MCE remote with Meedio - AVS Forum
post #1 of 2 Old 04-25-2007, 07:58 AM - Thread Starter
Warren_G's Avatar
Hi,
I am just setting up a new HTPC, and am trying out Meedio with an MCE remote. I have the Zalman HD160 case with the built in IRTrans and VFD.
My problem is this, when I use the MCE remote, I seem to get 2 commands sent for many of the button presses. When I try to learn a command, for instance arrow down, it sends and learns both mceremotedown and Keyboard down. In Meedio, when I press down, it jumps down 2 lines. I can sorta fix this by turning off the IRTans plugin in Meedio, and the keyboard down command still works, but then many of the other buttons on the remote do not do anything. Am I out of luck? Do I need to use a different remote? I have a few other remotes, but I use MCE upstairs, and for ease of use, it would be nice to use the same remote, and set itu p to operated the same way as the MCE interface. Any helpis appreciated, thanks.
Warren_G is offline
post #2 of 2 Old 04-25-2007, 08:40 AM
UFGrayMatter's Avatar
Originally Posted by Warren_G View Post
Hi,
Are you using HIP? There is also a MCE Remote Plugin for meedio, you should have that.
UFGrayMatter is offline
Reply Home Theater Computers
User Tag List
