Dell M2010 Remote - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 08-05-2010, 07:35 PM
inslee's Avatar
I purchased the USB dongle and remote off ebay (new) and when I plug in the dongle, Windows 7 x64 picks up USB input drivers and all but when I press the "wireless" button on the remote itself, it tells me to hold the remote 6 inches from the computer/dongle (which I do) but it keeps saying "connection unsuccessful)
Any Ideas?
Also, is there supposed to be some kind of light that shows up on the bottom or something? it looks like there is but nothing lights up when I plug the dongle in
inslee is offline
Old 12-23-2010, 10:21 AM
swommer's Avatar
Originally Posted by neoalex View Post
I did get the remote to work on Windows 7 X64. Here's how, I actually have two remotes, the Dell remote like most of you with the Dell internal USB receiver. I eventually purchased the remote from gyration too (when they released one with an LCD just like the Dell remote (though the color scheme they chose is not great):
This new remote actually worked perfectly on my AMD HTPC, including the LCD. I then moved the Dell remote (including the Dell receiver) to a newly built Core i7 PC running Windows 7 X64 Professional. I installed the software that came with the new Gyration remote which is an updated version and low and behold everything worked including the LCD (which never worked when I had it on the HTPC). The new software is also able to control iTunes and display info from it on the LCD. I'm sure some of you could use this, and since it's not yet posted on Gyration's website, I only have it on the CD the new remote came with, here it is, for all to enjoy:
Hope this helps ,
Have fun.
Can somebody upload the driver again? The links are invalid now...
swommer is offline
Old 01-07-2011, 06:47 PM
neoalex's Avatar
swommer: Sorry for the late reply. The drivers are actually now available on gyration's website, you can download them from Support -> Downloads section. Here's the direct link:
http://www.gyration.com/images/stori...sicService.zip
neoalex is offline
Old 03-29-2011, 05:45 AM
notsky's Avatar
Got scammed on an ebay purchase and got the whole kit, but without a USB RF reciever..... anyone know the part number and/or where i can buy this? thanks!
notsky is offline
Old 03-29-2011, 06:12 AM
notsky's Avatar
will this reciever work with the m2010 remote?
http://www.amazon.com/Movea-GYAM1100...pd_sim_sbs_e_3
or this one?
http://www.amazon.com/Gyration-MINI-.../dp/B0000UV090
Just wanted to make sure the dell remote would work with a gyration branded reciever, as i cannot find the dell branded reciever anywhere.
notsky is offline
Old 03-31-2011, 10:04 AM
Jim E.'s Avatar
According to Gyrations, the receivers on their site will NOT work with this remote. They said they no longer have those receivers either. YMMV.
or this one?
Jim E. is offline
Old 06-22-2011, 08:25 PM
WeAreNotAlone69's Avatar
Dell WJ151/RY496 XPS M2010 LCD remote.
Q: Will the Dell WJ151 remote- function as a BASIC WMC remote WITHOUT the RF dongle /RH515 transceiver? via a standard ehome IR receiver?
(Currently I am controlling customized HTPC Win7 WMC (Win7 WindowsMediaCenter) with a HP Picasso 5070-2583 (IR) remote= paired with a (IR) HP branded 5070-2584 receiver. (that id's itself as a Microsoft eHome Infrared Transceiver)
IR Receivers and remotes- HP, Dell, etc can be mixed and matched. EG: HP remote with Dell transceiver.
From reading thru various parts of the thread:
Dell XPS Media Center M2010 came with a OEM version of the Gyration Air Mouse remote.
Gyration remote is more programmable/can control more devices.
RF module Dell to Gyration branded units are different.
Originally - 2-3+ years ago...the RF module (RH515, Dell part number=YY993)needed so the LCD functioned properly was a (internal) sub-assembly for the Dell XPS Media Center M2010.
Obtaining such was hit or miss as it was a INTERNAL part.. Once the spares were gone it was phased out.
Later on a external RF dongle /kit containing Remote and RF dongle was released as a bundle.
At some point in time it was phased out too.
Fast forward to 2011-06
RF modules are hard to find /expensive...
(Remotes themselves- Used ones are likely to be worn out- New old stock units "may" be problematic- due to age/ how they were stored.)
QUESTION:
Q: Is the Dell M210 remote functional as a BASIC WMC (IR) remote without the RF dongle?
Is it pure RF, Or does it transmit basic WMC commands via IR.... and the Gyration part of the remote /lcd functions via RF?
(I ask as I'd like to us the remote as a basic WMC remote, until RF components could be sourced.)
WeAreNotAlone69 is offline
Old 06-23-2011, 09:18 PM
GnatGoSplat's Avatar
No, it will not. I just tried it.
