2 questions about ht setup. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-29-2007, 10:19 AM - Thread Starter
fishandfly's Avatar
1. Is a dvi cable the preferred method to go 35 feet from htpc to plasma?
2. I want to have the audio go from the htpc to both the surround sound as well as the plasma, so we don't always need the surround sound cranked. Is that possible?
fishandfly is offline
post #2 of 2 Old 05-29-2007, 10:38 AM
S-dogg's Avatar
1. It depends on what you're feeding the signal to. But, a digital connection will give you the benefit of no signal loss or interference over a longer run.
2. It depends on how you're sending the signal. If you're sending multichannel analog, just put a splitter on the front channels. If you're sending a digital (optical or coax) signal, you'll need to ensure your sound card can ouput analog audio at the same time. Assuming yes, just run the front channel to the TV.
We'll need more info on your setup before giving any specific advice.
Insanity is just a state of mind
Visit the Atomic Playground for the latest on movies, video games, computers, and more!
http://atomic-playground.blogspot.com
S-dogg is offline
Reply Home Theater Computers
