MyHD on Vista & W7 / W8 Main Thread - Page 4 - AVS Forum
View Poll Results: What Version of Windows "Vista" are you using "MyHD" on
"Vista" Home Premium 24 24.00%
"Vista" Home Basic 1 1.00%
"Vista" Ultimate 65 65.00%
"Vista" Business 10 10.00%
"Vista" Enterprise 0 0%
Multiple Choice Poll. Voters: 100. You may not vote on this poll
post #91 of 230 Old 06-07-2007, 08:32 PM
Morpheus_Rising's Avatar
Also I get the error message "MyHD IR receiver not found. Check your serial or USB port and IR Receiver". I have the receiver pluged into the USB port.
I sometimes get this error message when I boot up and get to desktop. I just unplug the usb connector from the port and plug it back in and it fixes the problem.
Morpheus_Rising is offline
post #92 of 230 Old 06-07-2007, 10:13 PM
Lsollee's Avatar
Thanks for responding. I tried that but I still get an error.
Loren
Lsollee is online now
post #93 of 230 Old 06-08-2007, 04:19 PM
Lsollee's Avatar
Originally Posted by Lsollee View Post
Hello, I just bought a new Pc with Vista on it. I get the following error message.
"Error: (InitGraph) : could not create Janus Capture filter. Reinstall the device driver of MyHd or install the latest version of Directx". I installed the program again and I am running Directx 10. I also am running the software in the compatibility mode for Windows XP.
Also I get the error message "MyHD IR receiver not found. Check your serial or USB port and IR Receiver". I have the receiver plugged into the USB port.
Thanks in advance for any help you can give me.
Bump
Loren
post #94 of 230 Old 06-13-2007, 12:00 AM
Lsollee's Avatar
bump
Loren
post #95 of 230 Old 06-23-2007, 09:41 PM - Thread Starter
SFischer1's Avatar
Quoted: 26 Post(s)
bump
Hi,
It's Summer Time.
People are on Vacation, like me.
As not one person has reported "MyHD on Vista Goal 1:" completed, I have not changed my recommendation as to running MyHD on Vista.
I do wonder, are you running with your shields down, that is turning off most of Vista's protection. That is required and unpleasant.
I myself cannot help as I lost my Vista Installation and I will perhaps not be trying Vista again before Fall.
However, I have seen your failure message when I had other Video / Audio software with codecs installed. I often had to restart several times to switch between editing Video and running MyHD.
The best plan would be to save your data, do a clean install of Vista and install only MyHD, CW_EPG if desired and Fusion if you have that tuner also.
Then get, build or ... a new computer for your other needs. That has been the advice for a long time now and I am in the process of doing so myself. I have given up using my very powerful computer for multiple things, HTPC only usage is the only way to go. Also Unpleasant
Stephen H. Fischer
SFischer1 is offline
post #96 of 230 Old 06-25-2007, 06:24 AM
rgathright's Avatar
I have had MyHD in my HTPC for years and it normally works with no problems. I had plans on slowly upgrading a entire system, but still using XP. But our other PC died so I am in the process of turning over my current HTPC for normal use and building a brand new HTPC instead.
Right now being able to record using the MyHD is the heart of my HTPC. But now if I am to build a new HTPC I assume I would have to get Vista. Is this correct? I normally do not want a new "Windows" product until it has been bug-free for a while, but I am impatient due to not have my HTPC.
NEW ORLEANS SAINTS - SUPER BOWL XLIV CHAMPIONS
rgathright is offline
post #97 of 230 Old 06-25-2007, 06:30 AM
TPeterson's Avatar
I believe that you can still buy new machines from some vendors with XP preinstalled. Of course, there's always the option to upgrade a computer to WinXP, no matter what OS came preinstalled. Or maybe now is the time to roll your own HTPC? Then the choice of OS is completely yours.
TPeterson is offline
post #98 of 230 Old 06-25-2007, 06:46 AM
rgathright's Avatar
I am planning on building this one all by myself. I have had a long learning experience (some good and some bad) the last week working with the two current PC's.
