New FusionHDTV Software - Page 60 - AVS Forum
AVS Forum > Video Components > Home Theater Computers > New FusionHDTV Software
TPeterson's Avatar TPeterson
09:40 AM Liked: 18
post #1771 of 1797
12-21-2011 | Posts: 11,960
Originally Posted by ccrider2 View Post
I can't get WRTV RF25 in Indy since they went to 3 subs. It comes in good on my other tuners. It's not found when you do the scan. Was working, till I re-scanned to add 6.3......now nothing. Got to be an issue with the card's sw and WRTV's 'modified method' (480i 16:9 on 2 subs 720p 16:9 on one sub) .....
Chris, if you--or someone else reading this--could capture a couple-minute clip of the full transport stream from WRTV rf25 we can get it to Minevox (formerly DViCo) for analysis to help them produce an updated FusionHDTV to fix the problem. If the only PC tuner available is the Fusion one you could try using the free version of TSReader for the capture, as that allows up to one minute of recording, which may be enough sample.
EDIT: Oops, I just re-read the TSReader description that I linked above and see that the full-TS recording ability is limited to the $99 standard version and that the free one will only record one program from the stream, so that won't work.
Also, I re-read your post and see that FusionHDTV was properly handling the TS until its channel-scanning subroutine got invoked. In that case, if you have a saved version of the Fusion branch of the Registry (from the "Save" button on the Configuration window) you could try using that to restore the channel setups.
09:51 AM Liked: 18
post #1772 of 1797
Another edit: There is a DViCo utility that can capture the full TS of OTA channels...I'm not remembering its name at the moment, but that could be used here to capture a sample for Minevox analysis.
That old utility is called TSBrowser2.exe and it's still on the DViCo FTP site here. It's not very user-friendly and comes with no instructions. You install it by copying the exe to the folder where you've installed FusionHDTV and then running it from there. I didn't verify that it still works with the current FusionHDTV version, however. (If you're going to go down this road, let me know and I'll confirm that point)
ccrider2's Avatar ccrider2
01:46 PM Liked: 15
post #1773 of 1797
12-21-2011 | Posts: 561
Well TP, Man You're Good....
Before I read your first "edit", I tried to figure out how to record with TSReader Lite. That is, how to change the the tuner device, as I've always used the Fusion for that purpose. Bam!.....WRTV now works.
Thanks for the 'wave of your wand'!
Chris
PS: Does clicking 'OK' on the 'Configuration Menu' also save to the same Registry location? (Just so I'll know in the future..... to click 'Cancel' after a bad channel scan)
In other words; Does 'Save' and 'OK' do the same thing?
Again, Thanks For Your Time
04:12 PM Liked: 18
post #1774 of 1797
Glad to hear that it's "fixed."
Actually, Save and Load respectively "save" a copy of the FusionHDTV Registry branch to the FusionHDTV Program Files folder and "load" the saved copy in that folder back into the Registry. You can keep safe that copy (or many copies) from accidental overwriting by moving it to a subfolder and/or changing its name from config.reg to something more descriptive. The OK button, OTOH, writes any changes that were made in the configuration since opening the Configuration window to the current Registry branch.
06:47 AM Liked: 15
post #1775 of 1797
12-22-2011 | Posts: 561
Thanks TP,
SAVE always confused me, as it never gave me the opportunity of 'where'.
Keith's Avatar Keith
01:38 PM Liked: 10
post #1776 of 1797
03-25-2012 | Posts: 276
Has anyone tried other software to run the Fusion HDTV 5 USB Gold with software
such as DVBViewer, Transedit or TS Reader ?
02:13 PM Liked: 18
post #1777 of 1797
03-25-2012 | Posts: 11,960
TSReader will work, as will WMC.
