Control STB from PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-06-2007, 10:45 PM - Thread Starter
nickolasj80's Avatar
I would like to run my cable STB into my tuner/capture card, but would like to be able to change the channels via software on the PC...how is this done?
I am currently running MCE 2005, and from what I have found, I need something called an "IR Blaster"? but there seems to be compatibility issues with MCE 2005.
Also, from what I read about the IR Blasters, I couldnt find any way to control it via software.
Any help with this would be appreciated!
thanks,
Nickolas
nickolasj80 is offline
post #2 of 6 Old 04-06-2007, 11:12 PM
galileo2000's Avatar
usb-uirt?
www.usbuirt.com
you'll need something like xlobby www.xlobby.com or Girder to use it.
xlobby is still free for now ( oh well I haven't checked in few weeks it went commercial not too long ago) and most excellent front end I've ever seen.
Good time to buy computers and computer parts: NEVER
galileo2000 is offline
post #3 of 6 Old 04-07-2007, 01:12 AM - Thread Starter
Originally Posted by galileo2000 View Post
usb-uirt?
www.usbuirt.com
thanks for the suggestion...i read somewhere that USB-UIRT may not be compatible with MCE 2005, is this correct?
Also, xlobby looks nice, but, for the purpose I need, it seems like a bit of an overkill, is there perhaps a simpler application, meant for JUST talking to my STB?
post #4 of 6 Old 04-07-2007, 01:47 AM
S-dogg's Avatar
Your remote sensor for the MCE remote should have a port for an IR blaster on the back. You can pick them up at Rat Shack or a similar store.
The control for that blaster is configured within the MCE software. I don't recall the exact location, but it's there in the menus. Just poke around, and I'm sure you'll find it.
Insanity is just a state of mind
Visit the Atomic Playground for the latest on movies, video games, computers, and more!
http://atomic-playground.blogspot.com
S-dogg is offline
post #5 of 6 Old 04-07-2007, 03:19 PM
joeyjoeyjoey's Avatar
MCE supports IR Blasters which connect to your IR receiver then you affix it (usually they are self adhesive) to the IR receiver of your STB.
When you go and setup your TV signal there is an option that states you are using a set top box. Select that and when it comes to changing channels in MCE it will send a change channel signal through the IR blaster to your STB thus changing the channel.
This link may help
Also this information is found in the MCE 2005 software manual.
joeyjoeyjoey is offline
post #6 of 6 Old 04-07-2007, 03:21 PM
umdivx's Avatar
also check out fireSTB http://home.comcast.net/~timmmoore/firewire/readme.htm
depending on which cable box you have you can control it via firewire or RS232 from your pc.
- Josh
umdivx is offline
Reply Home Theater Computers
