video compression? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-27-2007, 04:49 PM - Thread Starter
mknutt's Avatar
Quoted: 25 Post(s)
I am currently using DVDShrink to rip my DVDs to my laptop. I tried the search function on the forum, but did not find the answer to my question.
I am ripping just the movie. Depending on the movie, I am still finding 4-5 GB per movie with no compression. Since I will only be watching these movies on the laptop, I am wondering what the "most preferred" level of compression to still allow decent video quality while saving valuable storage space. Thanks.
mknutt is offline
post #2 of 4 Old 08-27-2007, 07:14 PM
walford's Avatar
Are you sure you have no compression normally DVD's with their MPEG2 standard compression require about 2GB per program hour which is about what you say you are getting.
walford is offline
post #3 of 4 Old 08-27-2007, 07:53 PM - Thread Starter
mknutt's Avatar
Quoted: 25 Post(s)
Unless DVDShrink has compression that I am unaware of...I should have no compression. Keep in mind that I am only ripping the movie, an audio file, and 1 subtitle file. I am getting rid of all the menus and extras. For example, I ripped Anchorman as a test and my total file size was just over 4 GB. I believe the video itself with no compression was just under the 4 GB. I would like to cut this down more if I could, but I was hoping someone may know a "preferred" level of compression so I would not have to rip DVDs over and over at various compression.
mknutt is offline
post #4 of 4 Old 08-27-2007, 10:28 PM
Blue_MiSfit's Avatar
The only "preferred" level of compression is what works best for you.
I personally hate the look that compressed domain transcoders like DVD Shrink create, so I prefer no extra compression, I just rip 1:1 (or do a proper x264 or MPEG-2 backup with MeGUI or HC).
You may be able to stand higher compression from a transcoder like DVD Shrink. It all depends on what your eyes tell you
~MiSfit
Blue_MiSfit is offline
Reply Home Theater Computers