03:09 PM Liked: 10
post #1778 of 1797
after i made the above post, I got DVB Viewer, Transedit and TSReader to work,
but only with OTA ATSC signals, now I have to figure out how to make the software
work with Clear QAM-256 signals..
hziemba's Avatar hziemba
08:00 PM Liked: 10
post #1779 of 1797
04-09-2012 | Posts: 59
I sometimes have a problem where a recording is very choppy, both the video and audio - like skipping words. In a worst case, there is no video, or an occasional frozen scene. It has happened on all 3 major networks' shows. Sometimes the recordings are fine.
I have version 3.68, and running WinXP-SP3. The hardware is Fusion 5 USB.
My guess is that something in a Windows patch is interfering with the Fusion driver, but I'm not sure.
Any ideas?
09:11 PM Liked: 18
post #1780 of 1797
04-09-2012 | Posts: 11,960
Hziemba I don't know anything about your specific problem but that is a pretty old version of the Fusion app! I suggest that you try the latest and greatest version, 3.91 and see if it fixes any of your problems .
09:05 PM Liked: 10
post #1781 of 1797
05-03-2012 | Posts: 59
I updated to 3.91, but problem is still there...let me elaborate...
For months now, recordings have been less than the show time...a 1 hr show ends up looking like 40 minutes or so on the counter, though it actually does run the full hour...that's when it does record.
Some stations record OK, but some almost never record normally - they are barely watchable because the video and audio skip, and sometimes the counter moves forward in 2 sec increments. That skipping is sometimes there when watching live on the computer.
BTW, I'm connected to cable TV,and these are unencrypted channels.
One suspicion I have is that the signal level has gone down over the months. What kind of numbers should I be seeing in % and dB?
09:33 PM Liked: 18
post #1782 of 1797
05-03-2012 | Posts: 11,960
A decent cable connection yields signal levels of "100%" with dB values of 27 or more. If you see less than 90% your cable signal is suspect.
Based on your description of the live TV performance, I agree that poor cable signal is a very likely cause of your problems.
tranle's Avatar tranle
10:28 PM Liked: 14
post #1783 of 1797
05-04-2012 | Posts: 550
For me the 3.91 version does not detect my audio channel correctly. Out of my 5.1 speakers it only think I have a 2 channel. But the version 3.90 work fine.
Using it on win7 64bit.
10:55 PM Liked: 18
post #1784 of 1797
05-04-2012 | Posts: 11,960
Originally Posted by tranle View Post
.... But the version 3.90 work fine.
Then I would use 3.90, since the differences are generally minor and, IIRC, mostly relate to improving tuner action on a few models. I'm surprised to hear that there are any changes to audio.
SFischer1's Avatar SFischer1
12:09 PM Liked: 29
post #1785 of 1797
01-14-2013 | Posts: 2,047
http://www.avsforum.com/t/369015/san-francisco-ca-ota/9090#post_22827800
KKPX PSIP 65.1 RF 41 has messed up PSIP causing Fusion7USB and Fusion7Dual and Fusion5 RT GOLD  to abort when selecting KKPX.
As there are many ION stations this may be seen in other areas.
Larry and Nani:
I don't know what's up with your FusionHDTV7 installations. I was prepared for the worst, since I know that KKPX' screwball subchannels are crashing TViX tuners (made by the same company as FusionHDTV and, therefore, having some related software), but I found that my FusionHDTV7 USB tuner doesn't crash when tuning any of the KKPX OTA subchannels, even the encrypted ones (although the latter show only a black screen, of course).
The FusionHDTV app is notoriously fragile, however, so I suspect that something has broken yours and the two of you do need to reinstall it, as Nani suggested. I would try using the "repair" option that's presented in a reinstallation.
Hi,
In this case (YMMV) I have found a method of restoring FusionHDTV to live normal operations. (Fusion7Dual)
EDIT: On some systems a simple computer reset may be all that is needed.
When KKPX is selected Fusion aborts.
Restarting Fusion "SIGNAL: -1% 0" is shown for all stations and a black picture / no sound appears.
1) Drag a .tp file to the Fusion icon. File should play normally.
2) Click on the screen to display the Fusion control panel.
If you can start Fusion by another way without it aborting, then the file play method is not needed.