It's too bad, I have 3 of these with no dongles that are completely useless. I have been sitting on them for 4-years, waiting for an opportunity to buy even one dongle, but the opportunity never presented itself. Even tried to sell them on eBay once, didn't get a single bid. If I were a normal, non-packrat kind of person, I probably would have chucked them in the trash years ago.
Shawn
GnatGoSplat is offline
Old 06-23-2011, 09:43 PM
nc88keyz's Avatar
Quoted: 153 Post(s)
Liked: 78
I love this remote. have 2 backups as well in case they go bad. Have 3 htpcs in the household and use them on two.
I have a proposal for anyone with means.
I have one new pcb RF dongle that i will trade even for one T7600 Core2Duo CPU. I dont really want to give it up but i have 2 already and can use my android remote for the third htpc. However, on the other hand I do not want to pay 100 bucks for a T7600 chip for an older laptop.
Both products are scarce. I doubt anyone has one of these just lying around. but thought I would throw the offer around.
Thats a Merom 667Mhz bus Core2Duo ...the fastest cpu for the chipset it was designed for.
HT1: UN78JS9500, AVR: AVRX-7200WA, AMP: UPA-7, SPKRS: L/R: Veritas 2.3I C: 2.0CI SUR: V2.0R,, SUB: SVS SB13Ultra x2 ATMOS: 4X RC-6C, NUC i5/KODI, ChromeBox/KODI, ShieldTV
HT2: LC80LE844U, AVR: AVR4311CI, SPKRS: L/C/R: Veritas 2.2C, SUR: RC-RCRx2, SUB: 10.3x2
STORAGE: DS1812, DX513 x 2 - 4TBx18 Hybrid Raid, (It Just Works!!) R/C: HarmonyOneX2, Harmony880x1
nc88keyz is offline
Old 09-22-2011, 06:59 PM
arpad's Avatar
anybody know of a place to buy the rh515?
many thanks
arpad is offline
Old 09-23-2011, 01:01 PM
MikeyJinPhx's Avatar
Got one back in April directly from Dell. I just went to their site and did it through the online chat. They had both the yy993 and RH515 in stock for $14.99 each. Once you get one, follow this guide. Worked perfectly for me.
http://hackaday.com/2008/10/08/how-t...center-remote/
Mike
MikeyJinPhx is offline
Old 11-06-2011, 06:41 AM
nc88keyz's Avatar
Quoted: 153 Post(s)
Liked: 78
Im usually all about making some money on ebay and what not but, I faired very well with HP touchpads sold at profit.
For those who have been waiting,
FYI, paypal payment will bypass the zip code providence check as this is from dell canada, however with that said,
Here is a source of RH515s. / Manufacturer Part# : YY993 | Dell Part# : YY993
http://accessories.dell.com/sna/prod...=baynoteSearch
I have two backups. Anyone who appreciated this link and has a spare remote itself my down arrow no longer works. Please be kind and let me know if you have something nice for me.
nc88keyz is offline
Old 11-07-2011, 04:39 PM
nc88keyz's Avatar
Quoted: 153 Post(s)
Liked: 78
My order for 2 were cancelled from dell ca,
Seems you cannot trick their credit authorization system with CA ship to US. Even though, by changing the country code, changed providences to citys, and registered us zip codes. even mr rebates worked with discounts. Alas, order was cancelled this morning for undefined reasons.
I think they are in stock though at dell ca. give it a whirl if you are up north and need RH515s.
Good luck to all.
nc88keyz is offline
Old 11-22-2011, 09:30 AM
little.dread.1's Avatar
I realise this is an old thread but can anyone please tell me if this is the unit that will work for the with the Dell M2010 Premium remote?
Code:
http://www.amazon.com/Genuine-Microsoft-Premium-Receiver-OVU412002/dp/B0041EATS4/ref=pd_rhf_ee_p_tab0_t_1
Tia
little.dread.1 is offline
Old 11-22-2011, 09:38 AM
Douglas_d's Avatar
No,
That receiver is an IR receiver. The Dell M2010 remote uses RF to communicate with the computer. That receiver is for standard ol' IR remotes.
Douglas_d is offline
Old 11-30-2011, 02:09 PM
mflanagan's Avatar
Darnit! Is there any way to get that part from Canada to the U.S.? I cant beleive there is no way to get on here in the US
Flan's Theater!
Xbox Gamertag: Darth Flan
mflanagan is offline
Old 01-11-2012, 03:56 AM
ScAtMaN_UK's Avatar
Sorry to bump this old thread again but I am another sucker who was duped into buying the remote and CX701 kit only to find that it did not come with the RF dongle.
Does anyone have one spare or the board out of the M2010 they are willing to part with?
ScAtMaN_UK is offline
Old 01-19-2012, 08:43 AM
jetfxr27's Avatar
Now that the M2010 PC's as-is are plentiful, would it easier (if you're willing to pay) to get one of those?
