HELP! Which MB for the 6300 Should I buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-15-2006, 12:14 PM - Thread Starter
mrpman's Avatar
OK, I decided to but a Core 2 Duo 6300 and overclock it. I would like to use this PC to hook up to my Home Theater Projector via HDMI.
After reading the FAQ on motherboards (thanks to renethx and anyone else who compiled the information) I gather that it is not a good Idea to get a motherboard with the graphics built in?
So should I stay away from the ATI and Nvidia chipsets and just got with the Intel 965 or 975 with a PCI express video card?( I want to be able to connect to a desktop display and my Projector either HDMI or DVI)
I have also read that the 965 might have better memory performance than the 975 chipset is this still true?
I just want to make sure the the MB, Memory and PCI express video card are the right combo, because I see all of these pictures of MB with two video cards connected and it is a little confusing.
Is there a MB that uses the Nvidia Chipset but Doesn't have built in video? (meaning if I buy a Nvidia chipset MB, will I have to use an Nvidia PCI express card for video?)
Any help would be greatly appreciated.
mrpman is offline
post #2 of 8 Old 12-15-2006, 01:48 PM
olyar15's Avatar
If you don't want to use the onboard video, don't use it. That shouldn't affect your buying decision. Pretty much all motherboards also come with PCIe slot for video cards.
Charles
olyar15 is offline
post #3 of 8 Old 12-15-2006, 01:58 PM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
I have the Intel D975XBX2 and I highly recommend it! Two words - "stable" and "works" best describe it. Shop around, you can get it for $199 from tiger direct.
vddobrev is offline
post #4 of 8 Old 12-15-2006, 05:54 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I wrote Hardware Recommendations for Building a High-Definition HTPC. Selecting a motherboard depends on features you want (the number of SATA ports, onboard IEEE 1394 etc.), to what degree you want to overclock (FSB over 500MHz, or modest 350MHz?) and your budget.
renethx is offline
post #5 of 8 Old 12-16-2006, 10:25 PM - Thread Starter
mrpman's Avatar
Thanks For the Replys...
I am willing to spend the following
Processor - $180 (6300 core 2 Duo retail Box)
MB - $200 (although there seems to be ones that are a lot less money that will do the same just without all the bells and whistles)
Memory - $200 (1G or Higher have not looked at prices yet but would like fast and stable)
Case - $100 (with power supply?)
Video Card - $200 (don't know which one yet)
I have read in a few places that guys are successfully overclocking the 6300 with stock cooling, thats why I figured I could save some money going with the 6300.
I don't really do any hard core gaming, but I hate a slow PC.
It seems SATA II drives are getting cheap, Are there any MB that support SATA II and is it worth it?
mrpman is offline
post #6 of 8 Old 12-16-2006, 10:33 PM
Bigjohns's Avatar
I chose this one... it's for a gaming PC for my son. For home theater, anything NVidia 6600 or better will be more than enough. This board supports SATAII drives.
http://www.asrock.com/product/ConRoeXFire-eSATA2.htm
Bigjohns is offline
post #7 of 8 Old 12-16-2006, 10:35 PM - Thread Starter
mrpman's Avatar
Which one?
mrpman is offline
post #8 of 8 Old 12-16-2006, 10:37 PM
Bigjohns's Avatar
Bigjohns is offline
Closed Thread Home Theater Computers
