The X-Meridian 7.1 Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 2140 Old 04-03-2007, 05:32 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1273 Post(s)
Liked: 873
I found the best music performance run X-FI in audio creation mode with Bit-matched output. The improvement is not subtle which suggests to me that the card may be capable of outperforming the current vista drivers.
My worry is that Creative could care less, they are working on getting a basic set of bloatware working on vista and a re-write to improve/restore game performance. Audio concerns seem to mostly located in Marketing
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is offline
post #722 of 2140 Old 04-03-2007, 05:43 AM - Thread Starter
ROBSCIX's Avatar
I think with Creative Labs, Pure sound quality has always been on the back burner for them. Aslong as their newest card has EAX X then the card will sell. Case in point is the X-fi elite with trash opamps as you guys put it.
I checked the Auzentech site and they have updated information regarding the X-Tension DIN board. I hope this means it is getting ready to be released to the public.
Specifications
Mic Preamplifier
1) Peak level : 0dBFS @ -40dBV
2) Gain Adjustment : Gain +20dB up
3) 5V power supply (Condenser Mic)
4) Connector Type : 1/4 TRS Input
MIDI I/O
1) 1-in, 1-out 16 MIDI channels in and out
2) Connector Type : MIDI Standard MIDI 5-pin DIN
Digital In
1) Connector Type : RCA or Optical Combo
2) Format : IEC-60958 Consumer(S/PDIF)
3) Sampling Rate :44.1,48,96,192kHz
4) Resolution : 24-bit
Digital Out
G9 Digital Out
1) Connector Type : 9-pin Mini Din Jack
Nice list of features for such a small companion board. I will be getting one to go with my XM and I/O Bracket I made for the Aux_In and the CD_IN. My audio will take up 3 slots now! -Atleast I have lots of I/O for my gear
ROBSCIX is offline
post #723 of 2140 Old 04-03-2007, 03:28 PM
BlackdogZA's Avatar
my first post on these forums
a bit of a n00b question here but what (brand/type) of cables are you using to connect the x-meridian to your receiver.
If there is anyone from the UK/EU answering this question, where did you get these cables from.
BlackdogZA is offline
post #724 of 2140 Old 04-03-2007, 04:04 PM
alg7_munif's Avatar
Cables:
I'm using these, quite thick and need to be trimmed to fit.
The favourite, Monter's
I think this is also good for the price
alg7_munif is offline
post #725 of 2140 Old 04-03-2007, 05:38 PM
dbossa's Avatar
I'm ordering these:
http://cgi.ebay.ca/Monster-Cable-mic...QQcmdZViewItem
They seem to be of even better quality than the other Monster cables that we keep seeing.
dbossa is offline
post #726 of 2140 Old 04-04-2007, 08:10 AM - Thread Starter
ROBSCIX's Avatar
If you notice how much rubber is on those 3.5mm plugs, your probably gonna have to cut some of it off with a knife. When you get them let us know if there is any difference.
ROBSCIX is offline
post #727 of 2140 Old 04-04-2007, 11:29 AM
fireanimal's Avatar
I got a custom set made by Blue Jeans Cable, really nice job, but I forgot how tight the spacing was on the output jacks, so I had to get cheap 3.5mm extension and then plug my Blue Jeans into those....Kind of defeates the pupose I guess.
fireanimal is offline
post #728 of 2140 Old 04-04-2007, 11:44 AM
Naylia's Avatar
Quoted: 17 Post(s)
I ended up going with these...they're on their way so we'll see how they work out. Radioshack has them online and they'll ship free to a store location.
http://www.monstercable.com/productDisplay.asp?pin=135
Naylia is offline
post #729 of 2140 Old 04-04-2007, 03:00 PM
dbossa's Avatar
Geez, you're right. The cables look nice and thick and the miniplug connector looks very flat so it should be able to fit side by side with others. Now that I'm looking at this I feel like a schmuck for having ordered the other ones.
dbossa is offline
post #730 of 2140 Old 04-04-2007, 05:06 PM - Thread Starter
ROBSCIX's Avatar
MOst of them I think are designed to be used for hooking up a Ipod or other device. The concept of multiple 3.5mm jack side by side doesn't enter into it. I am thinking of making a few custom sets for some guys.
@dbossa, usually you can just carve off some of the rubber around the plug.
ROBSCIX is offline
post #731 of 2140 Old 04-04-2007, 06:36 PM
fmzip's Avatar
Quoted: 47 Post(s)
Liked: 102
I went with these cables too...they worked great!
