Question about Decoding HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-31-2007, 11:40 AM - Thread Starter
Dukenightvision's Avatar
I have a question about the decoding process when I am simultaneously recording and watching a HD stream.
I'm using SageTV to both record and watch HD-TV on a Syntax Olevia 532H LCD HDTV. My computer is connected to the 532H via DVI-HDMI cable. The native resolution of the 532H is 1366X768 (supports 1080i when watching TV via the tuner).
Now my question: When I am watching a HD program that is being streamed at 1080i, is my computer's GPU (Nvidia 7800 Go) actually processing the stream to my HDTV at 1080i or is it down converting the 1080i stream to the native 720p HD resolution of my 532H? I sometimes use the Overlay setting and at times I use VMR 9.
Dell Inspiron E1705
Windows XP SP2
Dual Core T2400
1GB RAM
Nvidia Go 7800 (256MB)
Nvidia Purevideo Decoder
Artec T14A USB HD Tuner
Dukenightvision is offline
post #2 of 8 Old 01-31-2007, 11:46 AM
Targus's Avatar
What have you set the resolution to?
Targus is offline
post #3 of 8 Old 01-31-2007, 12:09 PM
stanger89's Avatar
Quoted: 3383 Post(s)
Liked: 1843
It will deinterlace (if necessary) and scale to whatever your desktop resolution is. This applies regardless of video resolution or display resolution.
stanger89 is offline
post #4 of 8 Old 01-31-2007, 12:13 PM
umdivx's Avatar
Your video card will down convert, or down-rez the 1080i video to whatever the resoulution your video card is set to.
So if your video card is setup and outputting 1366 x 768 that 1080i video is down converted to 768p.
BTW your tv basically does the same thing. When your watching a 1080i video with teh built in tuner of the tv, your TV has an internal video scaling chip, this scaling chip, scales that 1080i video to the native rez (ie 1366 x 768) of your tv.
make sense?
- Josh
umdivx is offline
post #5 of 8 Old 01-31-2007, 12:51 PM - Thread Starter
Thanks for all of the quck replies. I really appreciate it.
My screen resolution is set to native (1366X768). When I set the resolution on my GPU to output 1080i to my TV, I get a bad flickering effect. I've read on another thread that my Olevia 532H is not capable of displaying 1080i when connected to my computer using the DVI-HDMI cable, but will display 1080i when using the component connection on the TV. I've purchased a DVI-i to Component cable from monoprice.com so I can output 1080i to my 532H.
So if I am able to change my TV resolution to 1080i, does this mean that my GPU won't have to deinterlace and scale down the 1080i HD stream?
I'm asking this question because at the present time when watching a 1080i HD program, I get a little video stutter at times. I'm wondering if the stuttering is due to my GPU deinterlacing and scaling the 1080i stream to 1366X768. If the GPU has less work to do, I'm wondering if the ocassional video stutter will stop.
post #6 of 8 Old 01-31-2007, 01:09 PM
umdivx's Avatar
My screen resolution is set to native (1366X768). When I change the resolution on my 532H to output 1080i, I get a bad flickering effect. I've read on another thread that my Olevia 532H is not capable of outputting 1080i when connected to my computer using the DVI-HDMI cable, but will display 1080i when using the component connection on the TV. I've purchased a DVI-i to Component cable from monoprice.com so I can output 1080i to my 532H.
Sorry to tell you but that DVI to component cable won't work. Not with Nvidia video cards atleast.
either way your TV won't do 1080i, Like I said before, your TV will accept a 1080i signal but it won't display in 1080i lines of resolutions.
ANY 1080i video on your TV, is down converted to 1366 x 768.
So its weather you want your TV to down covert the 1080i or if you want your video card to down convert.
Honestly I have my PC do the scaling, meaning my PC converts all 1080i signals to 720p before its sent to my projector.
I bet you that the PC does a better job of de-interlacing 1080i video than your TV does.
What mpeg decoders are you using? you might have better performance changing the de-interlacing and video settings in the decoders.
If you try feeding your tv a 1920 x 1080 resolution i bet you'll get more shuddering that way, than the way you are now.
- Josh
umdivx is offline
post #7 of 8 Old 01-31-2007, 01:20 PM - Thread Starter
Thanks for the education, Josh. I'm using Nvidia Purevideo decoder. I'll play with the settings to see if that helps.
post #8 of 8 Old 01-31-2007, 01:25 PM
umdivx's Avatar
Try changing the de-interlace to video, or smart. also if your on overlay for video try VMR9 or the opposite if its on VMR9 try overlay.
- Josh
umdivx is offline
Reply Home Theater Computers
