Xbox 360 HD DVD Addon -- Works on an HTPC!? - Page 91 - AVS Forum | Home Theater Discussions And Reviews
post #2701 of 2767 Old 10-23-2007, 12:49 AM
LR6AGB001's Avatar
Appreciated and it seems my videocard isn't even listed. And here I thought I could get by with my Radeon 9800 Pro.
As for everything else, I'm fine.
LR6AGB001 is offline
post #2702 of 2767 Old 10-23-2007, 08:33 AM
jkcheng122's Avatar
Quoted: 83 Post(s)
Liked: 92
i just found this on ebay (link). anyone know if this can be converted to an internal drive for pc?
edit: change the *** to *********
jkcheng122 is offline
post #2703 of 2767 Old 10-24-2007, 12:44 AM
LR6AGB001's Avatar
Feeling kinda guilty here after I've just convinced a buddy of mine to get the X360 add-on, only to find that his copy of 300 is not working at all. Any suggestions, he replaced the disc twice and still nothing.
post #2704 of 2767 Old 10-24-2007, 12:52 AM - Thread Starter
MidnightWatcher's Avatar
Quoted: 37 Post(s)
Liked: 25
Is he connected to XBox Live when he puts the disc in? Maybe he needs to download an update first.
MidnightWatcher is offline
post #2705 of 2767 Old 10-24-2007, 06:44 AM
LR6AGB001's Avatar
That's the problem, the disc won't even get that far. It'll just sit there reading the HD-DVD disc and the odd thing is a bunch of HD-DVDs from netflix work.
post #2706 of 2767 Old 10-28-2007, 07:11 AM
chetanzcool's Avatar
Heh guys:
Using a Dell 24 inches HDCP monitor.XFX 8800 GTX , Power DVD advisor gives me an all green but still HD movies play at 540 p and not at 1080p, Any advise.
Nvidia 163.71 drivers.
XBOX HD DVd player.
Using Power DVD ultra 7.3
chetanzcool is offline
post #2707 of 2767 Old 10-28-2007, 07:38 AM
Hunter844's Avatar
Originally Posted by chetanzcool View Post
Heh guys:
XBOX HD DVd player.
What are you using to input to your tv from your video card?
At what they want for Ultra I'm inclined to go ahead and buy a stand-alone player especially since they are under $300 at walmarks these days. I've got the add-on for my XBOX but the damn 360 keeps dieing (sent it back for warranty work and it lasted 2 days thereafter)...the 3 rings of death.
Surely there is some open-source nerd out there that's going to do everyone a big favor and put out some kind of HDDVD/BR media player that is either super cheap (and works) or out and out free to donate (and still works).
Hunter844 is online now
post #2708 of 2767 Old 10-28-2007, 08:04 AM
Using a DVI to DVI connector
XBOX HD DVd player.
Using Power DVD ultra 7.3 (7.3.3304.0)
post #2709 of 2767 Old 10-28-2007, 08:23 AM
Vern Dias's Avatar
Change the video quality setting from auto to best in PDVD......
However, be aware of the fact that PDVD may have determined you don't have adaquate HW to support full resolution output, so you may experience stuttering and other problems with video quality forced to best.
You will find this setting in Configuration - Video - Advanced When you are actually playing an HD DVD or BD.
Vern
Vern Dias is offline
post #2710 of 2767 Old 10-28-2007, 08:35 AM
Well i do have a pretty powerful system ...Tried the option still plays at 540p...Huge black bars on the top and botton!
post #2711 of 2767 Old 10-28-2007, 09:58 AM
laguna_b's Avatar
How do you know it is playing at 540p? Where did it tell you that?
laguna_b is offline
post #2712 of 2767 Old 10-28-2007, 10:08 AM
iamme's Avatar
i'm thinking about picking up a prebuilt HTPC, the HP slimline s3120n with these specs:
AMD Athlon 64 X2 Dual-Core Processor 4200+
2GB RAM
GeForce 6150LE shared video (Possible video card upgrade to: XFX 8400GS)
Will this system handle an Xbox 360 HD DVD player?
