Xbox 360 HD DVD Addon -- Works on an HTPC!? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 2767 Old 11-15-2006, 02:24 AM
pteittinen's Avatar
Originally Posted by madpoet View Post
I've been mucking in the registry for an hour. There's all sorts of crazy stuff in there, but I didn't really notice any changes turning stuff on and off.
Did the same thing last night, with same results
I won't pay a cent for UHD Blu-rays made from 2K masters by upscaling.
pteittinen is offline
post #182 of 2767 Old 11-15-2006, 02:29 AM
pteittinen's Avatar
Originally Posted by himey View Post
My bad it looks like patsfan123 did just that!
Yeah, looks like WinDVD8HD outputs full rez when the disc is not protected by AACS. That "1080i patterns" disc was authored by me, btw, from streams I found on the net. Apparently some of those originate from http://www.w6rz.net/
post #183 of 2767 Old 11-15-2006, 05:05 AM
madpoet's Avatar
FYI, it also plays homemade BDs at full rez.
Someday maybe I'll actually WATCH my projector...
madpoet is offline
post #184 of 2767 Old 11-15-2006, 05:34 AM
talon95's Avatar
Quoted: 130 Post(s)
Liked: 63
This is nothing new, but as a data point I just got the Jap. WinDVD installed and working. 960x540p for me also and that is through my MSI 7600GT with HDCP connected through DVI to my Infocus 4805 projector. I even tried it with only the projector connected, but no luck.
Config:
C2D E6300@2.8Gig
Gigabyte DS3
MSI 7600GT HDCP (93.71 drivers)
WinDVD HD Japanese version
One bit of good news was that it was only peaking at about 40% CPU usage playing King Kong, so no problems there, at least not at that res.
For now this is fine for me as my projector is only 480p. Hopefully it'll get fixed down the road.
Dave G.
talon95 is offline
post #185 of 2767 Old 11-15-2006, 06:24 AM
new04quest's Avatar
Originally Posted by curtisb View Post
It is in English and such if that is your question. It just seems to have the extra bits of HD-DVD or bluray support. Though as others have noted, it isn't full resolution and it obviously has a lot of chance of not working on your particular configuration. I installed the US version on accident at first before buying it from the Japanese site (very concerning but following the instructions I had no problems) and didn't notice any differences besides the secondary HD windvd application folder and application (looks the same).
Did you get the US or JP WinDVD8 platinum to work with the new HD-DVD player by Xbox? Where did you get the HD-DVD driver for PC?
new04quest is offline
post #186 of 2767 Old 11-15-2006, 06:31 AM
madpoet's Avatar
No, the US WinDVD8 DOES NOT work. It doesn't contain the right stuff. You must have the Japanese version.
madpoet is offline
post #187 of 2767 Old 11-15-2006, 06:54 AM
mmortal03's Avatar
Great, so they are second guessing the lack of the ICT being enabled on a COMMERCIAL AACS protected disc, and applying the downrez anyway.
I can't even think of a reason why they could be sued for following the letter of the law of the industry, when it is the industry ITSELF that has decided to NOT enable the ICT initially.
What, do they think that we will come up with some way of copying an uncompressed 720p recording frame by frame? That is completely unfeasible with today's hardware and software.
mmortal03 is offline
post #188 of 2767 Old 11-15-2006, 07:02 AM
new04quest's Avatar
Do you happen to have a working Xbox HD-DVD driver for PC?
post #189 of 2767 Old 11-15-2006, 07:31 AM
thexder's Avatar
XP Drivers are on this page
Vista does not require these drivers.
thexder is offline
post #190 of 2767 Old 11-15-2006, 07:33 AM
unimatrixzer0's Avatar
Anyway to take the update for WinDVD HD 7.5 and some how replace the correct files in WinDVD 7.0 to turn it into 7.5?
unimatrixzer0 is offline
post #191 of 2767 Old 11-15-2006, 07:45 AM
pteittinen's Avatar
You don't need any drivers for XP, if all you want to do is view movies. WinDVD HD and PowerDVD HD both contain the required stuff for movie playback. If, however, you want to look at the file system/directory structure on the disc, you need a driver for XP.
post #192 of 2767 Old 11-15-2006, 07:50 AM
talon95's Avatar
Quoted: 130 Post(s)
Liked: 63
The Jap. WinDVD HD is a full separate app. I haven't had time to look at what it installed, but the installer is 200+meg vs. 70-80 for the U.S. WinDVD.
