nvidia 8600 / 8500 series info - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 828 Old 05-12-2007, 06:57 AM
Powerage's Avatar
Originally Posted by ditcho View Post
I dn't know why you guys continue to bang your heads over the most difficult and almost impossible problem - to get an HTPC to output flawless interlaced resolution. Even if you set the desktop to be 1080i, AFAIK no player can pass exactly the 1080i material without down -p and so on scaling and interlacing, effectively killing a huge amount of the resolution.
What is your solution?
Powerage is offline
post #362 of 828 Old 05-12-2007, 07:34 AM
Tinker's Avatar
Location: guarding my retirement igloo...with a McMillan TAC-50 long range sniper rifle
Originally Posted by Favelle View Post
Thanks for info but being from Canada, most US onlines shops dont really service up north that well, if at all. But thanks anyway
???? Who needs the US shops. I got my PASSIVE 8600GTS for $220 Cdn and I live in BC:
http://www.avsforum.com/avs-vb/showthread.php?t=845569
I get my stuff local or from NCIX.
Silent vid cards are great on paper, but after using a few I found them not the ideal for "my" HTPC builds. Yes they are silent but you really need good air flow to make them effective. In most HTPC cases, the air flow is limited due to case design/size and the desire to keep intake/exhaust fans quite has limited what a passive cooled vid card can do in my builds. Every one I used in the past always heated the inside of the HTPC up and needed more air flow from various fans and the noise was just trade off between the case fans and the passive vs active vid cards. Yes they work but usaully the passive versions cost more then the active ones. Its just comes down to a trade off, a little noise from the vid card or a little noise from the case fans. Just IMO
You do not stop playing because you get old...
You get old because you stop playing.
Tinker is offline
post #363 of 828 Old 05-12-2007, 08:16 AM
arfster's Avatar
Silent vid cards are great on paper, but after using a few I found them not the ideal for "my" HTPC builds. Yes they are silent but you really need good air flow to make them effective. ...
You're quite right - it's really common problem (and not just in HTPC cases). The way I got around it was buying a 120mm fan and rubber mounting it on top of the (previously fanless) heatsink. You can then downspeed said fan to 700/800rpm or so, at which point it's basically silent. It's still kicking out far more air then the typical useless 60mm GPU fan running at hurricane-noise speeds, so cooling is no problem either.
An even smarter way would be a case where a 120mm gpu fan blew air over the heatsink and exhausted it directly out the back, and also acted as the case's main fan exhaust. Something for the custom builder I think :-)
Anyway, I don't know why gpu makers haven't started using larger fans - for HTPC noise purposes you'll never get a 60mm to work properly, or even a 80mm. A good 92mm might work though - 120mm is ideal, but isn't the easiest to shoehorn into tight spaces.
arfster is offline
post #364 of 828 Old 05-12-2007, 10:56 AM
Thuppu's Avatar
Has anybody get hands on Club 3D 8500GT Silent graphic card? Should be hdcp compatible.
Thuppu is offline
post #365 of 828 Old 05-12-2007, 11:26 AM
Favelle's Avatar
These guys are HDCP and passive:
http://www.ncix.com/products/index.p...cture=Gigabyte
In terms of LFE, size does matter!
Favelle is offline
post #366 of 828 Old 05-12-2007, 11:34 AM
bobby1234's Avatar
Yes I'm also interested in this. Same price where I live as the Gigabyte 8500 GT but the added bonus of 512 instead of 256 memory.
Only thing is that there's no hdcp confirmation from what I can see on the Club3D website or specs pdf? But I've seen it listed as hdcp compatible in many shops.
If someone gets this card I would like to know for sure about the hdcp support.
bobby1234 is offline
post #367 of 828 Old 05-12-2007, 11:49 AM
ditcho's Avatar
720p
ditcho is offline
post #368 of 828 Old 05-12-2007, 11:55 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
Yes. I have one, they can be found cheaper than that. Pricegrabber is your friend.
Before that I had an 8800GTS. Without Hardware acceleration, it performs the same as the 8800. With hardware acceleration it is about 70% less CPU on HD mpeg4.
