Stream audio & video from my Home PC to My HT7.2 Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-01-2007, 12:58 PM - Thread Starter
maransm's Avatar
Hello,
The following is my HT setup:
My 7.2 HT Setup:
TV - NEC 50XR5
Receiver - AVR-740
Center Speaker - TSS- SAT4000 Center
Left & Right - TSS-SAT4000
Surrounds -TSS- SAT1100
Subwoofer - left & Right -TSS-SUB4000
DVD player - DVD 47
Remote - Logitech Hormony 890
Dish - Dish network DVR ( dont remember the model #)
- I have all the components sitting inside the closet and I use Harmony 890 to control.
- I have my Home PC where I have songs and downloaded low quality (international) movies and would like to watch it from my HT.
Question:
What video card do I need in my PC to connect it to my receiver HK 740. (it supports HDMI inputs)?
All I need is to play those downloaded VCDs, DVD rips and .VOBs from my PC to my HT?
I probably need to do some home work, but it would be helpful if someone could lead me to the right direction.
Thank you.
maransm is offline
post #2 of 3 Old 02-01-2007, 01:15 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Well, you need an HDMI equipped video card and at the very least something to control the PC. Either a wireless keyboard/mouse or a remote.
Check out this thread.
http://www.htpcnews.com/forums/index...howtopic=23416
kapone is online now
post #3 of 3 Old 02-02-2007, 09:32 AM
The Canuck's Avatar
Why do you want to connect the video card to the receiver? Just get a sound card with digital out (coax or optical) and connect that to the receiver.
I think the NEC has a vga port at the back, so just pick yourself up a VGA cable and you'll be good to go. Or you could get a DVI-HDMI cable.
The Canuck is offline
Reply Home Theater Computers
