Semi-Official BD and HD DVD on an HTPC Configuration/Playback FAQ - Page 31 - AVS Forum | Home Theater Discussions And Reviews
post #901 of 910 Old 03-26-2010, 08:44 AM
Plasman's Avatar
Very basic question-
I have an older HTPC (Core 2 Duo 2Ghz) and Soundblaster original Audigy with Windows XP Pro. Plays regular DVD's great with coaxial audio output. I want to add a BD SATA drive. Do I have enough horsepower, can you recommend a good inexpensive drive, and which software/drivers might I need? Thanks in advance!
Plasman is offline
post #902 of 910 Old 03-26-2010, 10:27 AM
back2boston's Avatar
You'll need to check for driver support to confirm sound card and BD player support, etc. (although I imagine it will be fine, esp if staying with XP), but in my opinion you can't go wrong with the Lite-On IHOS104.
Tiger Direct has it about as cheap as you can find:
http://www.tigerdirect.com/applicati...9&Sku=L12-1332
Comes with PowerDVD 8 OEM. You must upgrade that to v9 'Ultra' to get full DD/DTS etc. surround sound decoding (will cost another $60 or so from PowerDVD's web site). Do it.
back2boston is offline
post #903 of 910 Old 03-27-2010, 07:54 AM
Plasman's Avatar
Thank you very much for the advice. I've always liked Lite-On drives.
Plasman is offline
post #904 of 910 Old 04-29-2010, 07:22 PM
cheer's Avatar
OK, stupid question.
I've got an HTPC connected to my TV via HDMI and to my receiver (older one, Sony STR-DG800) via optical S/PDIF, and Arcsoft's TMT3. And that works fine, except of course I'm limited to lossy audio (I have to set TMT3 to downmix).
The STR-DG800 has 7.1 analog inputs (though I'm only using 5 speakers + SW). So. Assuming I can re-assign the motherboard's audio ports appropriately, in theory can I run audio cables from the PC to the analog inputs and set TMT3 to decode DTS-MA and Dolby TrueHD and get the better audio?
Christopher D. Heer
Disclaimer: I neither speak for nor represent my employer or its views.
Originally Posted by Oscar Wilde
Work is the curse of the drinking classes.
cheer is offline
post #905 of 910 Old 04-29-2010, 08:29 PM
jimwhite's Avatar
be wary of what your AVR will NOT do when processing analog inputs...
Jim White
St. Petersburg, FL
jimwhite is offline
post #906 of 910 Old 04-29-2010, 09:19 PM
cheer's Avatar
Meaning what, exactly?
Christopher D. Heer
cheer is offline
post #907 of 910 Old 04-30-2010, 11:06 PM
jimwhite's Avatar
bass management, Audessy, etc....
Jim White
St. Petersburg, FL
jimwhite is offline
post #908 of 910 Old 04-30-2010, 11:08 PM
proteus7's Avatar
Any idea how to get S/PDIF to do more than 2 channel audio?
I have an Asus P5Q-EM based HTPC, and using onboard realtek audio (s/pdif out) I can never get more than 2 channels. Running TMT3, output is set to S/PDIF. Receiver (Pioneer) shows 5.1 input, but is only playing through 2 channels. Windows NEVER gives me an option for more than 2 channel audio. Any ideas? Even on a DTS-HD source (Avatar), I'm getting downmixed to 2-channel DTS...
proteus7 is offline
post #909 of 910 Old 05-01-2010, 12:12 PM
cheer's Avatar
Ah, OK. Well, it's a pretty basic receiver and it doesn't do much of that anyway, so I'm cool with that limitation.
Christopher D. Heer
cheer is offline
post #910 of 910 Old 05-01-2010, 12:13 PM
cheer's Avatar
You might have to fiddle with the Realtek settings to tell it you have a 5.1 speaker setup. My Realtek has a "speaker configuration" setting.
Christopher D. Heer
cheer is offline
Reply Home Theater Computers