iamme is offline
post #2713 of 2767 Old 10-28-2007, 10:36 AM
laguna_b's Avatar
I built mine with a Gigabyte MB and Athlon x2 6000, 2G memory embedded ATI graphics chip...cost for MB, CPU, Memory total $289 plus tax. So you better be getting a cheap price on that HP machine. Also, it MUST have PCI Express if you ever want to upgrade the graphics card.
laguna_b is offline
post #2714 of 2767 Old 10-28-2007, 11:03 AM
laguna_b: Its got Huge Black Bars on the top and bottom, and i checked it with WIN DVD HD and cliucked on the i and it displys the rsolution of the video being played as 960 x 540 which is 1/4 th of the 1080p pixels...that pretty much sucks.
post #2715 of 2767 Old 10-28-2007, 11:08 AM
iamme's Avatar
it's a refurb for $400. i think it's a good deal for a complete system with OS. i've built plenty of PC's in the past, and i'm at a point where i'd like use it out of the box. unless, it's not powerful enough to play HD DVD's.....then i might consider building.
iamme is offline
post #2716 of 2767 Old 10-29-2007, 01:08 PM
JonProphet's Avatar
I'm Sorry about asking this, but I got to page 4 and then skipped to 44 and then read 46 so if this is a repost, please accept my apologies.
Quick and dirty question. Is anyone able to decode the new codecs using the 360 drive? If so, how? If not, I'm assuming yer getting atleast DD and DTS right? If you can't, is it still not possible to send undecoded data across HDMI so a receiver can decode?
-JD-
JonProphet is offline
post #2717 of 2767 Old 10-29-2007, 01:24 PM
ExDeus's Avatar
XBOX HD DVd player.
I'm not sure how to know positively that PowerDVD isn't downrezzing to 540p, but I have three thoughts...
1) Just because WinDVD is downrezzing, doesn't mean PowerDVD is downrezzing.
2) You need to have your desktop resolution set to 1080p if you want full resolution, because when video is displayed at full screen, it's always going to be scaled to your desktop resolution.
3) The black bars are likely letterbox matting, either introduced by the playback software to maintain the aspect ratio, or already encoded into the video stream. Even if you have your desktop set to 1080p and PowerDVD downrezzes the video to 540p, it's going to be scaled back to 1080p by your video card as it is output to the display. Neither your video card nor PDVD will display any lesser video (when maximized to full screen) at it's 'native resolution' inside a black box, it will always get scaled. Do you have controls on your monitor to see the current resolution?
So, what is the aspect ratio of your video content? If it's 2.35:1 or greater, expect big bars, even on a widescreen display.
Also, if you want to bypass the requirement for HDCP, install AnyDVD HD. That would prevent any downrezzing.
Get WMC Recording Storage Pooler 1.1.0.
Get ATI HD Registry Tweaks 0.16. Updated 2009-12-31.
Get Firewire drivers for DVRs. Updated 2009-02-25.
ExDeus is offline
post #2718 of 2767 Old 10-29-2007, 04:22 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 25
2GB RAM
You'll want to upgrade the video to an ATI 2400 or 2600 and enable the hardware acceleration in PowerDVD Ultra.
post #2719 of 2767 Old 10-29-2007, 04:41 PM
Rathbone's Avatar
Quoted: 53 Post(s)
Liked: 25
The early ersions of WinDVD HD downrezzed everything. Seems you have on of these. Nero Showtime 4.1 shows the output resolution. Try that to be sure.
Rathbone is offline
post #2720 of 2767 Old 10-29-2007, 04:46 PM
ExDeus's Avatar
It shows the file's resolution or the output resolution? In the past, like PDVD, Nero has shown the file's resolution.
ExDeus is offline
post #2721 of 2767 Old 10-30-2007, 10:38 AM
HPforMe's Avatar
-JD-
The drive won't decode anything. You need the software to do that. That's where PowerDVD comes in. The latest version decodes TrueHD and DD+ passing it as pcm.
