No sound from HTPC to LG LCD hdtv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-12-2007, 08:27 AM - Thread Starter
nimiq1's Avatar
On the topic of audio from htpc via lcd hdtv. I have hooked up my HDTV to the htpc ( motherboard asus m2a-vm hdmi ) using a dvi from the pc to hdmi on the TV.
I am not getting sound when i play files via medi player, do I need another cable for sound, and if so where should i plug it into? The board has an hdmi port and spdif.
So am using the hdmi on the board to connect to the only HDMi on my TV.
The manual is crass really, and that is why I resulted to asking here. I have connected using dvi-hdmi and get a picture, also when I do hdmi-hdmi, I get a picture also.
Here are my parts:
1. Antec fusion case.....$184 cnd
2. lg dvd writer....$40.79 cnd
3. ASUS M2A-VM HDMI (AMD 690G) mainboard .....$92.99 cnd
4. Crucial Rendition 1GB DDR2 667/PC5300 240-pin ( 1.5gb ) $39.99 + $22.99
5. Western Digital (WD3200KS) Caviar 320GB SATAII 7200RPM 16MB Buffer (OEM)..............$84.99 cnd
6. AMD Athlon 64 X2 4200+ (65W) Dual-Core Socket AM2, 2.2GHz, 512KB x2 L2 Cache, 2000MHz HT, 90nm (ADO4200CUBOX)........$122.99 cnd
7. OS....vista ultimate
nimiq1 is offline
post #2 of 6 Old 06-12-2007, 09:53 AM
stuckinthemud's Avatar
DVI doesn't do sound. You need to run a cable from the sound card's sound port to the TV. SPDIF or optical sound cable would be best. But I ran composite and have been happy with the results. Will be going to the store today to pick up the optical cable though...so I can have surround sound again.
Nate
stuckinthemud is offline
post #3 of 6 Old 06-12-2007, 10:14 AM - Thread Starter
nimiq1's Avatar
I am using hdmi to hdmi, and I don't have an audio receiver either. The PC is just connected directly to the TV.
nimiq1 is offline
post #4 of 6 Old 06-12-2007, 01:13 PM
olyar15's Avatar
Check the motherboard manual to see whether the HDMI output will send audio. I doubt that, it is probably only sending video.
Charles
olyar15 is offline
post #5 of 6 Old 06-13-2007, 09:39 PM
gazebo's Avatar
Quoted: 14 Post(s)
I remember reading somewhere you have to enable audio to HDMI port in the BIOS. Let me know if it works. I don't own this board if the audio works over hdmi I'll build my next htpc using it.
gazebo is offline
post #6 of 6 Old 06-14-2007, 07:41 AM
zangmann's Avatar
I had this problem with the Abit F-I90HD I set the pc up with DVI and the bios needed to be changed to HDMI for the audio to be picked up. Maybe its the same here.
zangmann is offline
Reply Home Theater Computers