Here is a pic of the bypassed/removed capacitors (circled in yellow) for anyone else who is unclear as to which caps need to be removed. In place of the caps I used some buss wire. You can also see the location of where the LM4562's go.
My audio system setup is a Rotel RSP-1068 pre-amp, RMB 1075 Amp, B&W 703's fronts, B&W HTM-7 center and B&W HTM-7's for the rear with a Rel Strata sub. Before this card I used to listen to DVD-A's thru a Panasonic RP-91. The sound was pretty awesome. For regular Cd's I played them through a Shanling CDT-100 which is a pretty nice tube CD player ($1500).
I never heard this card in it's stock form so I can't compare it to it's original state. The only thing I can compare it to is my current audio setup.
I am running Vista 32 with the latest Auzentech drivers, no adjustments in the software, straight analog out 44 KHZ for CD's 48KHZfor DVD-A. The music is on two 200 discs Sony VGP-XLB1-2 changers, nothing fancy.......All I can say is Wow! Very smooth, transparent sound, nice tight bass. Pretty amazing! In comparison to my Shanling, I have to say I like this better. It sounds silky smooth even at high volumes. I never would have expected it!
I guess I am going to have to get the blackgate cap to see what improvement that makes....Very happy to say the least! Thanks to you guys, I bought this card. I would have never known about it otherwise! AVS is the best!
Fran
fmzip is offline
post #732 of 2140 Old 04-04-2007, 06:38 PM
fmzip's Avatar
Quoted: 47 Post(s)
Liked: 102
I tried to make some custom cables...but for less than $20 a set for the Monsters, it wasn't worth the hassle for me.
fmzip is offline
post #733 of 2140 Old 04-04-2007, 07:02 PM
Spirit2's Avatar
@fmzip
You've bypassed only the left channel caps... You gotta bypass the 2 caps to the bottom right of each opamp as well.
Should look like this:
http://www.avsforum.com/avs-vb/attac...chmentid=73548
as per markk02474's post:
http://www.avsforum.com/avs-vb/showt...&&#post9538227
The black gate cap mod I'm told won't make any difference to the audio output...
The reason they change them on the X-Fi's is due to longevity
(+ it's possible the stock X-fi cap isn't big enough)
Spirit2 is offline
post #734 of 2140 Old 04-04-2007, 08:07 PM
Pythagore's Avatar
I'm really tempted by that cap mod, but I have so much to loose if something goes wrong. After performing the cap mod, do you guys measure the output DC while playing something or at idle?
Pythagore is offline
post #735 of 2140 Old 04-04-2007, 08:33 PM
AVOpus's Avatar
you can measure it at idle.
AVOpus is offline
post #736 of 2140 Old 04-04-2007, 08:36 PM
AVOpus's Avatar
Fran
Yeah, you need to fix that other channel. Your imaging is probably a bit off. The good news is that the sound will only get better and you already like it now. Cheers!
AVOpus is offline
post #737 of 2140 Old 04-05-2007, 04:55 AM
dweekie's Avatar
Wow, that looks like some clean work. What gauge wire did everyone end up using across the points?
dweekie is offline
post #738 of 2140 Old 04-05-2007, 05:56 AM
jimwhite's Avatar
Wow... if it sounds SO good with caps on one side and no caps on the other, maybe the caps really have no significant degradation.... you would think that if they did, this configuration would sound TERRIBLE !!!
Jim White
St. Petersburg, FL
jimwhite is offline
post #739 of 2140 Old 04-05-2007, 06:04 AM
jimwhite's Avatar
Jim White
St. Petersburg, FL
jimwhite is offline
post #740 of 2140 Old 04-05-2007, 06:18 AM - Thread Starter
ROBSCIX's Avatar
@FMZIP, Yeah, that is some very clean soldering you did there. You did this or a pro? or are you a pro? Anyway the idea for the blackgate was mentioned around here before the X-fi thread ever came into the picture. A few people though the PS Cap on the XM might be starving the card of power so it was thought that replacng the card would help with Bass and dynamic's although the current results have been mixed.
@jim, I don't think it swould sound terrible, just the right side wouldn't be as clear might be hard to notice in stereo if your using headphones you would probably pick it up.
ROBSCIX is offline
post #741 of 2140 Old 04-05-2007, 06:33 AM
Spirit2's Avatar
@ROBSCIX
If you're referring to markk27xx's post about power supply mods..
He talks of replacing the 2 capacitors above and below each opamp...
