DB15 to componet can it be done??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-23-2007, 07:02 PM - Thread Starter
rkm
rkm's Avatar
I need to find a way to convert my Db15 monitor connection from my laptop to a component signal...... How is this possible? I thought KeyDigital would have something but I haven't found it yet. Any ideas?
rkm is offline
post #2 of 7 Old 02-23-2007, 08:51 PM
cowanrg's Avatar
Quoted: 45 Post(s)
yes it can be done.
http://www.partsexpress.com/pe/showd...number=181-702
here is just one example. search the web for db-15 to component, or vga to component, stuff like that.
cowanrg is offline
post #3 of 7 Old 02-23-2007, 08:56 PM
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
mlknez is online now
post #4 of 7 Old 02-23-2007, 08:57 PM
Parabellum's Avatar
Blue jeans cable can customize any cable you need, actually. Including DB15 to component
Parabellum is offline
post #5 of 7 Old 02-23-2007, 09:22 PM
kylebisme's Avatar
Those are just for devices that output or accept a component signal through a DB15, to covert the signal you need a transcoder like this:
https://www.audioauthority.com/index...ore&iProduct=2
kylebisme is offline
post #6 of 7 Old 02-23-2007, 10:01 PM
Rupert's Avatar
Originally Posted by kylebisme View Post
Those are just for devices that output or accept a component signal though a DB15 though, to covert the signal you need a transcoder like this:
Agreed. You can't just use a component cable on a VGA connection on a laptop. The signal must be transcoded.
The cables shown above will work with certain projectors, etc. that have been specifically designed to input component over certain VGA pins. They won't work with laptops.
Rupert is offline
post #7 of 7 Old 02-24-2007, 05:28 AM - Thread Starter
rkm
rkm's Avatar
You got it kylebisme. That is what I was looking for. I knew their was a cable for HD for what I want, and I knew it wouldn't work for a computer. Thanks
rkm is offline
Reply Home Theater Computers
