Has anyone gotten the VGX-XL3 to do 1080p instead of 1080i? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-02-2007, 03:30 PM - Thread Starter
rangerx83's Avatar
...I can't find a way. I'm connected via HDMI to a Sony 52" Bravia. I'm aware that the XL1 or XL2 can do it, but the XL3 does NOT seem to support it.
Thanks in advance.
rangerx83 is offline
post #2 of 8 Old 05-03-2007, 03:54 AM
imws's Avatar
I noticed this as well on a demo machine at J&R the only hd resolutions listed were all interlaced. I believe it is related to the monitor driver that is being used. It is a generic PnP driver at least on the J&R machine. This was connected to a 46" Sony Bravia LCD. There's not a lot of information on this machine on the internet.
imws is offline
post #3 of 8 Old 05-03-2007, 07:53 AM
EnterFace's Avatar
That is the way my computer came this week with that generic driver for some run of the mill monitor, I wonder if there are any drivers out there that take HDTVs into consideration? I have my computer connected to a Sony 60XBR2 that is supposed to be 1080p but I'll never know since my Blu-Ray optical drive seem to do only interlacing.
EnterFace is offline
post #4 of 8 Old 05-03-2007, 09:36 AM
EnterFace's Avatar
Thanks in advance.
Check your PM
post #5 of 8 Old 05-26-2007, 10:43 AM
ds7777's Avatar
yeh even my vaio ar-38g cant output 1080p onto my 60" sony xrd tv (which supports 1080p). i wish i could find a way to get this to work! do let me know if u find anythign that allows this geforce go 7600 GT to output 1080p!
ds7777 is offline
post #6 of 8 Old 06-06-2007, 09:40 AM
pdampier's Avatar
I got 1080p once but then lost it.
History:
Installed machine for the first time - Applied all WU updates and Norton updates. Updated in-box Sony driver to the driver on the CD they ship with the XL3 (98.13). Used the system like that for a while. Updated the drivers to 158.24 from the nVidia web site. During the install (after the installer uninstalled the two previous nvidia drivers) the screen went black and never came back. Once the HDD stopped spinning I hard powered it down and on reboot I had 1080p as an option. However I had no sound at all over HDMI to the TV (it had worked prior).
I did a system re-image (F10 on POST). While this was going on I changed the TV over to another HDMI connection and noticed no audio on that - Turned TV off/on and audio was back! Damn, it was a TV issue most likely....
Since the re-image I have re-tried the above but still only get 1080i with the 158.24 nVidia drivers...
pdampier is offline
post #7 of 8 Old 06-06-2007, 10:53 AM
Ralph3's Avatar
Ralph3 is offline
post #8 of 8 Old 12-14-2007, 10:34 AM
techieg's Avatar
See my posting in the following thread to set 1080p; http://www.avsforum.com/avs-vb/showt...hlight=vgx-xl3
Open Software Foundation.
http://www.opensoftwarefoundry.org
The Foundation for Information & Communications Technology.Â
Open Systems, Inc.
http://www.opensysinc.net
techieg is offline
Reply Home Theater Computers