18002884410
jetfxr27 is offline
Old 02-10-2012, 08:12 PM
DavidinCT's Avatar
Quoted: 245 Post(s)
Liked: 67
I would love one of those boards myself....
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
Old 02-11-2012, 10:41 AM
Auxon's Avatar
For anyone who is interested - I was successful at ordering two YY993 boards from Dell just a week ago and getting the hack to work . They are not listed on Dell's outlet webpage, but the customer service rep was able to find them without any issue. Cost was somewhere near $15 each.
Auxon is offline
Old 03-24-2012, 07:23 AM
brethg's Avatar
I have manged to find a uk suply of the boards but desperatly need a remote, can anyone help. i can source extra boards too
brethg is offline
Old 03-24-2012, 07:51 AM
nc88keyz's Avatar
Quoted: 153 Post(s)
Liked: 78
im sorry i dont have any remotes, i had bought three years ago for 14 each on ebay. I have 1 spare board, and 1 spare remote
Just three days ago, my arrows, back , ok button volume up all stopped working.
Using my handy iphone / htc tool kit to break the seal once again on the plastic casing. bought some foil conductive tape at hardware store used for sealing leaks in ducting. Its about 4-5 USD a roll. Use a hole-puncher to make near-perfect conductive pads, and refreshed the thin carbon material that is on the back of the keypad. This is what makes contact and closes the circuit to register button presses.
Result: buttons work perfectly now. I think once before I bought a broken remote to steal the pad itself out of it. This time I wants to see what could be done.
It works like new for anyone having similar problems. Once issues with all the remotes that were out there is they sat for years in a warehouse , so aging issues expected.
Good luck sourcing the remote for them. I still see them for 20-25 on ebay btw. Best HTPC remote ever. imo
http://www.ebay.com/itm/Dell-Wireles...item58928cd5ee
nc88keyz is offline
Old 03-24-2012, 11:57 AM
brethg's Avatar
yeh but they're in texas which is $43 shipping :-(
brethg is offline
Old 03-25-2012, 06:51 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I had an online chat with Dell and they are going to request a RH515 for me, price is $10.99.
Mrkazador is offline
Old 04-24-2012, 07:35 PM
snake killer's Avatar
Wow!
I never imagined after all these (almost 4) years this thread would still be active.
I have not used my Dell M2010 remote in a while.
I am going to test it soon and I am willing to sell it at a reasonable price. I have the receiver (RH1515) as well.
I don't know the situation with the drivers but I did save the XP drivers on my hard drive back in 08.
Any body interested can PM me.
Otherwise I'll put it on eBay when I find time.
snake killer is offline
Old 04-27-2012, 01:25 PM
loginatnine's Avatar
FYI, I just phoned dell in Canada for YY993 and they did not have any but they had the CX071 in stock for 170$, thought it was a joke but it's not!
Is it possible to strip the part from a M2010? My father in law has one! Or anyone here willing to sell me one?
EDIT: looks like CX071 is the whole kit w/ the remote and everything, I guess that's why it's so expensive!
loginatnine is offline
Old 05-14-2012, 08:03 AM
Can anyone confirm that this is the correct receiver? http://www.amazon.com/Genuine-Micros.../dp/B0041EATS4
Old 05-14-2012, 08:17 AM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
That's the IR receiver. Not the RF receiver.
assassin is online now
Old 05-15-2012, 08:29 AM
Posted: 11-22-11, 10:30 AM
Code:
Tia
Posted: 05-14-2012 09:03 AM
Standard media center (MCE) type remotes use IR, not RF so a standard MCE remote won't work.
RF= Radio Frequency (Radio waves) =Goes thru objects
IR= Infrared (Light waves) =line of sight
These remotes were custom manufactured for Dell by Gyration Inc, a maker of RF keyboards and wireless mouses.
Dell branded Gyration remotes ONLY work with custom (proprietary) Dell branded RF interface board. (YY993).
YY993 was (only?) installed in Dell M2010 media center pc/laptop? IIRC... or very few select Dell PC's hence why it's rare /hard to get.
Gyration did sell a version of the M2010 themselves with a matching dongle (USB stick containing RF interface board)
AFAIK Gyration branded remotes =work only with matching dongle.
(Thanks Dell for the custom proprietary branding job... Make is so it doesn't work with a standard Gyration dongle)
To clarify....
Dell M2010 remote uses RF to communicate with computer, NOT IR.
Dell branded Gyration remotes ONLY work with custom (proprietary) Dell branded RF interface board. (YY993)...
Old 05-15-2012, 12:53 PM
cdru's Avatar
Quoted: 20 Post(s)
There are more than a few receivers on ebay (search for YY993) for around $35. Helluva lot cheaper then the $170 if you can actually find someone who has it in stock.
cdru is offline
