
How do the various versions rank on crashing when the recording ends? It seems to be happening, oh, maybe 10% of the time with 3.60 on my system. Would I do significantly better with an upgrade?
--Dale--
sengsational is offline
post #1087 of 1809 Old 02-23-2008, 10:22 AM
jldet5's Avatar
--Dale--
Let me put my 2 cents in and say I was terribly unhappy until 3.63.01. For OTA that version has been perfect with dual tuners. So perfect that I've been resisting the urge to go to the 3.66.01 however I think I will try it since my fusion 7 is on the way.
jldet5 is offline
post #1088 of 1809 Old 02-23-2008, 06:31 PM
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Dale, I'm seeing far fewer crashes than 10% of captures but I haven't kept statistics on crash frequency with version number. In any case, I'm pretty sure that you won't see things go in the wrong direction crashwise with the newest version.
post #1089 of 1809 Old 02-26-2008, 02:53 PM
img eL's Avatar
Can u get a full screen display with tsbrowser2?
img eL is offline
post #1090 of 1809 Old 02-26-2008, 02:55 PM
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Why would you want to? TSBrowser is a diagnostic tool not a player app.
post #1091 of 1809 Old 02-26-2008, 03:55 PM
cdcooker's Avatar
Thanks. It is so strange that this new version is not showing on the ATSC download page.
cdcooker is offline
post #1092 of 1809 Old 02-26-2008, 05:42 PM
Well, I upgraded, and no crashes yet, but my files are named something weird, and I don't know how to fix that. After I schedule through CW_EPG, the file name looks right in CW_EPG_RECORDS, but when it records, the file that gets created has a format like "2008-02-26(Tue)PM080000..." then followed by the correct file name "...AD-46-080206-2000-Show Name-Episode.tp". I can't find anywhere to alter that setting in the Fusion UI.
--Dale--
post #1093 of 1809 Old 02-26-2008, 07:02 PM
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
The setting is "hidden" on the Manual Scheduler dialog. My only quarrel with that placement is that they enabled it by default.
post #1094 of 1809 Old 02-26-2008, 07:03 PM
jldet5's Avatar
--Dale--
Theres a checkbox to unclick in the recording scheduler panel of Fusion.
jldet5 is offline
post #1095 of 1809 Old 02-26-2008, 07:04 PM
jldet5's Avatar
I've got to learn to type faster.
jldet5 is offline
post #1096 of 1809 Old 02-26-2008, 09:42 PM
cdcooker's Avatar
I downloaded and installed the latest driver, but I got an error message of AUTHENTICATION FAILED AT DECODER when I tried to launch the FusionHDTV application. I have FusionHDTV Gold 3 T PCI card. I picked the right card during the installation process. Any idea what went wrong here?
I ran the 3.63.01 exe file, and choose uninstall driver. Then reboot the computer, and went to Control Panel's Add Remove programs to uninstall FusionHDTV. Reboot. Then run the 3.66.01 exe. Reboot. Run the FusionHDTV app and got the error message.
cdcooker is offline
post #1097 of 1809 Old 02-26-2008, 10:44 PM
KAXKID's Avatar
looks like an unsuccessful remove/install process. in these newest versions, the driver has to be removed via the "add/remove" module first. try it again, here's a link to my process with some recent additions:
http://www.avsforum.com/avs-vb/showp...postcount=2281
KAXKID is offline
post #1098 of 1809 Old 02-27-2008, 03:08 PM
After much gnashing of teeth, I finally clicked on EPG (never needed to before since I use exclusively CW_EPG). I clicked on every other thing in the whole dang program before trying this. I never wanted to go to the lame-o EPG sent by the stations! But finally, since it was literally the only button I had not tried, I gave it a shot. There I found an unnamed dialog with a "Manual Record" button! Am I getting warmer or colder? Clicking that button takes me to "Manual Reservation" dialog and where I expect a drop-down for how to name files (like MyHD and CW_EPG have). Instead I find two checkboxes on that screen: "Scheduled Watch" and "Automatic Date Maker". If you guys had not just told me "Manual Scheduling Dialog" and "recording scheduling panel", I would have clicked away in frustration. But I thought about it and concluded that if the checkbox is "checked" under "Automatic Date Maker", it screws up the file name such that it starts to look like this: 2008-02-26(Tue)PM080000AD-46-080206-2000-Show Name-Episode.tp, and if the "Automatic Date Maker" is UNchecked, the file name will look like this: AD-46-080206-2000-Show Name-Episode.tp. So any reason this is not under the wrench, where it should be?
--Dale--
post #1099 of 1809 Old 02-27-2008, 03:17 PM
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
None that I can think of...but I didn't code this app.
post #1100 of 1809 Old 03-12-2008, 06:29 AM
BCCISProf's Avatar
I am using a FusionHDTV5 Express with 3.63.01 OTA only (NY area) for quite some time and it generally works well. The following issue has me baffled (and it may or may not be a problem with the software/hardware).
According to Titan TV WJNDT (PBS) is 51.1-51.5 (55). Using a setup box, that is indeed where it is found. However, the Fusion software after scanning finds 50.1 50.3 50.4 50.5 (and no 50.2). Which contains the same program material.
The problem is when recording. Titan TV obviously records the wrong material since it saves the program as 51.x (which is where it thinks the channel is) and then the software ends up recording channel 5.