Not the big one that AVOpus and others have replaced.
From blcare:
Capacitors connected to pins 4 and 8 are power supply bypass capacitors and are there to absorb noise, and keep the opamp stable. In my opinion they will have negligible impact on the sound.
Spirit2 is offline
post #742 of 2140 Old 04-05-2007, 07:12 AM
desertdome's Avatar
Quoted: 1336 Post(s)
Liked: 1525
For those looking for cables, I like the Acoustic Research Pro II Series cables for my X-Fi Elite. The mini connector is small enough for both the M-Audio Revolution and the X-Fi. Also, the mini to two RCA cable is 3' for those that don't want long cables. You can buy them at Amazon.com or other online vendors.
High Impact AV
desertdome is online now
post #743 of 2140 Old 04-05-2007, 09:12 AM - Thread Starter
ROBSCIX's Avatar
@Spirit 02. Yes those are the ones I was refering to. I haven't spoke to him for quite a while. I had ask him to explain it to me and IIRC, he said those caps may be starving the opamps of needed power. I will see if I can find the notes regarding that subject. What is the point of modding the large cap then?
ROBSCIX is offline
post #744 of 2140 Old 04-05-2007, 09:20 AM
fmzip's Avatar
Quoted: 47 Post(s)
Liked: 102
I actually am a sales rep for a company that assembles printed circuit boards. The board was reworked by an IPC certified solderer which is why it looks so good! Hard to tackle this job without the proper soldering iron and magnification and hands of a surgeon! I couldn't possibly handle those little tiny pieces of buss wire, let alone make them straight!
fmzip is offline
post #745 of 2140 Old 04-05-2007, 09:25 AM
fmzip's Avatar
Quoted: 47 Post(s)
Liked: 102
Did I miss something in my interpretation of the mod? Are there supposed to be other caps bypassed that aren't?
I blieve the operator used 28-30 ga buss wire
fmzip is offline
post #746 of 2140 Old 04-05-2007, 09:31 AM - Thread Starter
ROBSCIX's Avatar
I thought it was done by a pro, the are just too nice!! -For my reference, if others wanted this done what kind of bill would they be looking at? -I will just do mine myself but quite afew guys won't..
Yes, you need to bypass further caps -look at the two on the bottom of the Opamps you removed them on the left. They need to be removed on the RIGHT aswell.
ROBSCIX is offline
post #747 of 2140 Old 04-05-2007, 09:32 AM
fmzip's Avatar
Quoted: 47 Post(s)
Liked: 102
Originally Posted by Spirit2 View Post
@fmzip
#&*%$$! The picture I had did not have those caps bypassed.......It did seem that my left channel was quite a bit more in the forefront than the right. I hadn't set up my pre amp yet so I thought that was why! Guess I need to take care of that!! Thanks for pointing that out
fmzip is offline
post #748 of 2140 Old 04-05-2007, 09:35 AM
Spirit2's Avatar
The black gates that markk27xx mentioned, were to replace the caps that he ended up jumpering around anyway. He didn't mention any particular capacitor to use for the opamps power supply. (As far as I can tell)
I'm not entirely sure why those who have put a 2200uf 16V black gate on there have done so. The X-Fi thread suggests that for the X-Fi, the stock cap on there isn't big enough, and that the jamicon isn't likely to last very long. Hence using the black gate.
In my discussions with bclare, he said the 'power supply' caps are there to absorb noise, and to keep the opamp stable. Dunno how this figures in with markk0247's thought on them.
Spirit2 is offline
post #749 of 2140 Old 04-05-2007, 09:36 AM - Thread Starter
ROBSCIX's Avatar
I know the pic your talking about. No biggie just take it back to the person and have them finish the mod for you. What did you notice about the sound in the left channel better? You actually have the ability to do A/B comparisons by using the balance slider. This way you can fully notice what the mod has done to improve your sound. this is aunique oppurtunity, can you give use the low down of the difference you hear?
@Spirit, yeah That discussion was in PM's. I got it mixed up with forum posts.
I know why they were doing the mod on the X-fi -given the reason you mentioned.
Just unsure why people adopted that particular MOD right down to the part# and spec.
ROBSCIX is offline
post #750 of 2140 Old 04-05-2007, 09:37 AM
Spirit2's Avatar
Yeah... you woulda been looking at the first of the 2 modding posts that markk0247 posted...
(The first only has the left channel bypassed).
At least this will fix up what you're hearing
You're welcome
Spirit2 is offline
Reply Home Theater Computers