3) Click "Live". You will get the "SIGNAL: -1% 0". Click on the channel number and select a different strong station than KKPX.
4) You will get the "SIGNAL: -1% 0". Close Fusion.
5) Restart your computer.
6) Click on the Fusion Icon. You should get a normal live picture and sound.
Repeat if you wish by selecting KKPX, the above procedure can be used to restore normal live viewing again.
 A channel rescan can be saved in the registry by clicking on the "SAVE" button.
First click "OK" to really save the Fusion settings, "SAVE" does not save the settings.
SHF
12:58 AM Liked: 18
post #1786 of 1797
01-15-2013 | Posts: 11,960
My experiment above was performed under Win7 (64 bit). At Nani's suggestion, I tried tuning the ION station after switching my Windows XP (32 bit) machine's Fusion tuner to OTA and that did crash. So it seems that FusionHDTV 3.90 handles the odd ION subchannels more gracefully under the newer OS for some reason.
BTW, I find that simply restarting the PC (i.e., Nani's step #5) is sufficient to recover normal operation after these (and similar) crashes.
11:52 AM Liked: 29
post #1787 of 1797
01-15-2013 | Posts: 2,047
Hi,
Well Terry, as you were testing XP I decided to test W7.
Fusion5 RT Gold on W7 32 Bit standby HTPC. (Desktop system)
Connected my Fusion5 RT GOLD for the first time to my new antenna system (See my profile). I got 102 programs vs 102 for the Fusion7Dual on my active HTPC.
Results were the same but a little different for Fusion5 RT Gold on W7 32 Bit!
KKPX 65.1 RF 41 lasted ~ 15 seconds before aborting.
KKPX 65.96 Airbox aborted immediately.
A computer restart was all that was necessary to restore Fusion.
The Fusion7Dual is a real looser, I may put the Fusion5 RT Gold in my active HTPC.
So it's not only the OS type but the type of tuner card.
Larry, can you just restart your computer or do you have to do the elaborate process I must do with the Fusion7Dual?
SHF
12:05 PM Liked: 18
post #1788 of 1797
You're right, it does make sense that the tuner model would affect this behavior, because each one uses a different driver and--sad to say--my impression is that the authors of the later models' drivers were actually less experienced than the previous authors due to high company turnover.
01:19 PM Liked: 29
post #1789 of 1797
06-22-2013 | Posts: 2,047
Hi,
A tidbit about Fusion, it's waketimer can be checked.
My W7 laptop keeps waking up from Hibernate and I so far cannot find out why.
All the usual suspects have been eliminated and I now am chin high in sticks of dynamite in Windows W7 lighting matches to try and find the next one to go off as I am in the dark.
This post for CW_EPG gave me an additional tool, "powercfg -waketimers". Not in some documentation online.
http://www.avsforum.com/t/659993/cliff-watson-epg-add-on-for-myhd-fusionhdtv-and-hd-homerun/3660#post_22424303
LastWake.bat
REM This bat file must be right clicked and run as Administrator selected!
pause
powercfg lastwake
pause
powercfg devicequery wake_armed
pause
eventvwr.msc
pause
I have disabled Fusion from setting it's waketimer now as the Fusion7 USB tuner is seldom connected and while I have tested recordings using my network HDHR tuners, my main HTPC does all the recordings.
The bat file results:
C:\Windows\system32>powercfg -waketimers
There are no active wake timers in the system.
C:\Windows\system32>pause
Press any key to continue . . .
C:\Windows\system32>powercfg lastwake
Wake History Count - 0
C:\Windows\system32>powercfg devicequery wake_armed
C:\Windows\system32>eventvwr.msc
Here is the entry for Fusion before I canceled it:
Timer set by [PROCESS] \Device\HarddiskVolume3\Program Files (x86)\DVICO\FusionH
DTV\FusionHdtvTray.exe expires at 8:14:23 PM on 6/28/2014.
