airboard wink - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-31-2001, 10:09 AM - Thread Starter
karos's Avatar
My airboard has developed a bad habit of winking at me. No, it's not the batteries or the contacts.New batteries installed after cleaning the contacts still gives the same behavior. Even leaving the batteries out overnoight does nothing. That is-
1)when a key is pressed, the airboard is emitting a signal at 1-2 per second
2)the signal stops after 30s (airboard autosleep?)
3)moving the mouse doesnt start it up again but pushing any key does
4)control W and alt F4 keys dont work to close a window
5)really weird--->if an internet explorer window is visible, then the first keypress results in a rapid cycling of all the entries in the address bar
It still works ok but this blinking reminds me of the old crt monitors with the blinking block cursor.
karos is offline
Closed Thread Home Theater Computers