So I could actually still buy Windows XP to use with any setup?
post #99 of 230 Old 06-25-2007, 05:39 PM
jldet5's Avatar
Sure! Last I checked windows XP OEM home was all over the place for around $80. Directron.com is one of my favs along with newegg and zipzoomfly. Check out Amazon and buy.com too.
jldet5 is offline
post #100 of 230 Old 07-14-2007, 11:40 PM
nwbear's Avatar
Has anyone found a solution to the bluescreen problem when resuming from hybrid sleep mode? I've been able to get everything else to work fine with little effort, but this one's got me stumped.
nwbear is offline
post #101 of 230 Old 07-15-2007, 06:07 AM
jldet5's Avatar
Try turning off hybrid sleep in the power options and then using hibernate instead of sleep. I know its not as nice but that is probably as good as it is going to get.
jldet5 is offline
post #102 of 230 Old 07-15-2007, 11:34 AM
nwbear's Avatar
Unfortunately that won't work for me. I use this machine as a media server and I need to be able to wake the system remotely.
I upgraded this system because of the power management features in Vista. I was never able to get XP to sleep in low power mode, and I don't want to leave this 500 watt machine running all the time.
Anyone check with Macro Image Technology to see if Vista drivers are coming? Since it's a current product I would think they'd support it at some point.
nwbear is offline
post #103 of 230 Old 07-15-2007, 03:12 PM
jldet5's Avatar
I thought hibernate would wake the same?
There has not been any developement on the MIT product for over a year. Maybe its two....I lose count. Don't wait for drivers as everyone has heard nada.
jldet5 is offline
post #104 of 230 Old 07-15-2007, 04:36 PM
TPeterson's Avatar
Look on the MyHD box. Do you see the list there of what OSes are supported? Do you see WinV included?? I didn't think so.
If WinV can't wake from S4 (hibernation) remotely, then you should upgrade your system to WinXP, because I wake WinXP systems remotely from S4 all the time.
post #105 of 230 Old 07-15-2007, 04:47 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 38 Post(s)
Liked: 147
Terry - Vista (obviously) didn't exist when the boxes were printed and it's not exactly crazy for people to ask if it will be supported at some point. The poor guy wasn't getting up on a soap box and slamming MIT for not doing so yet - he was just asking if it was going to happen. I'm sure there are lots of products that don't mention Vista support on the box that will get new drivers sooner or later, though most of them will obviously be from bigger companies that have the resources to make this more practical. No need to jump down his throat...
gsr is offline
post #106 of 230 Old 07-15-2007, 05:39 PM
jldet5's Avatar
Terry just really hates Vista, DRM, and the horse they rode in on.
Not crazy about DRM, the BS Flag, etc myself...
Nothin personal
jldet5 is offline
post #107 of 230 Old 07-15-2007, 05:44 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 38 Post(s)
Liked: 147
Nothin personal
Can't disagree with any of that myself - I just saw no need to jump down someone's throat for asking a reasonably innocent question (and I've had a bad day with car problems so I should be the one he gets to be mean)...
gsr is offline
post #108 of 230 Old 07-16-2007, 02:21 PM
nwbear's Avatar
I'm not sure why you were even looking at my previous message. I suggest you stop reading the MyHD on VISTA thread if mention of Vista upsets you.
Many things run on XP that weren't designed to. Same goes for Vista. I can't use the hibernate mode even if remote wake-up works, (and haven't even tried to) because I need the PC to wake up very quickly. S3 works great for that.
Anyone else out there have any constructive information?
nwbear is offline
post #109 of 230 Old 07-16-2007, 02:34 PM
jldet5's Avatar
Terry did confirm that you should be able to use hibernate and wake remotely. If you are not willing to work with that then I believe you need to return/sell your MYHD card and move on to the Fusion card, HD Home run, etc.
jldet5 is offline
post #110 of 230 Old 07-16-2007, 04:05 PM
nwbear's Avatar
OK - We've covered dropping Vista and we've covered getting rid of the MyHD card. Let's assume I'm going to do neither and instead try to find a different work around for this problem. I am posting this in the MyHD on Vista thread so I think it's reasonable to expect that additional responses (if any) will be from people interested in helping to get MyHD to work on Vista and not those that don't think it can or should be done.