If you select the "System" log in "event viewer" and "Filter current log" on the right selecting "Event Sources" checking "Power-Troubleshooter", the entries display when the computer has waken up, but with "Wake Source" Unknown.
I have checked all suspect entries in "Task Scheduler" and as I do not use "Windows Media Center" it is not the cause as was on my Vista laptop which also took a long time to find and stop. And lots of posts on the internet.
"Autoruns" has helped but I am stumped for now.
http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
If anyone wishes to help me, a PM might be best as this is OT as fusion "has been eliminated from my inquires".
TIA
SHF
Kafei's Avatar Kafei
12:20 PM Liked: 10
post #1790 of 1797
08-31-2013 | Posts: 203
I can’t seem to find the DViCO site anymore, but I am finding a Korean-language site that has arisen in its place:
http://www.fusionhdtv.co.kr/
This appears to belong to a company called MPiXON Corp., and the most recent versions of the software seem to be there for download.
No English version yet.
06:26 PM Liked: 29
post #1791 of 1797
10-23-2013 | Posts: 2,047
Hi,
See attached for English by Google Translate. 10/23/2013
XPS format in ZIP, PDF would not print page.
Only partially translated, but will help in selecting the correct file.
Download failed to start!
Use Google Translate directly live for a better and more complete webpage.
SHF
Fusion WebPage 10_23_2013.zip 187k .zip file
EDIT: This snip is better: (Members can click the photos to see the larger versions)
Attached: Fusion WebPage 10_23_2013.zip (186.7 KB)
08:14 PM Liked: 29
post #1792 of 1797
Hi,
Try Google Translate on:
http://www.dvicomall.co.kr/
for current products in Korea.
SHF
03:02 PM Liked: 10
post #1793 of 1797
11-08-2013 | Posts: 203
Originally Posted by SFischer1 View Post
Hi,
SHF
I am more interested in software updates, personally. I was hoping that eventually they would get subtitles added to FusionHDTV; it has been in the pipeline forever but is apparently never going to happen.
06:43 PM Liked: 29
post #1794 of 1797
11-08-2013 | Posts: 2,047
Hi,
It has happened. See their current product: http://www.digitalconnection.com/products/video/tvixm6620np.asp
It is perhaps not on their Korean Web Site. Strange.
That is the only product that digitalconnection shows now.
FusionHDTV with subtitles? Perhaps when Hell freezes over.
Wait, that happens every year about this time. http://en.wikipedia.org/wiki/Hell,_Michigan
Perhaps in their Windows 8 version. Download that version (One bit per year so it will take some time.) and report back.
SHF
07:16 PM Liked: 10
post #1795 of 1797
SHF
Heh.
I should be saying closed captioning instead of subtitles.
I can watch the recorded .tp files through VLC and see the subtitles.
I can live stream through VLC (F:\VideoLAN\vlc.exe atsc:// :dvb-modulation=8VSB :program=1 :dvb-physical-channel=19) and see closed captioning on live TV.
So obviously the driver is passing the information through.
The answer I got on the old DViCO site was that it was difficult to implement and would take a lot of time.
Phbtbtbtbtbt
I’ll shop around next time.
07:41 PM Liked: 29
post #1796 of 1797
Hi,
Perhaps Korea HDTV does not have CC. DC has the manual for download but no CC found in it.
I somehow turned CC on in VLC, I may have to find how to turn it off soon.
SHF
Bruce Embry's Avatar Bruce Embry
03:39 AM Liked: 11
post #1797 of 1797
11-18-2013 | Posts: 1,102
HI all,
I was able to download the latest drivers Windows 8 for my FusionHDTV 7 Dual Express a few nights ago. It took about 10 hours for the download to complete. I use WMC, so I removed the FusionHDTV software and kept the drivers installed. The card was able to record two HDTV streams at the same time. The setup for the 7 dual express is a little tricky in Windows 8, so use the manual mode to get both turners activated.
Reply Home Theater Computers
Subscribe to this Thread
Powered by vBadvanced CMPS v3.2.3
