Easy HDTV - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 158 Old 01-05-2008, 11:27 AM - Thread Starter
gc04's Avatar
CarolinaGuy
What's your zip code and cable provider?
Greg
Easy HDTV, HDTV viewer for ATSC tuner cards
Easy HDTV DVR, HD DVR for ATSC tuner cards
gc04 is offline
post #32 of 158 Old 01-05-2008, 02:11 PM
RLDWV's Avatar
I did a scan of QAM 256 with the same result - scanned 137 channels, many went in the 95-100% range, one even stayed frozen in the viewer window. Once the scan was done, the channel list stayed empty. When I closed the app it gave the windows "application had a problem" dialog box.
Zip: 25401
Cableco: Comcast
Tuner: Fusion5 USB
Bob
...there are also unknown unknowns. These are things we don't know we don't know." -D. Rumsfeld
RLDWV is offline
post #33 of 158 Old 01-05-2008, 03:20 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
Can the Beta version coexist with the production version on the same pc if installed in different directories?
qz3fwd is offline
post #34 of 158 Old 01-05-2008, 04:51 PM - Thread Starter
gc04's Avatar
Not entirely, the desktop shortcut and the start->programs->Easy HDTV->Easy HDTV shortcut will point to the last one installed and you'd have to manually create a new shortcut to the first one installed. Other than that it would work.
Greg
gc04 is offline
post #35 of 158 Old 01-05-2008, 05:12 PM
RLDWV's Avatar
Anything else you want me to try with the App?
RLDWV is offline
post #36 of 158 Old 01-05-2008, 07:08 PM - Thread Starter
gc04's Avatar
No I can't think of anything else to try right now. Do you know what channel to frequency mapping Comcast uses in your area? Standard, IRC, HRC?
Greg
gc04 is offline
post #37 of 158 Old 01-05-2008, 07:32 PM
fishmonger's Avatar
Originally Posted by gc04 View Post
The fact that it tuned something sounds promising. The beta has been updated, found a tiny little mistake in it , to version 1.2.3 beta. Give the new version a try and keep your fingers crossed.
Same behavior with the 1.2.3 beta. It tunes several channels going through the scan (cable channel map, 256-QAM modulation and video only, no audio, not sure if that is normal or not), but adds nothing to the channel list.
I have a very nice frozen picture of Hillary Clinton on ABC HD in the EasyHDTV window right now, though.
e: I am on Comcast in 77382
fishmonger is offline
post #38 of 158 Old 01-06-2008, 07:15 AM
RLDWV's Avatar
Oops - right over my head! Up until now I've left it up to my Fusion software to figure out. Is there something I can look at that will give me any indication?
RLDWV is offline
post #39 of 158 Old 01-06-2008, 09:09 AM - Thread Starter
gc04's Avatar
I don't see anything in the software you can check and there's nothing on the comcast web site about it.
Another possible problem is there may not be any PSIP data. When using the Fusion software do the channels have real names like "ABC" or are they just a number like "D31"?
Greg
gc04 is offline
post #40 of 158 Old 01-06-2008, 09:18 AM - Thread Starter
gc04's Avatar
Anyone using the Hauppage HVR-1600 should NOT use the "nanocosmos MPEG-2 video decoder filter 2" when selecting the video decoder, even though it appears first in the list. Easy HDTV is failing without reporting an error when trying to use. You should use the "InterVideo NonCSS Video Decoder for Hauppage" or the "HCW MPEG-2 Video Decoder"
Greg
gc04 is offline
post #41 of 158 Old 01-06-2008, 10:17 AM
Lkr
Lkr's Avatar
im using an ATI TV Wonder 600. I've started to get errors, so it crashes as soon as I open it. I've started using Media Center again. Also, I tried the beta, and none of the QAM works for me. I have Comcast in 32828.
Another bit of feedback/opinion. I can't justify paying $20 for this software, when there are other apps just like it that are free. my advise would be to add some sort of recording option in it and it would easily be worth $20.
Lkr is offline
post #42 of 158 Old 01-06-2008, 07:38 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
Just ordered a license today-looking forward to future feature updates!
qz3fwd is offline
post #43 of 158 Old 01-07-2008, 05:32 AM
RLDWV's Avatar
They are shown as D763, D1085, etc., which is primarily why I want to dump the Fusion SW. With about an hour's worth of programming effort the DVICO boys could easily let us assign our own friendly names to the channels (after they're scanned and added to "favorites"), but I guess that's just not to be...
Bob
RLDWV is offline
post #44 of 158 Old 01-07-2008, 10:21 AM
CarolinaGuy's Avatar
GC04,
I'm with TRIAD Time-Warner, (Greensborro, Winston-Salem-High Point, NC)
My actual zip is Thomasville, NC 27360.
According to this I should have several source.
http://www.silicondust.com/hdhomerun...Postcode=27360
I will tried the new decoder I just read about in the posting.
CarolinaGuy
CarolinaGuy is offline
post #45 of 158 Old 01-07-2008, 12:08 PM - Thread Starter
gc04's Avatar
Originally Posted by CarolinaGuy View Post
GC04,
CarolinaGuy
It won't help with channels being added to the channel list, but you might see some video while scanning for channels.
