AAC mpeg4 audio codec - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-31-2000, 11:45 PM - Thread Starter
Tony Lai's Avatar
I was experimenting with this:
http://faac.sourceforge.net/index.html
Longer encode times, slightly higher decode requirements, better quality, lower bitrates required...
T.
IntelInside?
CyrixInstead:-P
AuthenticAMD!
"From the depths of winter I finally learned that within me lay an invincible summer..." a.c.
Tony Lai is offline
post #2 of 4 Old 09-01-2000, 11:24 AM - Thread Starter
Tony Lai's Avatar
Hmmm... doesn't look like any of you are interested.
Anyway I was discussing this with someone and the issue of digital watermarking came up. AAC does not have any watermarking issues at all - it is a free GPU codec.
I did note that the much higher system requirements (in both encode and esp. decode) might turn this into a bit of an Intel/AMD 'tax' if you know what I mean.
I get 3 to 4 times the cpu utilisation depending on processor - measured by Wintop.
Superior codec - smaller file size - superior sound.
Higher cpu usage - longer encode times.
T.
IntelInside?
CyrixInstead:-P
AuthenticAMD!
Tony Lai is offline
post #3 of 4 Old 09-01-2000, 12:16 PM
nataraj's Avatar
This being a HT forum I don't know if too many would be interested in audio compression.
There are indeed issues with watermarking and compression.
Watermarking for new dvd-a needs to be "inaudible". But perceptual compressing algorithms like mp3/mp4 relay on removing things from audio which are "inaudible". So they would remove the watermarking if it was truly inaudible ... which defeats the purpose of watermarking.
www.musicalnirvana.com
Presenting the genius of Indian Classical Music
nataraj is offline
post #4 of 4 Old 09-01-2000, 09:31 PM
tommyboy2's Avatar
I for one am very interested in this format. So is Dolby as I've heard they're doing something with it. AAC should be 30% smaller than MP3, yet its sonically superior and supports 24/192 and multi-channel too.
AAC also supports DRM (digital rights management), so the record industry will become its new best friend since they have so woefully missed the boat on MP3.
Anyway, I saw this encoder/decoder somewhere earlier today and wondered if anyone had tried it. Glad to hear you did. Do you know if you can rip a 24/96 track into an AAC format?
Tom
tommyboy2 is offline
Closed Thread Home Theater Computers
