Video of a GroundLoop - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-21-2006, 10:53 PM - Thread Starter
codywalker's Avatar
I have tried everything, any ideas from here please! This has been going on for months in my clients room. Here's the link of the video, only 30seconds long.
http://www.youtube.com/watch?v=s2b4SvAgXDs
It goes through a ton of stuff, but basically what you need to know is...
- All that is connected is DVD-player and Projector, using S-VIDEO cable
- Tried both on same socket (one in top plug, one in bottom plug) with cheater plugs (no grounds)
- Tried both on same socket (one in top plug, one in bottom plug) without cheater plugs (projector grounded, no ground on dvd-player)
- Tried turning off all-dimmers in the house.
- Projector at 'home screen' does not do this, only when displaying a source
- Sources have been changed out and verified
Results:
Only thing is that when I plug them into different outlets throughout the house I get different locations and intensity of the lines blinking.
My Conclusions:
- can't be the projector cause it doesn't do anything on the home screen
- can't be the source cause I've tried sources I KNOW are good
- MUST be the power?
codywalker is offline
post #2 of 16 Old 12-21-2006, 11:56 PM
SpaceCadet's Avatar
A recent post covered possible solutions.
http://www.avsforum.com/avs-vb/showt...&&#post9223630
SpaceCadet is offline
post #3 of 16 Old 12-22-2006, 02:35 AM - Thread Starter
codywalker's Avatar
yea the ground loops lines usually scroll though, mine dont.. they blink. trying another building tomorrow if no one has any great ideas.
post #4 of 16 Old 12-22-2006, 04:43 PM - Thread Starter
codywalker's Avatar
wouldn't you know it...
Took it home (exact cables,projector, and dvd-player), plugged it in and it works fine.
While I was there:
- turned off EVERY breaker in the house except the one the Outlet was on
- plugged everything into the outlet and we got the same lines.
Guessing something else on the circuit was pulling too like a fridge,ac, or something we couldn't find maybe???? Good chance its a fridge. The house is HUGE. Would this account for it?
Fridge or not...
So how do I fix it?
1. Power Filter?
2. Video Ground-Loop Isolator?
3. Ferrite Clips?
4. Battery Backup everything and run through that?
post #5 of 16 Old 12-26-2006, 02:26 AM
SpaceCadet's Avatar
I would have thought that you were using a high-quality surge suppressor with EMI/RFI filters/isolation. Try a good-quality Tripp Lite surge suppressor.
post #6 of 16 Old 12-26-2006, 07:49 AM
ToneDefJeff's Avatar
To me that looks more like electrical interference bleeding through a video cable. Not a grounding issue. How is the video cable routed to the projector and how about between components. I'd suspect it's in one of those two places.
ToneDefJeff is offline
post #7 of 16 Old 01-06-2007, 10:31 AM - Thread Starter
codywalker's Avatar
Will a UPS fix this problem?
Is this the same thing as a Power Filter? is there anything else that I might need? Isolation devices? Power Filter like a monster power filter or something like that? Or can I just get an APC UPS from Best-buy. That would be great.
post #8 of 16 Old 01-06-2007, 10:57 AM
Cody did you try what I mentioned above? If your only seeing the problem with a source connected from another location and not while the power is on to the projector I have a feeling it's in the routing of the video cable from source to projector.
A quick test is run one from the source ie: DVD player to the projector across the floor, away from everything else.
post #9 of 16 Old 01-06-2007, 11:31 AM - Thread Starter
codywalker's Avatar
ToneDef: did it, ran NOTHING except the Projector and the DVD player from like 2 feet apart... and used ALL NEW cables, replacing all the existing ones.
Will a UPS filter out the power? or do I need a POWER-Filter for that
post #10 of 16 Old 01-06-2007, 11:37 AM
AlphaFox's Avatar
to rule out the power, just charge up the ups and then unplug it from the wall. the av stuff will run off of battery and you wont be connected to the AC so no possible interference from AC sources, since you wont be plugged into it. if it still does it its probably a bad wire/routing issue.
AlphaFox is offline
post #11 of 16 Old 01-06-2007, 12:18 PM - Thread Starter
codywalker's Avatar
So if the UPS fixes it when unplugged.... Will it fix it when plugged in too? what device do I get to fix it if I don't want to hunt down the root and pay tons of time and money hunting it down..
I just need something.. power filter? if the UPS fixes it when unplugged from wall.
post #12 of 16 Old 01-06-2007, 01:06 PM - Thread Starter
codywalker's Avatar
I'm about to head over there now.... I bought this
http://www.apc.com/resource/include/...otal_watts=200
Does this function as a "power conditioner"? My plan is to plug it in and get it charged, then unplug it to make sure the bars dissappear and prove without a doubt that it is the power. (which I've already proved by bringing the devices back to the shop and they work fine here). I'm HOPING that this will work even when plugged into the wall to "condition" the power. Is this correct?
post #13 of 16 Old 01-06-2007, 04:53 PM
walter scott's Avatar
Quoted: 21 Post(s)
Having just fixed a ground loop issue, i agree, that is NOT a ground loop.
walter scott is offline
post #14 of 16 Old 01-06-2007, 11:39 PM
SpaceCadet's Avatar
If it solves your problem when it's not plugged in and the problem re-appears when it is plugged in, try one of the Tripp Lites that I suggested. They have better EMI/RFI suppression.
post #15 of 16 Old 01-08-2007, 09:54 AM - Thread Starter
codywalker's Avatar
Went there armed with MY apc, plugged everything up EXACTLY the same way it was (without the APC) and it worked fine.
I stayed for 2 hours to make sure the blinking lines did not reappear. They did not. The picture was perfect with and without the APC plugged in. I left the APC there and told them if the lines showed up they should plug EVERYTHING into it, and then unplug the APC from the wall.
I got an email today that said the lines are back. I'll ask to see if they did what I asked.
post #16 of 16 Old 01-10-2007, 02:35 PM
Sciberpunkt's Avatar
How long is this S-Video cable from the DVD player to the projector? It looks like the S-video cable is picking up radio frequency interference. Perhaps there's a CB or ham radio operator in the neighborhood or something. Try a shorter or better quality cable to see if it changes anything.
Sciberpunkt is offline
Reply Home Theater Computers