If I tune to 50.3 it displays what is supposed to be on 51.3, but on the controller it shows 50.2 (whose corresponding 51.2 has nothing scheduled). And if I manually record. It records the correct program. If I set a scheduled record to 50.3 it records 50.1.
I hope I explained this clearly --
Thanks for any pointers.
BCCISProf is offline
post #1101 of 1809 Old 03-12-2008, 09:17 AM
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Could you post the HTML ("all") summary of TSReader Lite's analysis of a full-TS sample from that station? (You can use, e.g., TSBrowser2.exe from the DViCo FTP site to capture the full TS data stream) That will show us possibly what's wrong with the PSIP from that station and give you some ammunition to contact them about correcting it.
post #1102 of 1809 Old 03-12-2008, 11:53 AM
BCCISProf's Avatar
First of all thank you for responding so quickly.
I couldn't get TSBrowser to work....is there an instruction readme file somewhere?
I did do the following:
1. Using the Fusion software I saved a 1 minute .TP file unchecking "Current subchannel only" from what Fusion shows as channel 50 (NJN)
2. Using TSReader I exported the HTML "All" and attached it here.
3. Attached it as a zip file.
I must say I do not understand it... but maybe you will be able to make sense of it.
Thanks again.
Channel50.zip 5.6845703125k . file
post #1103 of 1809 Old 03-12-2008, 12:29 PM
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
Thanks! The "trick" with TSBrowser2 is to put the exe in the FusionHDTV Program Files folder and then open it. But unchecking the Current Subchannel Only box, if you can, should be just as good. And in this case that's so.
The TVCT section in your attachment tells the tale:
Terrestrial Virtual Channel Table
Channel 3
Service Name: WNJN-DT
TSID: 2007 (0x07d7) NTSC: 50 ATSC: 51 NJ MONTCLAIR
Channel Number: 50.1
I.e., FusionHDTV is right and TitanTV is wrong. WNJN-DT is identifying itself (correctly) in the PSIP as "50.1". This is the usual convention for virtual channels, generally they go by the "traditional" NTSC number for the major channel designation.
You can notify TTV and/or WNJN of the error in the TTV listings and maybe they'll fix it, or you can start using CW_EPG for scheduling and just give up on TTV.
post #1104 of 1809 Old 03-13-2008, 03:03 PM
BCCISProf's Avatar
Channel 3
I think I understand. However, what is confusing to me is that on two different setup boxes feeding an ordinary TV, when scanning for OTA channels it comes up as 51.x rather than 50.x Can it be that those two units get their channel numbers from the ATSC info rather than from the NTSC info? Why would WNJN identify itself with both numbers?
Can you suggest a reference for me to read regarding this whole topic? As usual, I am grateful for your answers.
Thank you.
post #1105 of 1809 Old 03-13-2008, 03:29 PM
TPeterson's Avatar
Quoted: 261 Post(s)
Liked: 31
They're evidently displaying the actual rf channel number (51) rather than the virtual-channel ID. Unless they do that for all channels, I imagine that there's something about WNJN's PSIP that's causing them confusion. But the TVCT information clearly shows that WNJN's engineers intend for their broadcasts to be known as "50.x" not "51.x".
I recommend Michael Isnardi's DTV tutorials, which you can find here, as very clear expositions of all the nitty gritty.
post #1106 of 1809 Old 03-14-2008, 06:38 PM
tencom's Avatar
I can't get TS browser to open, with Fusion v3.66.01, is it bo longer compstsble with current versions of Fusion software?
tencom is offline
post #1107 of 1809 Old 03-14-2008, 08:13 PM
KAXKID's Avatar
check the ftp site for the version posted 1/28/08.
KAXKID is offline
post #1108 of 1809 Old 03-29-2008, 06:54 PM
jldet5's Avatar
All you VISTA guys think twice before installing SP1. I think you'll find your very unhappy with the Fusion problems. Something to do with VMR and floating point errors.
jldet5 is offline
post #1109 of 1809 Old 04-15-2008, 09:43 AM
steedums's Avatar
I have an issue with fusionhdtv where if anything goes fullscreen or if you do ctrl+alt+del and open up the task manager, fusionhdtv crashes. Media center works fine though. Any ideas? I have version 3.63.01 running on vista home premium.
steedums is offline
post #1110 of 1809 Old 04-16-2008, 07:47 PM
landofmu's Avatar
Just spotted
ftp://ftp.dvico.com/Products/FusionH...3.67.01Web.exe
<< Changes in Rev 3.67.01 official version >>
1. With Single tuner and Vista SP1, the problem of the floating point error was fixed.
- The Multi card of the Access violation problem didn't fix yet.
We recommend you to uninstall the Vista SP1 if you have a Dual tuner.
- We'll release fixed version as soon as possible.
2. The Full stream EPG of Australia has been supported.
3. The problem of MSVCR71.DLL error while using multiple recording was improved.
4. The Native MPG function was removed.
- To use the digital MPEG format, please refer to below link.
[ How to use the Digital MPEG ]
5. The 'Use DirectSound Audio' option for analogTV was added.
6. Fixed other minor bugs.
Guess I'll check it out
landofmu is offline
Reply Home Theater Computers
