Reverse HDMI Switcher? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-01-2007, 03:38 AM - Thread Starter
Pimpyo's Avatar
I have an Xbox360 Elite and use HDMI to display onto my HDTV as well as to capture video via HDMI with a Blackmagic Intensity.
Instead of having to turn off and restart the 360, unplug and move cables, and all that every single time, I would like to get a reverse HDMI switch.
1 input that can switch to 2 outputs.... but i can not seem to find any. I don't know if it would be called something else besides a reverse switch.
I have tried running a few of the regular switches in reverse from a local Best Buy, but I have had no success.
Does anyone know where to find a reverse HDMI switch, or of a regular switch that can be used in reverse?
Scott
(ps, first post to AVS)
Pimpyo is offline
post #2 of 11 Old 07-01-2007, 09:15 AM
Kal Rubinson's Avatar
Quoted: 672 Post(s)
Liked: 456
Check the Gefen line. They have 4x2 switchers and other devices with 2+ outputs.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #3 of 11 Old 07-01-2007, 10:03 AM
Rupert's Avatar
Scott
Welcome to the forum...
Do you really need to switch between the two devices? It sounds more like you want to distribute one signal simultaneously to two devices. If so, an HDMI splitter should work:
http://www.gefen.com/kvm/product.jsp?prod_id=2514
Rupert is offline
post #4 of 11 Old 07-01-2007, 10:23 AM
Ozy666's Avatar
Blech, expensive!
You could try monoprice for much less.
http://www.monoprice.com/products/su...d=10113&style=
Also, they have passive splitters for cheap, but I have no idea how well they would work. Cheap enough that it might be worth the gamble.
Ozy
Ozy666 is offline
post #5 of 11 Old 07-01-2007, 12:35 PM
ralphuses's Avatar
Originally Posted by Ozy666 View Post
Blech, expensive!
Ozy
Or get the monoprice 5 in 4 out.
ralphuses is offline
post #6 of 11 Old 07-01-2007, 01:13 PM
pcCinema's Avatar
If I were you I'd be looking for a splitter/HDCP stripper. It would allow you to not only do what you're asking for, but also to do forbidden things like record premium HD from cable.
Something like the Spatz Dvimagic.
Troy
The Non-Profit Home Theater Company will make your HTPC experience much easier.
Link for info on our first project
pcCinema is offline
post #7 of 11 Old 07-01-2007, 07:10 PM - Thread Starter
Pimpyo's Avatar
Blech, expensive!
Ozy
Ah, thank you! That isn't much more than a retail HDMI switch costs.
Looks like it has what I need and has good review from the website.
Thanks again,
Scott
Pimpyo is offline
post #8 of 11 Old 07-01-2007, 08:09 PM
Ozy666's Avatar
And again, you could try the passive ones for much cheaper...just don't know if they would work properly.
Ozy
Ozy666 is offline
post #9 of 11 Old 07-02-2007, 06:29 AM
Taldir's Avatar
I use the one from FireFold. It was cheaper then monoprice and works well.
Taldir is offline
post #10 of 11 Old 08-25-2007, 07:30 PM - Thread Starter
Pimpyo's Avatar
Ah, firefold FINALLY got their 1x2 HDMI splitters in stock (yes, almost two months from OP). Should be arriving within the week.
Man, that $53 pricetag is nice.
http://www.firefold.com/Products/1X2...2SPLITTER.aspx
Pimpyo is offline
post #11 of 11 Old 11-20-2009, 01:43 PM
wscribbler's Avatar
Did this work for you? I know it's been a long time. Perhaps you've come up with another solution? Please post if you have.
wscribbler is offline
Reply Home Theater Computers
