VC1 not supported in Nvidia 8500/8600. Any news when supported ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-10-2007, 12:50 AM - Thread Starter
8:13's Avatar
I think HD-DVD uses VC1, right ?
And this article says that the Nvidia 8500/8600 that's got everybody excited doesn't support it, or accelerate it.
I was looking at buying a 8600 but I think nw I'll wait till 2008 when the HD dominance is obviously either BD or HDdvd.
Tomshardware said to wait till 2008 before buying HD stuff.
Rather irritated right now, but I can wait.
There is new, and then you are new.
This is a moral of the bears and their cereal.
8:13 is offline
post #2 of 8 Old 05-10-2007, 12:56 AM - Thread Starter
8:13's Avatar
ha ha. VC-1 made me think of "Vito Cornelius". I dunno.
8:13 is offline
post #3 of 8 Old 05-10-2007, 12:59 AM
eric.exe's Avatar
Quoted: 16 Post(s)
Only really weak CPUs really need VC-1 acceleration. The codec very efficient and doesn't require that much horsepower. You probably only "need" acceleration for AVC MPEG-4. This could be why nVidia is taking their time with developing it, or might not at all.
eric.exe is offline
post #4 of 8 Old 05-10-2007, 01:01 AM - Thread Starter
8:13's Avatar
Would a E6600 that's not overclocked work ?
Any news if there will be a low-profile Nvidia 8600 ? Links ?
8:13 is offline
post #5 of 8 Old 05-10-2007, 01:11 AM
skibum5000's Avatar
Quoted: 48 Post(s)
Liked: 49
if by not that much horsepower you mean dual core or extreme single core.
once you have that is does run easily enough. but my old single core AMD totally choked on many VC1 titles.
skibum5000 is offline
post #6 of 8 Old 05-10-2007, 02:47 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The ATI Radeon HD 2000 series card provides complete hardware decoding in both H.264 and VC-1. Just wait till June. The price is very competitive:
HD 2600 XT: $199
HD 2600 Pro: $179
HD 2400 XT $99
HD 2400 Pro: ? (720p only)
The Clash of the Titans - AMD's R600 preview
renethx is offline
post #7 of 8 Old 05-10-2007, 05:41 AM
arfster's Avatar
It uses mainly VC1 (which is easy to decode), but also and increasingly h264 (which isn't).
The 8500/8600 can only accelerate VC1 with Vista at present, you'll have to wait a month for XP drivers. With an e6600 and acceleration, you'll be at 20% CPU with VC1, and <3% for h264.
Having said that, with en e6600 (or even an e6400) you can just decode everything in software anyway. As above, you could wait for ATI's reply, but frankly complete VC1 offload is a total non-feature, because it's easy work for your CPU.
arfster is offline
post #8 of 8 Old 05-10-2007, 06:17 AM
ballenjr's Avatar
An E6600 would work fine.
ballenjr is offline
Reply Home Theater Computers
