convergence adjustment by graphics card driver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-28-2007, 01:01 PM - Thread Starter
vojins's Avatar
hi people!
I am looking for a way to adjust the color convergence of a lcd beamer:
I switched some time ago from a dlp beamer to a panny pt-ax100 lcd beamer. now i built a htpc as a source for it, and I am looking to find a solution to the only problem, which i have with the panny: bad color convergence.
Its red panel seams to be a bit more then one pixel to the right and one pixel lower than the other two colors. First I searched in the settings of the beamer and found no options for adjusting convergence. I have talked to the panny support, but they say that it is normal with value beamers, to have "less then perfect convergence"...
Then I searched in the drivers of my ATI card of my htpc, to find a possibility to "move" the red signal to the best position, but there were no such options. I downloaded powerstrip, because I thought it could do the job, but again nothing!
I'm sure, I'm not the first to think about this, to adjust the convergence by the graphics card, but I did not find anything on the net or in the forum! Can someone help me?
vojins is offline
post #2 of 2 Old 07-28-2007, 01:57 PM
pcCinema's Avatar
Nope you are SOL... sorry.
Sell the pj and buy another, or break it on purpose to get a warranty replacement. (wink)
You might have to go through a few pj's to get a good one without any issues.
Just another reason why some of us STILL love crt projectors...
Troy
The Non-Profit Home Theater Company will make your HTPC experience much easier.
Link for info on our first project
pcCinema is offline
Reply Home Theater Computers