Also, uses 70 to 100watts less power in my HTPC.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #369 of 828 Old 05-12-2007, 01:42 PM
Tinker's Avatar
Well I returned the XFX 8500GT and got an ASUS 8600GTS. 1080i now works with no issues. Well I guess you get what you pay for in this case. If this card works out in the next couple of days, the 8600GTS will replace the MSI 7600GT Diamond Plus (since I can't seem to get anymore of them in Canada) for my HTPC builds. Not as clean with the DVI-HDMI route compared to the straight HDMI of the MSI card but its plus's are DX10, dual linked DVI's and maybe future HD GPU accelleration in XP. Bonus its also slightly cheaper then what I was paying for the MSI Diamond Plus card a few months back and a lot cheaper then the 8800GTS 320mb cards that I have been using for pure HTPCs (over kill).
Tinker is offline
post #370 of 828 Old 05-12-2007, 04:28 PM
Favelle's Avatar
That is also in Canadian funds. Shave off about 20-25% if you are paying in US doll hairs.
Favelle is offline
post #371 of 828 Old 05-12-2007, 04:53 PM
Joseph Clark's Avatar
Quoted: 266 Post(s)
Liked: 318
The nVidia drivers page lists Win XP as supported for the 8500/8600 cards, but earlier in the thread someone mentions that the HD support only works in Vista. I'm thinking of upgrading one of my computer systems, but I want to be able to run XP, not Vista, because of lack of support for a device I'm using (R5000 modded Dish 211). Can anyone clarify?
Joe Clark
Joseph Clark is offline
post #372 of 828 Old 05-12-2007, 05:04 PM
lobosrul's Avatar
Quoted: 543 Post(s)
Liked: 308
I think an XP driver update is expected for the new HD support. However, I see on Guru3d.com a beta driver (160.03) for XP!
http://downloads.guru3d.com/download.php?det=1633
lobosrul is offline
post #373 of 828 Old 05-12-2007, 05:43 PM
Quoted: 266 Post(s)
Liked: 318
Great! Has anyone tried this beta driver yet? An 8600 would serve my needs perfectly, since I am not a gamer at all and an 8800 would be overkill.
Joe Clark
post #374 of 828 Old 05-12-2007, 06:47 PM
heartsurgeon's Avatar
just to amplify Arfster's comments..
I have the Gigabyte 8600GTS which is fanless. Yes, it works well, the GPU temperatures are quite reasonable. However, the heatsink puts out a massive amount of heat. The heat sink faces away from the CPU, and away from the exhaust fans in the case (rackmount). In order to get the heat out of the case, I'm going to waterjet a blowhole above the area where the vid card and the expansion cards go, and mount a Nexus 120 mm fan controlled with a zalman fanmate (hopefully will be inaudible). While I'm at it, I'm going to mod a hard drive enclosure that has 3 heinously loud fans, and the top of my rack enclosure to vent out heat from the receiver the same way.
one question.. what causes tearing?
i was watching Office Space with theatertek/Win XP..got some tearing when there was rapid headmovement in a vertical manner (at 1080P)
Rule #1: You haven't wasted your money...you just haven't spent enough yet.
Rule #2: When in doubt...get both.
Rule #3: No need to invoke malice when stupidity alone suffices.
heartsurgeon is offline
post #375 of 828 Old 05-12-2007, 07:34 PM
Powerage's Avatar
Thanks for the link.
Can anyone confirm if this helps with VC1 / CPU Consumption & Stability under XP SP2?
Powerage is offline
post #376 of 828 Old 05-12-2007, 07:51 PM
arfster's Avatar
Go into the TT settings and turn on fullscreen mode, that'll get rid of it. Tearing is really common with all NVidia cards unfortunately, and this is pretty much the only solution.
arfster is offline
post #377 of 828 Old 05-13-2007, 03:50 AM
Thuppu's Avatar
Crap! There was hdcp listed in the specs when I put the link. Seems that Gigabyte is the only hdcp compatible 8500GT card. Seems that I have to cancel my order on Club 3D and put a Gigabyte on order.
Thuppu is offline
post #378 of 828 Old 05-13-2007, 06:42 AM
Signal64's Avatar
I can't comment on VC1 with these drivers, but overall I do seem to be getting worse performance with them on a XP SP2 box (w/ 8600GT). It's acting like it isn't doing anything.
