PC DVI to HDMI cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-26-2007, 05:57 PM - Thread Starter
Scamps's Avatar
Is there a trick to this?
I hooked up my PC to my snazzy new LCD TV (46LX177) using a DVI-to-HDMI cable but I get no picture.
Is there a setting I need set, the Blu Ray and the Cable box are working fine via HDMI.
Can I even do this?
Scamps is offline
post #2 of 10 Old 07-26-2007, 07:26 PM
adeelofsteel's Avatar
I have the same problem. For whatever reason, DVI to HDMI doesn't work (the computer cannot detect the attached LCD TV). I gave up and used a VGA cable and that worked instantly.
adeelofsteel is offline
post #3 of 10 Old 07-26-2007, 07:37 PM - Thread Starter
Scamps's Avatar
Hummm, so what are DVI-to-HDMI cables good for I wonder?
Scamps is offline
post #4 of 10 Old 07-26-2007, 07:52 PM
Thoraudio's Avatar
DVI to HDMI works with my X1300 and Akai lcd tv.
I'm going to assume that you've put the TV on the right input, and have enabled the right port on your video card.
What video card?
Thoraudio is offline
post #5 of 10 Old 07-26-2007, 11:28 PM
aboroth00's Avatar
Liked: 26
I have the same question. I was planning to connect my computer with a Radeon 9600xt (i know pretty old) to my Panasonic 37px60u and i don't know which output and cable on my computer to use, the dvi-hdmi cable or vga to component.
aboroth00 is offline
post #6 of 10 Old 07-27-2007, 08:35 AM
Thoraudio's Avatar
I'd suggest the DVI to HDMI route.
post #7 of 10 Old 07-27-2007, 08:55 AM
Craig Woodhall's Avatar
remember you have to go into the display properties on your computer and set up the tv as a second monitor.
Craig
Craig Woodhall is offline
post #8 of 10 Old 07-27-2007, 09:00 AM
Warren_G's Avatar
Actually, a couple of things you want to check:
Are you set to a resolution that the TV supports via HDMI? If you are using a newer Nvidia card, hook it up to a monitor and go into the Nvidia control panel and use the HDTV setup to select 720p as it should work for all LCD TVs.
Are you using just one display device? If you have a monitor and the TV hooked up, both need to be enabled.
Once you have set it up using a monitor, and ensured that your drivers are current and your connections are good, make sure that the TV is on, and selected to the correct HDMI input, and then turn on the PC. HDMI is the same standard as DVI, so it should work.
Warren_G is offline
post #9 of 10 Old 07-27-2007, 09:09 AM - Thread Starter
Scamps's Avatar
I will work my way through your list as soon as I make it home. Thanks.
Ps. I'm using an ATI X1900 Crossfire card.
Scamps is offline
post #10 of 10 Old 07-27-2007, 09:58 AM
Sarvatt's Avatar
There's a whoooole bunch of different types of dvi-hdmi adapters out there I have found. I have problems using my DVI-D single link to HDMI cable with all of my equipment with HDCP but no problems using an adapter with a DVI-D dual link plug on the end on any of my DVI equipment. Something to keep in mind incase you exaust all other options
Sarvatt is offline
Reply Home Theater Computers