That said, I also did try applying the update to the U.S. version, but it just gave me an incorrect version error and quit.
Dave G.
talon95 is offline
post #193 of 2767 Old 11-15-2006, 08:16 AM
cgmoore's Avatar
madpoet, is blueray also downres'd?
Please pray for peace.
cgmoore is offline
post #194 of 2767 Old 11-15-2006, 08:35 AM
madpoet's Avatar
Yes... but a workaround is brewing. Details to be released once it's completely confirmed. Many thanks to pteittinen!
madpoet is offline
post #195 of 2767 Old 11-15-2006, 08:48 AM
bton's Avatar
Anyone has any luck with Toshiba HD-DVD player?
bton is offline
post #196 of 2767 Old 11-15-2006, 08:56 AM
pteittinen's Avatar
The drive in Toshiba's HD DVD stand alone players does not have AACS in the hardware, so it can't be used for movie playback in Windows.
post #197 of 2767 Old 11-15-2006, 08:59 AM
Cipher's Avatar
pteittinen,
Any idea if this is also true for the HDDVD Addon?
Cipher is offline
post #198 of 2767 Old 11-15-2006, 09:05 AM
madpoet's Avatar
He doesn't have one, I'll test it tonight and let you know.
madpoet is offline
post #199 of 2767 Old 11-15-2006, 09:07 AM
I think what that user was talking about is Toshiba came out with their own HD-DVD player software to replace WinDVD HD in their newer HD-DVD laptops.
post #200 of 2767 Old 11-15-2006, 09:08 AM
pteittinen's Avatar
Ohh, heh, OK
post #201 of 2767 Old 11-15-2006, 09:14 AM
pteittinen's Avatar
Originally Posted by Cipher View Post
pteittinen,
Like madpoet said, I don't have one (yet). But if I were to make a guess, I'd say it won't work. The main reason being that the WinDVD I got working is for Blu-ray - and when you install the Japanese WinDVD 8, it asks you if you want to install the Blu-ray or the HD DVD version. They're not quite the same application.
post #202 of 2767 Old 11-15-2006, 09:16 AM
madpoet's Avatar
I'm hopeful I can figure out the changes it makes and apply them to the HD version however .
madpoet is offline
post #203 of 2767 Old 11-15-2006, 09:18 AM
pteittinen's Avatar
In the set-up menu there's at least one leaflet which is different in BD and HD versions.
post #204 of 2767 Old 11-15-2006, 09:36 AM
thexder's Avatar
I was not able to get any further with the Toshiba HD-DVD player software. It would seem that there are additional files required which would have been included on the original cd-based installation.
thexder is offline
post #205 of 2767 Old 11-15-2006, 09:39 AM
Cipher's Avatar
I've been trying this player but I get a registration error during installation (for 2 video decoder files - see my earlier post) and a configuration error when starting the application.
I even used FileMon to see which files the app was requesting and noticed two were missing from my system: thci.dll (Toshiba common module file) and mfc42loc.dll (MS Visual C++ file). I downloaded and registered these dlls and this time the Toshiba player found these files and ran without any "Missing" errors in Filemon. Unfortunately, the configuration error message still appeared!
Until WinDVD/PowerDVD release paches, I think this player might be our best chance to get 1080p for HDDVD.
Cipher is offline
post #206 of 2767 Old 11-15-2006, 09:43 AM
madpoet's Avatar
We'll see. I am semi-confident I will be able to get the BD patch to unlock the same settings for the HD version of WinDVD. But I won't be able to test it until later tonight.
-MP
madpoet is offline
post #207 of 2767 Old 11-15-2006, 10:24 AM
thexder's Avatar
-MP
Everyone is looking forward to reading about your progress later tonight.
thexder is offline
post #208 of 2767 Old 11-15-2006, 10:41 AM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
If someone can zip up the original installation disc for the toshiba HD-DVD software, this could go a long way in getting HD-DVD to work.
bhazard is offline
post #209 of 2767 Old 11-15-2006, 10:48 AM
edrossy's Avatar
The changes for hardware acceleration may be a registry setting? Can someone with toshiba HD-DVD (WinDVD HD version) software running at 1080p with hardware acceleration enabled export their registry settings.
edrossy is offline
post #210 of 2767 Old 11-15-2006, 11:17 AM
edrossy's Avatar
Did anyone say ANYHDDVD or ANYBDDVD???
If they did come out with those versions, any idea how much load would be put on the CPU when decrypting?
edrossy is offline
Reply Home Theater Computers