Using the Windows KMPlayer (not related to the KDE Linux flavor) and switching between it's internal H264 and Cyberlinks saw no difference in CPU usage. DXVA is checked and verified KMPlayer's internal was off.
Prior I was getting about 30-35% on an AMD2 3800, but now getting 45-67% with spikes up to 100% with the same source. I tried various overlay modes as well.
It's the same (albeit much lower CPU usage) with DVD content in PowerDVD.
Either with Hardware Enabled or not, the CPU usage is the same.
And yea, I could be doing something wrong here and will reload with the "old" drivers to verify.
Signal64 is offline
post #379 of 828 Old 05-13-2007, 06:47 AM
arfster's Avatar
You need to wait for the new XP drivers next month unfortunately - the current ones only hardware accelerate on Vista.
arfster is offline
post #380 of 828 Old 05-13-2007, 09:19 AM
Thuppu's Avatar
Can anybody who has the Gigabyte 8500GT tell the physical length of the card. Does my htpc case have room for it..? Is it shorter than a 7950GT? Thanks.
Thuppu is offline
post #381 of 828 Old 05-13-2007, 11:55 AM
ol623's Avatar
I think it's a bit shorter than the leadtek 7950gt I replaced.
ol623 is offline
post #382 of 828 Old 05-13-2007, 12:48 PM
rsandor's Avatar
Just installed the Gigabyte 8500GT fanless in a small HTPC case, so far so good. It replaced an EVGA 7600GT and it is a delight to lose the noise of the GPU cooling fan.
Only issue I(I think) is the airflow over the heatsink. Using Ntune utility, monitored the CPU at 31C but the GPU is running 65C when watching HD DVD content.
Would like to find out other's GPU temps are similar and should I worry about finding additional airflow.
rsandor is offline
post #383 of 828 Old 05-13-2007, 12:50 PM
CrispyFish's Avatar
Perfectly acceptable.
CrispyFish is offline
post #384 of 828 Old 05-13-2007, 12:52 PM
arfster's Avatar
I'd hope so - one of mine is the same and it actually has a fan....
arfster is offline
post #385 of 828 Old 05-13-2007, 01:39 PM
Thuppu's Avatar
Ok, thanks! Should be perfect.
Thuppu is offline
post #386 of 828 Old 05-13-2007, 03:10 PM
Quoted: 266 Post(s)
Liked: 318
Are you running Vista or XP? What kind of CPU do you have and do you have any CPU utilization numbers during HD DVD playback? I plan on upgrading one of my systems, but I want to stick with XP. Trying to figure out the best mobo, CPU, video card combo.
Joe Clark
post #387 of 828 Old 05-13-2007, 03:43 PM
Signal64's Avatar
It got lost in my reply, but I was looking at the recent May Beta driver to see what it offers.
Signal64 is offline
post #388 of 828 Old 05-13-2007, 04:09 PM
rsandor's Avatar
Thanks Arfster and Crispy for the feedback on temps. I won't worry now and I'll just leave the case as is. Very nice to have a quiet system- this one is in the master br so silence is a big factor.
Joseph- I am running XP MCE, so no acceleration for HD DVD. Using AMD Athlon XP dual core 4600 (legacy 939 socket stuff) on an Asus 6150 type MB (don't use the onboard graphics). Looking at CPU utilization it was somewhere around 50-75%. System is about a year old so probably would do things a lot differently now.
Don't know if it is placebo effect, but pictue appears to be much cleaner and pans are smoother using the 8500GT.
-Bob
rsandor is offline
post #389 of 828 Old 05-13-2007, 05:18 PM
Favelle's Avatar
Is this for SD-DVD or HD? Apparently, the 8500/8600 series upscale extremely well!
Favelle is offline
post #390 of 828 Old 05-13-2007, 08:22 PM
rsandor's Avatar
I have primarily been watching HD, so my observations are probably limited. However, even the standard XP desktop looks clener. I am using it via VGA output (over DVI connector) into a 1920x1080 Sceptre display. I'll have to look closer at SD DVD (but once you get spoiled by HD.....)
-Bob
rsandor is offline
Reply Home Theater Computers
