Semi-Official BD and HD DVD on an HTPC Configuration/Playback FAQ - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 11-19-2006, 09:58 AM
capitano's Avatar
Originally Posted by madpoet View Post
Skavan, I wish I could be more help. All I know is that using a DVI to VGA connector out to an analog monitor and the IOData WinDVD version, I have perfect 1080p playback with full hardware acceleration on BD disks.
me too have no problem with jap patched and dvi/hdmi connection.
capitano is offline
Old 11-19-2006, 10:05 AM
SNOOT's Avatar
I too am getting playback using the onboard 6150 on an asus a8nvm with amd x2 processor. This is through VGA. This produces video that is a little choppy at times but is very watchable. The choppiness seems to settle down after a period of time. My problem is audio though. I can not get any audio. I am connected to receiver via digital S/PDIF from a MAudio Revo 7.1. I have digtal selected on the MAudio side and digital on the Windvd side however there doesn't seem to be a way to select which sound card from within Windvd. Suppose I could disable the onboard sound.
DAve
SNOOT is offline
Old 11-19-2006, 10:28 AM
umdivx's Avatar
DAve
I think the 6100 and 6150 chipsets are just too slow (not powerful enough) as they don't have the power to do HD playback. If you look at cyberlinks advisor it basically says 7xxx series or higher for the nvidia side.
- Josh
Here's a checklist for parts needed straight from Nvidia: http://download.nvidia.com/downloads...ing_a_HDPC.pdf
umdivx is offline
Old 11-19-2006, 10:29 AM
talon95's Avatar
Quoted: 130 Post(s)
Liked: 63
DAve
If you haven't, you might try switching audio streams while the movie is playing. The default for the movies I've tried so far is DD+, but they also have a standard DD stream. I get sound from DD+, but playback isn't smooth. Switching to DD fixes this though.
talon95 is offline
Old 11-19-2006, 11:33 AM
pteittinen's Avatar
I get 960x540 doing that. Tried with both a non-HDCP and HDCP-compliant graphics card. Weird.
I won't pay a cent for UHD Blu-rays made from 2K masters by upscaling.
pteittinen is offline
Old 11-19-2006, 12:13 PM - Thread Starter
madpoet's Avatar
With the clean IOData installation process, or with the patched upgrade of the Japanese version?
Someday maybe I'll actually WATCH my projector...
madpoet is offline
Old 11-19-2006, 01:07 PM
pteittinen's Avatar
The clean one.
Old 11-19-2006, 01:29 PM - Thread Starter
madpoet's Avatar
Weird... I've attached a screenshot of mine doing 1080p with KoH. Not sure why. Are you going DVI to VGA or VGA to VGA?
madpoet is offline
Old 11-19-2006, 02:44 PM
pteittinen's Avatar
DVI to VGA. There's no VGA connector in either of those two graphics cards. They're both ATI, however, and I'm not 100% certain of ATI's drivers HDCP status.
Old 11-19-2006, 06:11 PM - Thread Starter
madpoet's Avatar
I'm just wondering if it's a video card thing. The 8800 is the latest and greatest, but it shouldn't matter.
madpoet is offline
Old 11-20-2006, 01:50 AM
pteittinen's Avatar
It could very well be. When I find the time, I'll try DVI->VGA on another PC, one with a HDCP-compliant Nvidia 7950GT and latest PureVideo HD drivers. My current PC monitor (24" Dell) is not HDCP, but I'm about the rectify the issue by placing an order for the 30" Dell today
Old 11-20-2006, 05:55 AM
SNOOT's Avatar
OK - disabled the onboard audio on the Asus and now get audio through spdif. Now I can tell that playback is much choppier than I realized by watching video alone. What was a short drop/chop of video is a longer break in audio. Very unwatchable. Yes I do think the 6150 chip set is way under powered. I suppose the question is which card to get. I have a NEC 50 inch plasma and will be sending it 1366x768. Dont Think I will ever use 1080p, Also where in Windvd do I select dolby digital or dolby digital + ?
SNOOT is offline
Old 11-20-2006, 10:19 AM
talon95's Avatar
Quoted: 130 Post(s)
Liked: 63
You can always pick a different track in the DVD setup menu, but within WinDVD you can either:
Right click in the video window while the movie is playing and select a track from the "audio" menu item, or
Go to the control panel at the bottom and select it from there also (you have to bring up the control panel with one of the icons down there, it's not displayed by default).
talon95 is offline
Old 11-20-2006, 05:47 PM
skavan's Avatar
Originally Posted by skavan View Post
5. The IOData version, no longer gives me the parental control error, and tries to play the disk - but gives me "Your display environment does not support protected content playback." . Even though I'm going analog (component) *and* the card is in fact HDCP compliant (although that should be redundant anyway).
