Final Decision, this is it, a HTPC 1080p HD For $700 Max - Post your suggestions! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-16-2007, 01:54 PM - Thread Starter
Dodgexander's Avatar
Ive come to the end of my teather.
I need a 1080p capable system..it will need to work without frame drops using 1080p h264 discs with high bitrate!Preferably id like to O'C.
Natalya Simonova: Do you destroy every vehicle you get into?
James Bond: Standard operating procedure. Boys with toys.
Goldeneye
Dodgexander is offline
post #2 of 6 Old 05-16-2007, 02:04 PM
zangmann's Avatar
renethx has 2 suggested builds, one of which is about 1/2 your budget, both capable of playing HD content smoothly. With the new 8500/8600s (or upcoming ATI HD2x00s) h264 should not be a problem anymore.
http://www.avsforum.com/avs-vb/showthread.php?t=710828
zangmann is offline
post #3 of 6 Old 05-16-2007, 02:17 PM - Thread Starter
The number of times ive looked through that thread...any personal suggestions?
Im not to keen on the pc5300 ram!
Goldeneye
post #4 of 6 Old 05-16-2007, 02:51 PM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
Then just buy a DDR2-800 kit...the motherboard will do what it can, but you should have enough headroom this way.
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
post #5 of 6 Old 05-16-2007, 02:54 PM
bdizzle's Avatar
8500gt - $99
q6600 - $266 (quad core after 7/22 price drop)
throw in a gig or 2 of ram, a cheap mobo and your pretty much set (assuming you already have a case, psu, monitor, etc). the 8600/8500 does most of the work for h.264 sources and the cpu should be able to handle anything you throw at it.
the only issue is getting a bd/hd-dvd drive for cheap if you wanna go down that route.
bdizzle is offline
post #6 of 6 Old 05-16-2007, 03:20 PM
zangmann's Avatar
ya definitely go with 2GB of DDR2800 and the 8500. I would honestly go with renethx's recommendations, his opinion is highly valued here. Don't blindly purchase, but everything I've seen recommended is high quality. Good luck!
zangmann is offline
Reply Home Theater Computers