Has anyone tried hibernating to a memory key? If it can be done does it speed up the wake up time of the system?
nwbear is offline
post #111 of 230 Old 07-16-2007, 04:14 PM
jldet5's Avatar
I haven't seen where the actual OS coming out of hibernate is all that slow. You still have to wait for the Mboard to post which is probably most of the time coming out of hibernate?
Interesting thought using a memkey for hibernate but I haven't found the need to try that yet.
If you look back a couple of pages or so you will see that I posted the same issue with the MYHD card coming out of sleep so I have seen the problem first hand. I don't believe there is any resolution except hibernate to the hard disk. Just the way it is.
jldet5 is offline
post #112 of 230 Old 09-06-2007, 03:08 AM - Thread Starter
SFischer1's Avatar
Quoted: 26 Post(s)
Hi,
In reading the document nothing jumped out at me except the size of the download, 1 Gig.
There might be some hibernation / sleep improvements.
I saw noted in KB 938979 http://go.microsoft.com/?linkid=7345605
"After you resume the computer from hibernation, it takes a long time to display the logon screen."
I lost my Vista installation and have not had time to rebuild it (Camping).
I am still waiting:
"As not one person has reported "MyHD on Vista Goal 1:" completed, I have not changed my recommendation as to running MyHD on Vista."
Stephen H. Fischer
post #113 of 230 Old 09-24-2007, 11:23 PM - Thread Starter
SFischer1's Avatar
Quoted: 26 Post(s)
I just found a link to this:
http://www.bbspot.com:80/News/2007/0...nstall-xp.html
Should the date on my computer be 04/01/07?
post #114 of 230 Old 04-26-2008, 01:18 AM - Thread Starter
SFischer1's Avatar
Quoted: 26 Post(s)
Hi,
I may be trying MyHD on WinV again.
As I will soon have a new laptop with WinV and will be installing WinV on my Video Processor PC it makes sense to try and move to just one OS including my HTPC.
But as MyHD, Fusion 5 (Fusion 7 USB in addition some of the time perhaps) and CW_EPG are working so beautifully in Windows XP, WinV has to do just as well.
I wish to ask if anyone is running CW_EPG on WinV meeting the main points in:
http://www.avsforum.com/avs-vb/showt...15#post9627015
I have been waiting for someone to report this before changing my recommendation about MyHD on WinV but there has been no reports about running CW_EPG on WinV that I have seen.
This is very puzzling!
Stephen H. Fischer
post #115 of 230 Old 06-03-2008, 09:07 AM
alk3997's Avatar
Liked: 87
This isn't the first time he has done that. My personal experience with his attitude was when I had the gall to use a dual core CPU and then ask for help solving a problem with MyHD. It is the reason I stopped appending to the MyHD thread.
Too bad he drives people away while supposedly trying to help.
alk3997 is offline
post #116 of 230 Old 06-03-2008, 09:36 AM
TPeterson's Avatar
Sooo....how's that dual core doing for you? (Mine're working fine, thanks)
post #117 of 230 Old 06-03-2008, 11:03 AM
jimwhite's Avatar
quad core now
Jim White
St. Petersburg, FL
jimwhite is offline
post #118 of 230 Old 06-03-2008, 06:01 PM
StormCrow's Avatar
Are there any advantages to using Vista over XP Pro SP3?
My XP install crashed and burned. I decided to try my Vista 64 Ultimate copy...Had no luck getting my Philips sound card and the MyHD drivers to install.
Tried my Vista Ult. 32 bit copy, got the drivers to load, then started getting those unsupported OS dialogs popping up with MyHD.
After all this, appears my HDD is failing, since I finally lost bootablity.
When I get a new HDD, should I just install XP Pro?
StormCrow is offline
post #119 of 230 Old 06-03-2008, 06:07 PM
TPeterson's Avatar
I would.
post #120 of 230 Old 06-03-2008, 06:20 PM
StormCrow's Avatar
Thanks Terry,
Yep, though it feels odd leaving these Vista discs on a shelf....as long as I have My 100 and 120 cards, I'll just stick with XP.
They have been so stable on XP these days, that's why I have been away from the threads
Reply Home Theater Computers
User Tag List
