BTX HTPC Case? - AVS Forum | Home Theater Discussions And Reviews
Old 11-20-2006, 01:16 PM - Thread Starter
brianrt's Avatar
I have a Dell 5150 that I turned into a HTPC, but want to put it in a HTPC style component case. Unfortunately it is a BTX form factor motherboard. So I have been looking high and low for a BTX (not mBTX) HTPC case. Does anyone know of one available or one soon to be available?
Thanks for your time.
brianrt is offline
Old 11-20-2006, 03:56 PM
Magnus Thome's Avatar
Since AFAIK Intel officially cancelled the BTX form factor a month ago or so I doubt there will be a lot of future releases of new HTPC BTX chassis the coming year. I'd suggest you grab what you can find asap beforte it's too late. AFAIK and IMHO of course!
I'm pretty sure I've seen a BTX HTPC chassi somewhere the last year but just can't recall where. Sorry. Search the usual suspects like Silverstone and so on :-)
Don't forget to enjoy things too....
Magnus Thome is offline
Old 11-20-2006, 03:59 PM
Tinker's Avatar
Location: guarding my retirement igloo...with a McMillan TAC-50 long range sniper rifle
Try the Silverstone or Thermaltake sites. I think they have BTX cases, but finding a retailer that may have them in stock may be a hassle tho.
You do not stop playing because you get old...
You get old because you stop playing.
Tinker is offline
Old 11-20-2006, 05:24 PM - Thread Starter
brianrt's Avatar
Thanks for the replies. No luck on the BTX front. Plenty of ones for mBTX though.
I guess I can just buy a new motherboard. Any recommendations for a micro ATX Pentium D 820 motherboard with COAX out?
brianrt is offline
Old 02-19-2007, 10:49 AM
poppagene's Avatar
Quoted: 608 Post(s)
Liked: 397
Newegg has several btx cases and several take a full size btx board
http://www.newegg.com/Product/Produc...srchInDesc=btx
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is online now
Old 02-19-2007, 12:20 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
yes but he's looking for an HTPC style BTX chasis.
unfrotunetely not many(if any) of those around.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 02-20-2007, 06:20 AM
Thuppu's Avatar
One alternative is to do the case by yourself.
Thuppu is offline
Old 02-20-2007, 06:47 AM
Kirby Baker's Avatar
Are Dell motherboards standard BTX? I always thought Dell motherboards were made special (non-standard mounting, etc) so that you couldnt rip them out and put them into a new case?
Kirby Baker is offline