6. Conclusion - Japanese WinDVD BD doesn't like copy protection (is buggy) and IOData WinDVD BD doesn't like analog.
UPDATE:
The IODATA version plays back SOME BD's - but fails with the above mentioned errors on :
Brothers Grimm and
Dinosaur.
Works fine (at 1080i analog) on:
Corpse Bride
The Great Raid (very choppy)
PowerDVD also works on the latter two titles - but hangs on the former -- or gives me the resolution error referenced in my original post. Weirder and weirder.
Anyone got Brothers Grimm and/or Dinosaur -- and can post their results?
s.
skavan is offline
Old 11-20-2006, 05:48 PM - Thread Starter
madpoet's Avatar
I don't, sorry. Did you remmember to set your BD region?
madpoet is offline
madpoet's Avatar
madpoet is offline
Old 11-20-2006, 06:33 PM
skavan's Avatar
yep BD region is set to Region 1 (USA).
s.
skavan is offline
Old 11-21-2006, 09:24 AM
vairulez's Avatar
any of you guys manage to get powerdvd 6.5 hd-dvd to see if it works better than windvd8 ?
sorry for my poor english but I'm french !!!!
vairulez is offline
Old 11-21-2006, 05:29 PM
laric's Avatar
Nobody tried ?
Need to decide on friday to buy x360 HD-DVD or wait for HD-E1 !
--Patrice
French speaking home theater HCFR Forum
laric is offline
Old 11-21-2006, 06:07 PM - Thread Starter
madpoet's Avatar
PowserDVD is not released for HD DVD.
madpoet is offline
Old 11-21-2006, 07:19 PM
Blippy2005's Avatar
that one guy that reviewed was using a beta version that's not publicly available. I think it actually is installed on one of those Vida or Niveus systems and he just plugged a Xbox 360 HD-DVD addon drive to one of those to test it as a functional drive. That's my assumption at least.
Blippy2005 is offline
Old 11-22-2006, 01:36 AM
capitano's Avatar
PowerDVD 6.6 BD edition
PowerDVD 6.5 HD-DVD edition
both only available in bundle with hardware.
capitano is offline
Old 11-22-2006, 04:49 AM
deandob's Avatar
Quoted: 40 Post(s)
Liked: 24
Any news on released hardware HD-DVD drives? Apart from the Xbox360 drive that does not have bundled software (so fairly useless), there seems to be nothing for the HTPC user on the HD DVD horizon.....
Dean
deandob is offline
Old 11-22-2006, 06:34 AM - Thread Starter
madpoet's Avatar
Correct... and as no hardware is being sold yet for the HD DVD, not available
Dean, I expect we will see a drive or two before Christmas but I'm not sure.
benes, you are correct... but given how much better the full tracks sound, why would I want a crippled version? WinDVD 8 is working perfectly now for me.
madpoet is offline
Old 11-22-2006, 08:33 AM
capitano's Avatar
[quote=madpoet]Correct... and as no hardware is being sold yet for the HD DVD, not available
QUOTE]
Here in Italy we say: If you search for then you will find..
capitano is offline
Old 11-22-2006, 12:28 PM
laric's Avatar
WHat about X360 Drive, isn't it released in US ? People start to have it here, I hope to have one tomorrow... Will let you know.
--Patrice
laric is offline
Old 11-22-2006, 12:55 PM
archibael's Avatar
--Patrice
Look at in context of the original message. PowerDVD HD DVD is only being bundled with hardware drives for the PC. Since no hardware drives for the PC are readily available, you can't get the software. Yes, the X360 drive is available, but MS makes no assurances that it will even work with the PC, let alone provide software for it, even though we've discovered here that it's apparently a fully-featured HD DVD drive in its own right.
I do not speak officially in any sense for
Intel Corp., Technology Manufacturing Group
but I do work there.
archibael is offline
Old 11-22-2006, 02:08 PM
laric's Avatar
Sure, but it did work even MS confirmed it, (although there is no support but that is another story).
Without even talking of HD-A1 drive that some have allready plugged in PCs...
I'm regular owner of WinDVD 8 Platinium and PowerDVD 7, having in mind both advertise on HD-DVD / BD support that they may not have included...
So my question...
Anyway I may have an answer soon...
--Patrice
laric is offline
Old 11-22-2006, 02:19 PM
archibael's Avatar
Nobody's arguing with the fact that the X360 drive works on a PC. It clearly does. But the software solutions, as you'll see if you'll page through this entire thread, are questionable at this point, and the standard versions of WinDVD (Platinum) and PowerDVD have been confirmed not to work, regardless of what they may be saying in press releases.
Old 11-22-2006, 05:56 PM
jojoxl's Avatar
Anyone try Showtime version that comes with today's Nero update (11/22, 7.5.9.0)? I don't have a drive yet, or I'd do it.
jojoxl is offline
