Is there an easy to use digital room correction software for multichannel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-02-2007, 08:40 AM - Thread Starter
dbossa's Avatar
After googling DRC, I came up with something called BruteFIR but it looks quite complicated. Is there any such thing as an easy to use and intuitive digital room correction software for a multichannel setup that runs on Windows?
dbossa is offline
post #2 of 5 Old 06-02-2007, 08:21 PM - Thread Starter
dbossa's Avatar
Anyone?
dbossa is offline
post #3 of 5 Old 06-03-2007, 05:40 PM
Herc's Avatar
Yes, do a search for "convolver". It's a filter that works kind of like ffdshow
Herc is offline
post #4 of 5 Old 05-04-2008, 03:43 AM
mshults99's Avatar
It's called SincAudio: http://www.sincaudio.com/. Haven't tried to use it yet, looks pretty straightforward. Anyone out there got experience with it? Looks simpler to use than some of the other approaches mentioned here, and more sophisticated than Vista's approach. Cheaper than the Acourate stuff.
But until I know it works, I don't know if it's worth it. Will update when I do.
mshults99 is offline
post #5 of 5 Old 05-07-2008, 11:11 AM
syntheticwave's Avatar
I know, BruteFIR works in the most http://en.wikipedia.org/wiki/Wave_field_synthesis - applications. Seems to be one of the best possibility for using impulse responses for create virtual environements.
syntheticwave is offline
Reply Home Theater Computers
