Does MPACT2 Coexist with HPix ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-30-2000, 04:28 PM - Thread Starter
gireesh's Avatar
I would like to to add HPix to my computer with the MPACT2 motherboard ?
Cliff, any way this would work ?
Gireesh.
gireesh is offline
post #2 of 16 Old 11-30-2000, 05:15 PM
Cliff Watson's Avatar
Gireesh.
Gireesh,
You are going to make me pull the HiPix out of one HTPC and install it in the Cassini, are you. http://www.avsforum.com/ubb/wink.gif Hope you don't mind if I do it after CBS HDTV programs are over. I'll post later tonight.
Best Regards, Cliff
Digital Connection, LLC
cwatson53@home.com
Cliff Watson is offline
post #3 of 16 Old 11-30-2000, 06:24 PM
clopez's Avatar
Hi Cliff,
What will we have to do to have Hpix also add support for 800x600 resolution for us less fortunate SVGA projector people..
PS will the HPix card work with my trusty 3Dfusion moded pci card.
clopez
clopez is offline
post #4 of 16 Old 11-30-2000, 06:29 PM
Vasim Pathan's Avatar
Cliff,
Let me rephrase clopez's question:
What will we have to do to have HiPix also add support for 800x600 resolution for us less fortunate SVGA projector people..
http://www.avsforum.com/ubb/biggrin.gif
Vasim Pathan is offline
post #5 of 16 Old 11-30-2000, 06:58 PM
If the HiPix card works with the Cassini it should work with the add-in Mpact2 card also.
It should be easy to add 800x600 VGA resolution to the HiPix, BUT the HDTV content will be at full resolution. The card does not downconvert to letterbox and unless you can compress the vert. image, you're screwed.
Best Regards, Cliff
cwatson53@home.com
post #6 of 16 Old 11-30-2000, 10:17 PM
Erik Garci's Avatar
Why is the HiPix unable to do letterbox for HDTV? Is it a hardware limitation? Or will they add this feature in the future as a software update?
Erik Garci is offline
post #7 of 16 Old 12-01-2000, 12:12 AM
Maybe because HDTV is not broadcast in letterbox?
Best Regards, Cliff
cwatson53@home.com
post #8 of 16 Old 12-01-2000, 12:15 AM
Gireesh.
Gireesh,
It works!! I captured to hard drive and all. Looks like the RKR Cassini will be our first HDTV enabled HTPC.
Best Regards, Cliff
cwatson53@home.com
post #9 of 16 Old 12-01-2000, 09:03 AM
Erik Garci's Avatar
The fact that HDTV is not broadcast in letterbox does not prevent the receiver from converting it to letterbox for display purposes. Some receivers on the market create a 16:9 image with black bars on top and bottom for 4:3 screens.
post #10 of 16 Old 12-01-2000, 09:24 AM
trbarry's Avatar
So what would I see on my screen if I watched an HDTV 16:9 show? I thought Ray said you could tell the HiPix you have a 4:3 set.
I have a Toshiba 4:3 set with no zoom/squeeze options.
- Tom
Why don't we power our electric cars from greener, cheaper Liquid Fluoride Thorium Reactors?
Tom Barry - Find my video filters at www.trbarry.com
trbarry is offline
post #11 of 16 Old 12-01-2000, 11:24 AM
Ken Wong's Avatar
Cliff,
So the Hipix does not require video overlay? Or does the Mpact2 on the
Cassini support overlays. I have the add in AGP Mpact2 video card, and thought that it did not support overlays.
I have been trying to get other TV cards to work with the Mpact2. The Hauppauge card works, but DTV does not since it needs overlay mode for operation. Is this correct?
Ken
Ken Wong is offline
post #12 of 16 Old 12-01-2000, 12:00 PM
Originally posted by Ken Wong:
Cliff,
Ken
Ken,
The HiPix card has its own graphics controller and only uses the primary video card to display the HiPix Control Panel (User Interface). You can have two display devices connected to the HTPC (a PC monitor and a projector or HDTV) or use the loopback cable for one display device. With one display device an analog switch on the HiPix will block the main video cards output and switch to full screen HDTV from the HiPix.
Best Regards, Cliff
cwatson53@home.com
post #13 of 16 Old 12-01-2000, 06:44 PM - Thread Starter
gireesh's Avatar
Thanks Cliff, MPACT2 lives in my HTPC. Well, if only HPix supported scaling to 800x600 that my projector can handle... I have no intention of upgrading till the 1280x720 DLP front projectors are out. Sound Advice is already selling a 1280x720 DLP RPTV so an FPTV can't be that far behind.
Gireesh.
gireesh is offline
post #14 of 16 Old 12-02-2000, 03:29 PM
cgblack's Avatar
OK Cliff, let's push the MPact2 envelope for a second.
I have a 3DCinemax MB based HTPC and love it.
Now we can add the HiPix card. Can I also add a Zoltrix or other dTV compatible capture card.
I would imagine then I would have four viewing modes (HDTV, dTV, DVD and Desktop) that could all be switched with some simple keystrokes.
Will this work?
Graeme Black
Graeme Black
My HT construction page
Nothing can be made idiot-proof, because idiots are far too clever ...
cgblack is offline
post #15 of 16 Old 12-02-2000, 03:47 PM
Graeme,
Why would you add yet another NTSC capture card when the HiPix has a tuner onboard and will detect the 3/2 pulldown, deinterlace and scale the image for you. The HiPix also has S-Video/composite input that will do the same thing.
But to answer your question, the Mpact2 has very limited overlay support. At the most 640x480 windowed.
Best Regards, Cliff
cwatson53@home.com
post #16 of 16 Old 12-02-2000, 11:51 PM
cgblack's Avatar
Graeme,
So I can watch VCR/DBS content. Will the HiPix do NTSC Capture other than via tuner?
Nevermind I didn't read the whole answer. The SVideo input will suffice. Thanks,
Graeme
[This message has been edited by cgblack (edited 12-03-2000).]
Graeme Black
cgblack is offline
Closed Thread Home Theater Computers