HPforMe is offline
post #2722 of 2767 Old 10-31-2007, 09:50 AM
JonProphet's Avatar
So there is no way to send Bitstream from an HTPC via HDMI so the receiver can decode the the audio?
-Jd-
post #2723 of 2767 Old 10-31-2007, 10:39 AM
archibael's Avatar
Not yet. Best you can do right now is 8-channel LPCM to analog or HDMI, and it's unclear whether PowerDVD will cooperate with the latter.
I do not speak officially in any sense for
Intel Corp., Technology Manufacturing Group
but I do work there.
archibael is offline
post #2724 of 2767 Old 10-31-2007, 10:47 AM
laguna_b's Avatar
I am not sure this of any help but I selected SPDIF and got my receiver to decode 5.1 channel from it. I have the OEM PDVD.
laguna_b is offline
post #2725 of 2767 Old 11-01-2007, 02:16 PM
ExDeus's Avatar
That's not entirely true --- DD+ is passed thru, as it can be decoded by a DD decoder.
If you select SPDIF in PDVD, then DD, DD+, DTS, and DTS-HD High Resolution (core) will all be passed through as 5.1/6.1, because those streams are all compatible with standard Dolby Digital and DTS decoders in AVRs.
Dolby TrueHD and DTS-HD Master Audio (core+extensions) are not compatible with standard AVR decoders, so PDVD decodes the audio and sends it as 2-Ch PCM, or DTS if you check the box. There have been some reports that PDVD OEM will only send 2-Ch DTS and not full DTS Surround (5.1). I'm not sure on that part.
ExDeus is offline
post #2726 of 2767 Old 11-08-2007, 08:11 AM
docimian's Avatar
anyone have any experience with the HD-DVD addon with a laptop?
Nero claims they dont support my video card - a geforce go 7800 GTX (256).
i have a pentium M overclocked to 2.66 GHZ so im hoping i can get this to work...
any suggestions as to another program that can accelerate the playback with my video card?
thanks!
Dan
docimian is offline
post #2727 of 2767 Old 11-09-2007, 06:38 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 25
New update available: This patch file updates PowerDVD Ultra to PowerDVD Ultra build 3319f. For retail version only.
Issue list:
  • Improve Blu-ray Disc and HD DVD title compatibility with PowerDVD Ultra
  • Enables support for secure BD/HD DVD playback on Intel 965/946 graphics chip with Windows Vista aero-glass interface enabled.
post #2728 of 2767 Old 11-09-2007, 06:51 PM
laguna_b's Avatar
PowerDVD has given me no end of problems which their "voice support" can not seem to get fixed. These guys send you on long uninstall / install/ install patches games that never yield anything other than what you started out with.
Depending on the "route " of installation and versions I use I either get most HDDVDs playing with a few that do not OR the reverse...the ones that play under one configuration fail under the opposite. I have the OEM version and I have wasted days of my own time with their games. I plan to ask for my "voice support" $29 back. It isn't a lot of money but it is a lot of satisfaction!
laguna_b is offline
post #2729 of 2767 Old 11-14-2007, 12:46 AM
Death Vader's Avatar
Hello what are the best configs for Power, I keep getting stuttering HD DVD playback.. Before I put the disc in I have the software accelerating box checked off, but when I actually play something, the box is unchecked?? Any reasn behind this??
Death Vader is offline
post #2730 of 2767 Old 11-14-2007, 09:12 AM
rubso's Avatar
hey guys, I have a new powerful laptop, C2D 2.0GHz, 8600GT nvidia..
Cyberlink advisor says i can easily play HD-DVD discs, ( using my add-on ) but the thing is, when ever i play a movie i keep getting this
the movie itself plays smoothly, but half of the screens keeps flashing a group of white pixels.
that looks like this:
can you help me guys?
rubso is offline
Reply Home Theater Computers