Greg
gc04 is offline
post #46 of 158 Old 01-07-2008, 04:07 PM
gc04,
you were right, still unable to receive any channels.
CarolinaGuy
post #47 of 158 Old 01-08-2008, 06:00 AM
RLDWV's Avatar
gc04,
So, you thinking about posting another beta version on your site, or is the lack of PSIP data a major hurdle for your app?
RLDWV is offline
post #48 of 158 Old 01-08-2008, 08:22 AM - Thread Starter
gc04's Avatar
It'll be a while before there's a new beta. Finding channels without PSIP data will take a fairly significant change to what we have now.
Thanks for giving the beta a try, I'll let you know when there's an update.
Greg
gc04 is offline
post #49 of 158 Old 01-16-2008, 08:52 AM - Thread Starter
gc04's Avatar
The QAM Beta has been updated to version 1.2.4. It now will detect channels without PSIP data.
Greg
gc04 is offline
post #50 of 158 Old 01-19-2008, 08:12 AM
lclaman's Avatar
Just gave 1.2.4 beta a try with my QAM card (Avermedia A180). It only partially (barely) works.
Easy HDTV is correctly picking up PSIP data for a few channels (the networks) and remapping them; e.g, it shows 2.1 as CBS HD, 4.1 as NBC HD, 4.2 as WNBC Weather plus, etc. However, Easy HDTV is not displaying any picture for these channels. It is only showing a picture for a couple of channels (the comcast preview channels, which are not so useful to watch )
lclaman is offline
post #51 of 158 Old 01-19-2008, 10:39 AM - Thread Starter
gc04's Avatar
What kind of signal strength do you get on those channels? Can you get those channels using other software?
Greg
gc04 is offline
post #52 of 158 Old 01-19-2008, 12:42 PM
lclaman's Avatar
I can get the other channels using the Avermedia software; however the avermedia software does not show the PSIP info; I'm not sure if it is not picking it up or if it simply doesn't decode it.
As for signal strength, I'd say the strength is high, but I don't know how to give you a level reading. (Does your software do this?)
Are there any debug settings I should try?
lclaman is offline
post #53 of 158 Old 01-19-2008, 12:59 PM - Thread Starter
gc04's Avatar
Signal strength is shown on the On Screen Display. Close the channels dialog, tune to the channel and click the OSD button. The signal strength is in the lower right corner of the OSD displayed as a percentage.
Greg
gc04 is offline
post #54 of 158 Old 01-19-2008, 02:32 PM
lclaman's Avatar
I'm seeing 100% signal strength.
Here's a snapshot:
lclaman is offline
post #55 of 158 Old 01-19-2008, 03:01 PM
Troubleshooter's Avatar
Wow, aint life grand when you can shill your wares and get people to beta test it in the same shot. Bill Gates and Larry Ellison would be proud!
-Trouble
Troubleshooter is offline
post #56 of 158 Old 01-20-2008, 07:50 AM
lclaman's Avatar
Actually, I think it's great to be able to get direct support from the software's author. Try contacting Bill Gates for your next Window's problem and see what response you get.
Now can we get back on topic?
lclaman is offline
post #57 of 158 Old 01-20-2008, 11:11 AM - Thread Starter
gc04's Avatar
Thanks for the info. That's very odd that it gets the PSIP info but not the video.
Greg
gc04 is offline
post #58 of 158 Old 02-08-2008, 10:02 PM
NeonGerbil's Avatar
Hey wow, just found this thread.
I just e-mailed some suggestions to the email address on your website.
I like the "TV only viewer" design. I don't use my computer to record or pause TV. I don't want a PVR, DVR, TiVo, etc.
I just want a window with TV in it.
Easy HDTV has been a neat alternative to Watch HDTV, as it actually works a bit better under Vista.
Suggestions I emailed about:
- Having a quick, channels-only pop up menu so I don't have to (SLOWLY) page through the channels with the Up/Down arrow.
- Add "overscan" to crop out some of the crud that is on the borders of some broadcasts.
- Add a quick aspect/zoom change button. Maybe a quick zoom between 16:9 and 16:10 for those with widescreen monitors and dont mind cutting a little off on the sides.
NeonGerbil is offline
post #59 of 158 Old 02-09-2008, 02:30 PM - Thread Starter
gc04's Avatar
Channel changing shouldn't be slow. You don't have to wait for the video to appear before swithcing channels again, like you do on a lot of other programs.
Over scan and 16:10 are both on the to do list. We were thinking of stretching a 16:9 to fill a 16:10 window rather than cutting off some of the picture on the sides.
Greg
gc04 is offline
post #60 of 158 Old 02-09-2008, 02:43 PM - Thread Starter
gc04's Avatar
Thanks to all who tried out the QAM beta. I've removed the QAM beta link as trying to add/debug the QAM support remotely isn't working very well. We'll try working on the QAM support in the future as soon as we can get access to cable locally.
Greg
gc04 is offline
Reply Home Theater Computers
