What do you use to play HD x264 files? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-07-2007, 07:03 PM - Thread Starter
trueimage's Avatar
Quoted: 37 Post(s)
I'm trying to play some 720p x264 (.mkv container) files and I'm having some problems.
They seem much easier to make stutter etc and I want to get the best quality out of them. Also, almost all have sound delay, but ffdshow audio processor with Jitter OSD shows 0 ms?
I have a 720p DLP and the following is a rough description of my HTPC build:
C2D 6400
2GB ram
nVidia 7900 GS HDCP via DVI
Win XP Pro SP2
Any ideas? I'm starting to get a lot more of these files and I'm wanting to start to backup my HDTV caps in this format too instead of xvid...
trueimage is offline
post #2 of 17 Old 04-07-2007, 07:04 PM
umdivx's Avatar
umdivx is offline
post #3 of 17 Old 04-07-2007, 08:22 PM - Thread Starter
trueimage's Avatar
Quoted: 37 Post(s)
Don't I need the Haali splitter for mkv?
post #4 of 17 Old 04-07-2007, 10:51 PM
uncertainty's Avatar
Media Player Classic is one of the few that does not require the Haali splitter as it has native support of mkv within it.
uncertainty is offline
post #5 of 17 Old 04-08-2007, 02:25 AM - Thread Starter
trueimage's Avatar
Quoted: 37 Post(s)
How can I try playing these files with the Pure Video HD HW/SW acceleration. doing some reading it says that this is much better than CoreAVC, and my card is on the supported list. Does this only work for HD DVD / Blu-ray ? or can I get for example PowerDVD Ultra 7.3 to play these as well using HW accel?
post #6 of 17 Old 04-08-2007, 04:25 AM
dirkling's Avatar
PowerDVD Ultra 7.3 does use nVidia hardware acceleration and includes H.264 support. If you want to use version 6 you need to add the AVC and AAC packs.
WinDVD and Nero also support nVidia hardware acceleration.
dirkling is offline
post #7 of 17 Old 04-08-2007, 04:56 AM
Mark_A_W's Avatar
Zoomplayer with Haali and CoreAVC.
Loving my Electric Bike!!
Mark_A_W is offline
post #8 of 17 Old 04-08-2007, 11:05 AM - Thread Starter
trueimage's Avatar
Quoted: 37 Post(s)
I can't get PowerDVD Ultra 7.3 to open an mkv
when i drag it over nothing happens, when i try to add it to the playlist, it won't add...
post #9 of 17 Old 04-08-2007, 11:33 AM
PowerDVD requires Haali for mkv...
post #10 of 17 Old 04-09-2007, 03:00 PM - Thread Starter
trueimage's Avatar
Quoted: 37 Post(s)
ok, I have Haali installed... still can't play mkv's in PowerDVD 7.3 Ultra
post #11 of 17 Old 04-09-2007, 03:03 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Coreavc produces artifacts with encodes. I suggest using the latest ffdshow, you have the cpu power for it.
Powerdvd has a 264 decoder which you can use in a media player that uses directshow codecs such as zoom player or media player classic. I dont think powerdvd accepts .mkv as input.
Mrkazador is offline
post #12 of 17 Old 04-09-2007, 04:42 PM - Thread Starter
trueimage's Avatar
Quoted: 37 Post(s)
so how can I get hardware accel to work?
These are 720p x264
can I rename the extension or convert them losslessly to an x264 format powerdvd will play?
I've read quality wise and cpu wise the purevideo hd hw accel is best, but only 3 dvd suites use it, and they wont play mkv?? so why do ppl use mkv??
post #13 of 17 Old 04-09-2007, 04:48 PM
stickygreen's Avatar
Media player classic, and Core AVC, works great, and super easy.
don't worry about your vid card bieng suported for the app, cause h264, dosen't use the GPU, it uses your comps processor to decode the file.
stickygreen is offline
post #14 of 17 Old 04-09-2007, 05:09 PM - Thread Starter
trueimage's Avatar
Quoted: 37 Post(s)
That's what I'm saying
PureVideo HD does use GPU to decode h264
post #15 of 17 Old 04-10-2007, 12:03 PM
iRobie's Avatar
Sounds like something else is interfering with your video playback. I have a C2D 4300 with an Intel 965 video card (mobo integrated), 1gb RAM, and it plays back fine on a 47" LCD screen.
FFDShow: No problem playing back 720p, h264, AC3 files (slight stutter on 1080p)
CoreAVC: No problem playing back 1080p, h264, AC3 files
Zoomplayer as the player, though Media Player Classic works too
Since my computer has less impressive specs than yours, I'm suspecting a software issue.
Here's what I did to get my software the way I wanted it:
--(Uninstall everything related in your case. Use Insurgent from http://www.cccp-project.net/ to remove extra stuff)
--Install your DVD player (PowerDVD in my case)
--Install the Combined Community Codec Pack. (My codec pack of choice. Very light.)
--Install CoreAVC
--Use Radlight Filter Manager to change PowerDVD h264 to less preferred, FFDshow for normal preferred for h264, and CoreAVC to preferred for h264
--Reboot
iRobie is offline
post #16 of 17 Old 04-10-2007, 12:49 PM
It seems due to some proprietary coding in PowerDVD that mkv's will not play correctly. Seems most people recommend to convert (not transcode just re-wrap) the file to avi in order for it to play in Powerdvd.
Other option of course is use a different player such as MPC.
post #17 of 17 Old 04-10-2007, 03:43 PM
slim313's Avatar
Search google for the Combined Community Codec Pack. Has everything you'll need.
slim313 is offline
Reply Home Theater Computers
